Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Chamberlain Liftmaster Sensor Problem
Lately the sensors on either side of my garage door have been randomly going out. Of course, the door will not close and I end up manually opening and closing it. Then, magically, 2 or 20 or 200 minutes later, the lights come back on and it's business as usual. Today it happened again and after messing with it for awhile and being late for work, it apparently still doesn't work. WTF?
Any help would be appreciated.
Thanks, Jason
    President:
  • 4,402 Answers
I think it time to replace the logic board
http://www.chamberlain-garage-door-openers.com/circuitboardcompatibilitychart.htm
Posted on Jan 10, 2008
Why does dooropener lights blink when butten is pressed
could be something blocking the sensor . My sensor on the floor on one side was blocked by a spider web holding a leaf in front of it. My door light would flash and door not go up or down. After i cleaned both sides every thing worked ok.
Jul 01, 2016 | Sears Craftsman LiftMaster Chamberlain...
I have the chamberlain garage door opener. the door will not shut. the door travels to about 8 inches above the floor and then reopens. the door is just over one year old and has worked well up...
The sensor colors are correct. Try wiping the little eye sensors that point at each other for one thing and make sure there isn't something protruding from door that's coming into the patty of electric sensors.
Mar 14, 2011 | liftmaster Chamberlain Garage Door Opener...
I have a chamberlain liftmaster professional Formula 1 Garage door opener that has been working for 5 years. Now will not go down unless you hold the main button. Sensors blink when it hits within 3...
Anytime the main light flashes 10 times and the door reverses to the open position it is a door sensor problem. They each have a small light that should be lit, both should be the same brightness and not flickering ever so slightly. If not tweak them a bit. If both lights will not come on you have bad sensors.
Sep 27, 2010 | Sears Craftsman LiftMaster Chamberlain...
Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+: replaced photoeyes but the lights on them are not ...
Check the wiring going to the sensors and make sure they are connected correctly at the motor unit. The solid white wires from each sensor go to terminal 2 and the wires with the black tracer go to terminal 3.
May 18, 2010 | Sears Craftsman LiftMaster Chamberlain...
Sensor lights blink contineously on one side and
Tweak the sensors so that they are pointed at one another. This should stop the blinking and the door should close.
Jan 01, 2010 | Sears Craftsman LiftMaster Chamberlain...
Chamberlain Liftmaster bounces back up sometimes...
On the side of the motor unit you will find the 'down limit control'. Using a small screwdriver turn this control in the opposite direction of the arrow printed on the cover. Some tweaking will most likely be necessary. You can remove the cover and watch the limit switch assembly and get a good idea how it works.
Sep 30, 2009 | Sears Craftsman LiftMaster Chamberlain...
Liftmaster 41A5389 won't shut
it has to be aligned with its mating optical sensor on the other side of the door. try adjusting it until you get a green light.
Aug 22, 2009 | Sears Craftsman LiftMaster Chamberlain...
Chamberlain garage sensor
IF YOU HAVE THE INSTRUCTIONS THAT WILL TELL YOU WHAT TO DO OR GO ON LINE TOO THE MFG AND I BELIEVE YOU CAN GET INSTRUCTIONS FROM THEM.
Jan 25, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage Door Opener Intermittingly Reversing
try adjusted the sensor controls on the sode of the unit other wise replace the logic board
Dec 24, 2007 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
730 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
