Question about Kenmore Washing Machines
My kenmore washing machine model #110.88752796 the tub won't stay leval, it hits to one side of hte washer, I keep having to screw in hte springs --what part or parts is it most likley to be and how can I tell. I have it on its side on hte floor but I dont have a lot of experience with washers and dont want to just start messing with things. Thanks
  • 5 more comments
  • jamie3482 Nov 18, 2009
    I already know what you have told me so far, sorry I did not make myself clear --it is not the springs what would be the next thing i am looking for as well as how would i tell which part is out of wack?
    I have a kenmore stackable washing machine, what it going on is it sits a little off balance and eventually it unscrews the balance spirngs and it goes really off wack. I know to take the thing and open it which i have done and the springs look to be in good working order, what would I be looking for next as far as fixing hte problem as cheaply as possiable. This washing machine is only a few years old and from what I have heard this is pretty typical for this machine. thanks
    i have already opened the machine up and checked the springs they are ok, my question is what is hte next part you would check, so on and so forth... and what would i be looking for as far as being off balance.
    The machine is only a couple of years old and had the moter replaced.
    Thanks
    It has nothng to do with the levaling of my washer, I am mechanically inclined enough to figure that one out. It is one of the parts in the machine. Please read the entire post.
    Thanks
    I do have a little repair knowledge, amny washers with problems before.
    Thanks
    No I havent noticed any grease, I have access to the bottom- it open and on the floor for fixing. What else do you suggest to look for?
  • jamie3482 Nov 19, 2009
    I don't believe it is the springs because the tub sits at an angle without even doing anything-if I am wrong let me know- it looks to me to be the items holding up the tub.
    Thanks for continuing to work with me on this issue, I will try teh things you suggested.
  • 986 Answers
The outer tub is supported by springs, pistons or counterweights to keep it balanced. The weight of all that water in a wash load requires a powerful balancing mechanism. If the balancing system becomes detached from one or more points, it will not be able to balance the load properly. Furthermore, even if everything appears to be in place, as the appliance ages, the springs or pistons may begin to wear out and not support as much weigh as needed.
Unplug the washer and open the cabinet. Because of the variety of balancing mechanisms, you will have to inspect your machine to determine how it is balanced. Once you discover the mechanism, then inspect it for integrity. In the case of old parts that appear to be in working order, you may not be able to tell if they need to be replaced. They may be weak but appear to be in good condition. If no other solution resolves the problem, then replacing the balancing springs or other moving support parts may be called for.
Here is a link on how to open a cabinit for a washer.
http://www.acmehowto.com/howto/appliance/washer/check/open.php
Best of Luck. Any questions just ask.
Posted on Nov 18, 2009
  • 1 more comment
  • Roger Campbell
    Roger Campbell Nov 19, 2009
    Iam sorry its not working out for you. If you replaced the springs/pistons please ingnor this comment.
    Iam sure I said even though they look fine they may be worn and unable to support and balance the load. I would replace them and see. best of luck
  • Roger Campbell
    well it could be your imbalance has moved some tub mounts I have seen it before. Look and see if you see fatiged mounts. If you have it apart still measure the free length of the springs they should be relatively close to the same. Also check and see if the same amount of pressure yields the same amount of travel. If it does the springs maybe ok. Like I said the spring rate may diminish over time by use.
  • Roger Campbell
    Roger Campbell Nov 20, 2009
    No problem Iam just here to others out as much as I can.
  • 11,896 Answers
Sounds like your bearing or coupler is worn. Have you noticed any grease in the washer? That would indicate a bad bearing seal which is common. Youwill have to access the bottom of the tub to make sure. That is likely the problem.
  • Nate Stansfield
    Nate Stansfield Nov 18, 2009
    Check the tub seal to make sure it is not ripped or stretched. The retaining spring clips that are attached to your drum probably have come off
    (There are three or four of them) Push the drum to one side and look to
    see which ones have come off and re-attach them to their anchor points,
    you should have no more trouble. When loading your machine for the spin
    cycle just make sure that all clothes are evenly spread around the
    drums balance point before spinning out.
    The drum is mounted with spring or rubber bushings that act like shock
    absorbers. When machines get worn out they get very sloppy or even
    break. When the machines get real bad they shake violently.
  • Nate Stansfield
    Nate Stansfield Nov 19, 2009
    The tub mount or coupler is likely faulty.
  • 10,865 Answers
Hello. I can assist you. First of all you are going to need two things to solve your problem. The first is a small level, you can get a twelve inch or so level from any hardware store, home depot, valu home center, etc. Also pick up a remnant of carpet that is the same dimensions as your washer.
