Question about Whirlpool GGQ8831L Gas Dryer
Hello is there a number i can call for assitance on lighting my gas dryer
    Sergeant:
    Champion:
  • 289 Answers
You don't lite a gas dryer.the glow bar light's the dryer.
Posted on Nov 18, 2009
Hange light on gas dryer
Hello Robert;
My name is Peter. I am a retired field service appliance technician.
The number that you have provided is your owners manual number. This is a generic manual which applies to several models.
Open the door on your dryer and you will see a label with the model number.
What are you trying to do? Replace the light? The light assembly?
Nov 12, 2014 | Kenmore 74602 Gas Dryer
Ignitor is lighting, going out after a few seconds,dries sometimes but mostly not drying
Hello Amy,
With the igniter coming on and then going off, yet their is no heat to the dryer the problem is going to be bad coils for the gas valve that need to be replaced.
This is a tip i wrote about the coils it includes the part number and instructions of how to replace them. http://www.fixya.com/support/r10174506-gas_dryer_starts_off_hot_but_after_while
GENE
Nov 13, 2011 | Roper RGX4634KQ Gas Dryer
Hello-I have the Kenmore Electric Dryer model 110-66842501 series 80. Started the dryer and noticed a burning smell & the dryer was unusually warm to the touch. Now there is no heat. Drum turns...
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jun 12, 2010 | Dryers
T701 dryer is plugged in but no power light and dryer won't star- it just stopped working
Hello, welcome to Fixya. I think you`ve come to the right place...in my humble opinion.
First things first, have you checked the 15amp fuses which are located at the back of your Asko dryer ? **Turn off your breaker at the home service panel, it should be a 30amp switch**
That is where I`d start. They are at the back as I said located next to where the power cord exit`s the unit. Look for 2 small round slotted caps ( these are the fuse holders/hubs ) either black or gray in color.
With a flat screwdriver fitted in the slot of the fuse hub, turn it a half turn counter clockwise an it should drop out...though it may need to be pulled out if it`s stuck in the holder part.
Replace with a 15amp "slow blow" ( the only difference is the slow blow are filled with sand and aren`t transparent glass tubes but rather gray or white in color ) if the fuse is blown. You can find these fuses at most brick & mortar appliance part stores or on-line parts vendors such as repairclinic.com, amresupply.com, reliableparts.ca etc. Part number is #8058140 and you should replace both. The number may substitue to an in-store number, it really depends on the vendor, just provide your model number and you should have no trouble.
Hope that is helpful. If so please rate the solution accordingly, if not let me know what you find or if you require further assitance.
Thank`s for visiting Fixya today and good luck.
macmarkus :)
May 08, 2010 | Asko T701 Electric Dryer
Whirlpool gas dryer heats then stops
you will want to do two things
first check you vent exhaust even a small clogg here can be detrimental
then if thats clear
repalcce the coils on the top of the gas valve
they are probaly weakening
they are called the boost and assit
or hold and assit
they sit ontop of the gas valve
Oct 13, 2009 | Kenmore 63942 Dryer
Maytag gas dryer will do the initial burn but will not start to flame again with the starter coil glowing
your gas coils are bad, more than likely just one
but it is beter to replace them as a pair just to be safe
they sit on top of the regulator
sometimes called hold and assist
or boost and assit
Oct 10, 2009 | Dryers
No Heat flown
there are a couuple of problems that would cause this.heating element bad or the hi limit thermostat has gone bad this is the most common failure.if you nees assitance and can look at the machine call me and it can tell you what to check 417-551-4311
Sep 16, 2009 | Kenmore 73952 Gas Dryer
I have a JC Penney dryer that is very slow drying cloths. The Igniter and Gas Valve are both working. When I turn the dryer on I can see the burner light but it only stays on for about 15 seconds before it...
HI, First thing you want to check is your venting to the outside. Make sure it is clean all the way out and that it is not pinch/kinked. Please let me know if I can assit you further.
THanks
Vic
May 17, 2009 | Dryers
Dryer won't run anymore
Hello opirono,
Please use the attached link http://www.pcappliancerepair.com/model-display.php
to show the details of your dryer.. In all probability, you smoked the thermal fuse and that needs to be replaced, Feel free to contact me if you need additional assitance,
Regards,
Rick
Dec 01, 2008 | Dryers
Light piolit
Hello dreas15
I need more information.
What's the model number.
How old is it? Today's dryers have electronic ignition.
Waiting for your response! I will respond right away!
Huuum
Sep 22, 2008 | Dryers
Whirlpool GGQ8831L Gas Dryer Logo
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
