Question about Kenmore Elite 45986 Front Load Washer
The Rubber seal came out and a metal ring came out with it. I got the rubber seal back in,but the I'm not sure about the metal ring. It looks like it's got a little spring thing on the bottom of it.
  • 5,911 Answers
The rubber seal you are referring to is called the bellow. It seals the front of the wash tub to the door frame. The wire hoop is the front bellow clamp. If the bellow is not damaged, you can reinsert the clamp by following these steps:
1. Install the bellow back over the frame of the door opening ensure you fit it snugly all the way around the opening.
2. Beginning at the top of the door, start inserting the wire hoop back into the groove that is in the rubber fold of the bellow behind the door opening.
3. Make sure to wire spring points towards the 6 o'clock position and begin inserting the wire hoop into the bellow groove.
4. As you work your way around the door to the 4 and 8 o'clock positions, you will need to maintain some constant downward pressure while pulling the spring apart in order to snap it back into place.
It may be advisable to use a second set of hands to hold the wire hoop in place while doing this as it has the tendency to want to come out of the groove.
If you inspect the bellow and it is ripped or torn, you will need to replace it or the washer will leak. The following link explains how:
http://www.fixya.com/support/r385210-replacing_door_bellow_kenmore_elite
Read through the link provided and let me know if you have any questions.
NOTE: There is another method you may try as well. Although I do not prefer this next method because these washing machines are very heavy, an alternative way of replacing the door bellow is to remove the lower toe panel and tilt the washer back at a 45 degree angle instead of removing the washer front panel. If you use this method, make sure it rests against the wall and will not tip forward. This allows the wash tub to drop down and away from the front panel and gives you access to the the rear bellow clamp through the bottom. This can save you some time. Thanks to user DGBG for the helpful tip.
If you would like some helpful exploded view diagrams of your washer that you can reference, you can use any of these web sites:
searspartsdirect.com
appliancepartspros.com
pcappliancerepair.com
Just use your model number to begin your search criteria.
If you have any questions, please let me know. I hope this helps you.
NOTE: These door seals do wear out and require replacement from time to time. However, overloading the washer to the point where items get caught in the door area can contribute to premature wear and tear.
Posted on Nov 18, 2009
Thank you for this tip! What is the six o clock position of the wire ring?
Posted on Jan 12, 2013
Replaceing high pressure power steering hose on 1978 chevy trk.where exactly do the o rings go?
On each end of hose, metal ends, just below nut. There is a small indent for the O-rings. Make sure the old O-rings are not still in the pump and gear box fittings.
May 06, 2017 | Cars & Trucks
Can the metal ring that retains the rubber door seal be replaced by a simple wire?
Hi,I have replaced these rubber seals,the front ring shouldnt give you much trouble its the inner one thats the pain,I woulnt use wire as the one thats on it is sprung loaded.
Ive also had to replace the door latch on a washing machine,what I did was take the top off and reach inside,maybe thats an option,or the other way is to put the machine on its side and go in through the bottom.
I hope this was some help,all the best.
Jul 16, 2015 | GE GFWH2400LWW Front Load Washer
I have a thermos 1 liter flask. I was washing it the other day. The glass part was our of the flask and a rubber seal came off but I didn't see where the seal came from. Please can you tell me where do I...
There is a rubber ring on the bottom of the glass and it holds the glass flask in place in the metal body.I wonder if this is what you describe as a seal.When you put the glass back in its body it should push up to a ring seal at the top.If that is there then I am sure it's the shock ring at the bottom.
Jul 07, 2014 | Washing Machines
Rubber seal has come off and cannot get the metal ring back on to tighten the seal back. Any suggestions on how to do this.
You will need to stretch the metal ring a bit. Once stretched make sure to shape in a circle again. Using two screw drivers and two pair of hands pull the metal ring back around the gasket. It is a real pain to do, but can be done. Make sure that the spring is located at the bottom of the rubber gasket. I'm sure that they make a special tool to do this, but this worked for us and washer still works fine.
Nov 17, 2010 | Bosch Nexxt 300 Series WFMC2201UC
Inserting loose rubber seal on front load washer
you can try holdthe one side and use a screw driver on the other end try to put the rmetal ring in the gasket. is batter if you have to persons...
Apr 10, 2010 | Bosch WFMC2100UC Nexxt Essence Washer
Wire ring that holds rubber seal on next 100 washer has come off
Bosch Nexxt 100 Series WFMC1001UC Front Load Washer how to put back on wire ring, with a spring for tension, that holds the inner rubber seal in place.
This video will show you how to change a door seal on this Bosch front loader washing machine and also how to get back on, the metal ring around the seal.
we have all bosch repairs in our channel.
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 24, 2009 | Bosch Nexxt 100 Series WFMC1001UC Front...
Kenmore HE 110.4751 front load
soild metal part fits in groove around door boot spring goes in at bottom they can be tough to get back on after inserting in groove around seal you'll have to stretch the spring and pop it under at the same time band will try to come back out and roll seal back off lip..good luck
Jul 16, 2008 | Kenmore Elite 45986 Front Load Washer
Metal ring aroound rubber seal fell off.
Start with the spring at the bottom, work the retainer around until the seal starts to pull away from the washer. Now grip the loop that the spring attaches to on the side that isn't in place and open the retainer. Push the retainer in place and release the spring.
Jan 09, 2008 | Bosch Nexxt Premium WFMC6400UC Front Load...
Kenmore Elite 45986 Front Load Washer Logo
391 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