Now Put the carpet remnant under the machine and check the level front to back and side to side. Adjust which ever legs you need to adjust by turning them with a wrench.
Once it is all level, load the clothes into it. DO NOT overload it, ever, usually half to 2/3 full of dry clothing is considered to be a full load.
Now run it and enjoy your good work. Regards, Joe
The drum is hitting the back of the machine
remove the bottom front panel (2 screws) look in and on the left and right side you should see 2 shockabsorbers. They probably need to be replaced. The 4 plastic pins need to be removed. I used a socket to compress the "flanges" and a hammer to tap them out.
Apr 06, 2010 | Kenmore 44102 Front Load Washer
When agitating, washer moves side to side three to four inches each way. It hits against metal brackets under motor. Thank-you.
Depending on you model you may have a propblem with you inne tub not properly attached to the transmission shaft.
Also check all the spring that help keep the waher tub in place and balanced.
Mar 08, 2010 | Washing Machines
In spinning mode inside tub hits outside tub of washing machine of Kenmore .70 series, two speed automotic washer.
hi,
thats a 35 year old washer. we had one for years. the springs have lost their tension. youll have to run smaller loads, you can try sears parts direct for springs but they may not have them. It may be time to retire it. keep it for a backup in case you new one has a problem..
jm
Jan 06, 2010 | Kenmore Washing Machines
Have a 110.92380200 top load washing machine. replaced 3 suspension springs and 1 counterweight spring. not sure where the counterweight spring goes? I do know one side hooks to the rear bracket on which...
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
The sections on machine base or tub should give you a decent diagram of where the springs go.
Sep 09, 2009 | Kenmore Washing Machines
Washing macine balance
Adjust the legs on the washer that seems to be the problem. Or you could have broken the hinges and springs on the tub itself. The easiest thing to try is the legs first they just twist like a screw
Feb 09, 2009 | Kenmore Washing Machines
Kenmore wasing macine tub is off track
heres how to accces the washer insides
http://www.youtube.com/watch?v=vogysB7XOc8
the washer being "off track" sounds as if perhaps a spring holding the machine centered has snapped, look toward the rear bottom unit there should be a spring going from the tub to frame holding it to the middle
Dec 14, 2008 | Kenmore 24032\24036 Top Load Washer
My washer leaks occasionally from the back
ok i need a lilttle help from you,,,ok,,,open lid..take your hand and put it on the top of the agitator,,push the hole agitator and tub back,,and let it go if the tub stays back and does not come back center by its self,,your counter balance spring broke,,no mattter which way you push that agitator it shoud come back to near center..what could be bad counter balance springs ,,or tub surport springs.if you need help removing and changing please post
Dec 03, 2008 | Kenmore 15864/15862 Top Load Washer
THE WASHING MACHINE TUB ON MY KENMORE HE4T SLAMS AGAINST THE SIDES OF THE MACHINE AND EVEN CAUSES IT TO JUMP ACROSS THE FLOOR
remove the front access paenl 3 screws across the bottom fornt panel. under there you will see the 4 suspension(shock absorbers), look to see if they have broken or perhapsa just dislodged form hte unit ,
Dec 02, 2008 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
I have a Kitchen Aid clothes washer and the tub that you put clothes in won't stay centered. When it spins during the spin cycle, it gets out of balance and thump, thump, thumps............me and the...
there are 3 springs that hold it to the frame,remove the 2 screws from the washer head,one on each side,now pull up on the head and lift the front out and up,you will see 2 spring clips pop them out with a flat screw driver,open the lid and pull the washer case toward you,sit it aside and look at the other springs they will tell you where the other one goes,also the tub sits on a triangle bracket make sure that is in place to,under the tub,let me know-mike
Sep 26, 2008 | Washing Machines
Washing machine
WASHING MACHINES HAVE SPRINGS ON THE BOTTOM OF THE TUB THAT ARE MENT TO KEEP IT FROM SHAKING, LIFT THE LID BY INSERTING A SCREW DRIVER SIDE WAYS BETWEEN THE LID AND THE FRONT THEN TURN THE SCREW DRIVER, NEXT UNDO THE SCREWS ON THE RIGHT AND LEFT HOLDING THE FRONT ON TO THE MACHINE, NOW IT WILL SLIDE OFF AND YOU CAN SEE THE SPRINGS
Dec 18, 2007 | Estate TAWS800JQ Top Load Washer
Washing Machines Logo
146 people viewed this question
Sal DeAngelo
fordexpert
 Brian Main
Brian Main
