Question about Maytag Neptune FAV6800AW Top Load Washer
Sometimes machine works other times it has a mind of its own
  • biggsrm Nov 19, 2009
    the room temperature I have the washer and dryer in, was higher than normal, that was causing a lr code now I leave the door open if I am running the dryer while washing clothes. but now the washer does not want to start when I push a wash button the time light flashes off and on then about 2mins the light go out and nothing happens. and the machine will not go into service mode.
  • FAV6800A FAV9800A
    FAV6800A FAV9800A May 11, 2010
    Hello biggsrm,
    I know you have the Service Manual form your “Locked Rotor” issue.
    If you can’t get into Service Mode then I feel the only fix is Control Board replacement.
    So will the machine let you into Service Mode? If so I would read the diagnostic code blocks and see what error events the machine has logged and we can go from there. Any surge protection on the 120VAC outlet that is powering the machine?
    What was the resolution of the LR error code on 10/2?
    Rich aka dh1200s
  • 526 Answers
Hello biggsrm,
I know you have the Service Manual form your “Locked Rotor” issue. What was the resolution of the LR error code on 10/2?
If you can’t get into Service Mode then I feel the only fix is Control Board replacement. Will this condition “mind of its own” allow you to get into Service Mode? If so I would read the diagnostic code blocks and see what error events the machine has logged and we can go from there if you want to DIY.
Any surge protection on the 120VAC outlet that is powering the machine? If the issue points to a Control Board failure and the 5yr warranty is up then I would search ebay for a used replacement Control Board. I have spares that have been verified good in my test FAV6800AW machine. If you wouild like to try let me know I’m in the 19344 area.
Good luck Rich aka dh1200s.
Posted on Nov 18, 2009
  • FAV6800A FAV9800A
    FAV6800A FAV9800A Nov 19, 2009
    It sounds like the Control Board became heat stressed. Not much choice here but to replace the Control Board and see if that will get you back in service. The Motor Controller set’s in the base/floor level of the machine. I hope if did not become heat stressed.
Creative 1472 sewing machine seems to have a mind of its own and the computer is doing different things each time it's switched on
Sounds like you are experiencing a computer glitch. Probably best to take it for service.
Aug 13, 2016 | Sewing Machines
Marantz bd8002
Hi
Some machines have a mind of their own. Take a look there.
Free User Manuals and Owners Guides ManualsOnline com
One thing though from my experience is that when I have pushed too many buttons some things may not work properly, then I disconnect and wait. Sometimes it helps,
kolbrun
May 24, 2014 | Saeco Odea Giro Plus Coffee Maker
Machine has filled up with water, has DE on screen, manouvered clothing & turned off twice.u
Hi Carol:
The "DE error code" is indicative of a Door Error. This indicates that the washing machine door is not shutting, locking or opening.
Here is a link to a service manual that should help you diagnose it. Keep in mind that LG models are sometimes difficult to diagnose.
VIsit this link: LG Washine Machine Service Manual
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Feb 11, 2012 | Samsung SW62ASP Top Load Washer
Used this machine 5 times and it now has no power, just dead!
If fuse in plug ok, Then the week spot is the wiring, Bear in mind the elements are in the top and bottom sole plate so stress faults can occur in the wiring between these plates. Also sometimes a thermal fuse may have gone, This component is usually hidden somewhere in the wiring.
pete
Nov 17, 2010 | Breville BGR400XL Sandwich Maker
Happily I don't have the dreaded F1 problem associated with many Kenmore Oasis HE machines. Maybe my problem is simple. Sometimes the buttons work fine but quite often you have to push them many times....
You need the board with the buttons, The board you need is called the user interface panel (board ) With a little patience you can easily swap this out your self, and the good news is that the part is cheaper than the machine control board for the F1 issue
Nov 01, 2010 | Washing Machines
Door locks have mind of their own
the fords are well known for the little motors inside the doors to freeze up and stop working!!
but since you say sometimes they work and sometimes they don't, could mean that your BCM is bad!!
(BCM= Body Control Module)
Jun 19, 2009 | 1997 Ford Explorer AWD
Brown, rust-like marks on washing
Hello I got a Bosch ClassXX5 and got the same problem, white clothes seemed Grey and some clothes seemed washed but not perfectly, until I discovered that the washing machine did not heat water anymore; after the end of the wash cycle the clothes were cold as the program was initially setup to 40C°.....
I used to think soaps were not up to the task and changed brand often, sadly a Bosch product letting me down was not on my mind, since that brand for me was above the rest, quality, strong, during in the time, having electric tools from Bosch without any problem for years!
Oct 11, 2008 | Bosch Classixx WFL 2066 Front Load Washer
Brother Intellifax 1270
There is a help menu on this machine. To print this out, just press the help button. To change the fax/tel ring, 1st have in mind how you want your fax machine to work. Do you have an a TAD connected? Do you want the fax machine to take priority over tel calls? The fax machine seizes the line after the set number of rings, that means any other device connected to other phone outlets, will not answer after the fax has answered. Have this in mind when you set the ring time. The TAD will have it's own ring time too.
Feb 29, 2008 | Brother IntelliFAX 1270E Plain Paper Fax
Gathering foot Not Gathering.
check the amount of pressure on foot, it might be too much for the type of material, that sometimes makes it gather
Jan 20, 2008 | Brother 1034D Mechanical Sewing Machine
Maytag Neptune FAV6800AW Top Load Washer Logo
89 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
