Question about LG DLE5977 Electric Dryer
Need to know how to remove drum on LG model DLE5977W
  • LG Master
  • 8,404 Answers
Try this: Most dryers tops are held in position with a spring clip(s). Pop the top up being careful of the finish.
You will soon discover the process for holding the front panel on --- generally spring clip(s) or screws or tabs or combination thereof.
Be careful of the door safety switches and wires.
The drum should come free of the dryer as you remove the front panel
I hope this answers your question
Thanks for using FixYa.com
Pleased vote
Positive comments welcome
thank s
a
Posted on Dec 06, 2009
3 Suggested Answers
SOURCE: LG Dryer cracked drum on
Thanks for the solution. I figured out how to remove the drum the other day. Since this is a ongoing problem with the drum i figured a new one is going to fail someday so i took my cracked drum to a weld shop and had them tack weld in a few locations (inside and outside) and fix the crack at the seam. My cost was $30. I installed it and it seems to be working great.
Posted on Apr 02, 2009
hunter19_46m
  • 7482 Answers
SOURCE: Thumping sound from loose drum
Your problem sounds like drum rollers have flat spots on them or in need of lubrication.
If you have a front loading machine, Unplug the dryer, remove the front of the dryer. This will expose the drum and belt, remove the drum and belt and this will expose the drum rollers.
Check your rollers for flat spots, if they have flat spots on them replace them.
If they don't then they probably only need lubrication. Lubricate the shaft of the roller with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve you noise problem.
Good Luck,
I hope this helps
Posted on Oct 11, 2009
My Lg tromm dle5977w is knocking
broken, worn drum roller? there are four of them.
Jul 06, 2014 | LG DLE5977 Electric Dryer
My lg tromm dle5977w dryer check filter light stays on and drum wont turn just makes humming noise
If the drum will not rotate then the drive belt is broken and should be replaced
May 26, 2014 | Dryers
LG DLE5977W electric dryer hums when attempting to restart
This is usually the motor but not always. Remove the belt. Check for obstructions in the blower fan housing. Manually rotate the shaft of the motor.
If the motor is very stiff, or impossible to rotate manually, and the blower fan housing is clear, you need to replace the motor. If the motor rotates freely, run the motor momentarily with the belt removed and the blower in place. If the motor runs fine with the belt removed, there may be a problem with the idler pulley or the clothes drum. Try to rotate the drum by hand. If it is very difficult to move, correct any problem with the rollers, pulley, rear bearing, then reassemble the dryer and try it again. If the motor hums but doesn't rotate on its own even with the belt removed--yet you can turn it freely by hand--you usually need to replace the motor or the motor start capacitor. You can also enter your model # for diagrams and illustrations at www.appliancehelponline.com
Mar 31, 2010 | LG DLE5977 Electric Dryer
I have a LG dryer dle5977w and it has started making a rattling noise it is coming from the bottom left side by the lint fan does any one out there have a idea of what it might be
May be a small sock or dryer sheet caught in the blower wheel.
Remove filter and use a flashlight to see down the filter housing. You may be able to see item.
Rotate the drum each way by hand to help see item.
Remove with hooked wire hanger.
You may need a service call to remove object.
Jan 04, 2010 | LG DLE5977 Electric Dryer
Good Luck,
I hope this helps
Oct 10, 2009 | LG DLE5977 Electric Dryer
Dryer DLE5977W washer WM2277HW just bought used ones no operating manuals help need one for each piece where do i get them
Follow the links below with Internet Explorer ONLY, opening these files may require the free download of additional software for viewing:
WM2277W Then Click on English Manual
DLE5977W Then Click on English Manual
Aug 28, 2009 | LG DLE5977 Electric Dryer
Felt has come off drum DLE5977W
you can't take the back of the dryer off you must take off front pop the top remove the the front take out drum and belt replace felt. Replace drum belt front and top thank you for useing fixya please rate me
Feb 10, 2009 | LG DLE5977 Electric Dryer
LG DRYER MAKING CLUNKING NOISE
Look inside the drum at the seam, front and back side. The weld on the stainless steel drum may have cracked. You would need to replace part number 3045EL1002F. It is moderatly difficult to replace.
Oct 16, 2008 | LG DLE5977 Electric Dryer
Install dryer belt on a lg
You will need to remove the front panel and the front drum support to get to the belt.
Mar 24, 2008 | LG DLE5977 Electric Dryer
LG DLE5977 Electric Dryer Logo
215 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
