Question about Dacor Preference RSD30 Gas Kitchen Range
Dacor range will no unlock after self-clean mode. It is beeping with an f8 message
  • 187 Answers
Try to reset the oven cleaner- set it to go off in five minutes and the lock should release at the end of the cycle. Also, ake sure you didn't accidentally set a child lock or delayed cleaning. If that doesn't work, go to your breaker box (or unplug it) and shut the power off. It should reset the electronics. If this does not work, please leave a comment telling me what kind of oven it is, manufacturer and model, and how it is powered, etc. thank you for your question.
Posted on Nov 18, 2009
  • yona21 Apr 17, 2011
    it is still lock what should i do
-F-3 error message on stove
F-3 is open or shorted temp sensor probably due to using self cleaning mode, temps in self cleaning mode on some brands and models can reach upwards of 1000 F. replace temperature probe, and if problem ensues replace clock\control.
May 09, 2012 | Crosley Kitchen Ranges
Dacor Preference RSD30 Gas Range My wife put the
I don't see the make and model number of your unit. I only see part of your post. Please post the make and model number. It should be a simple fix. From what I do see in your post, it sounds like the control board will need to be replaced.
Regards,Richard
Oct 17, 2011 | Dacor Ovens
Error code F8 keeps coming up. I was trying to run the self clean program and it wouldn't work. Now error code keeps coming up regardless of what mode oven is in
Hi vicktys,
The error code F8 that you are getting from your machine means that there's something wrong with the door locking switch. You need to check if there's any loose wiring as well as the door locking switches. If the wiring is fine you might need to replace the door latch assembly.You may contact Sears for the replacement part at 1-800-252-1698; M-F 6:30 AM-10:30 PM - Sat 7:00 AM-9:30 PM - Sun 7:30 AM-9:30 PM - All times Central.
Hope this helps.
Thank you for using FixYa.
Nov 22, 2010 | Dacor Epicure ERD30 Dual Fuel (Electric...
Self Cleaning NOT working and Locked itself...and BEEPS NON STOP
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Asker's Testimonial " Thanks for this! I did not realize self-cleaning was so bad for the appliance2_bing.gif. Fortunately, I hardly ever do it! " - sej51
Apr 20, 2010 | Dacor ER36D Stainless Steel Island Trim...
F8 error message on Dacor gas range
Look for the error code in the troubleshooting section of the owner's manual. Otherwise, search for:
Make Model error code F8
Sep 29, 2017 | Kitchen Ranges
Oven lock will not open
my self cleaning oven door will not unlock what do I need to do?
Jan 01, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Dacor ERD36SCH/H will not self clean
Door lock motor suonds like it is bad. Not an easy part to replace. You may need a technician.
May 12, 2008 | Dacor Epicure ERD36 Dual Fuel (Electric...
F1 error code, continual beeping all other oven functions work properly
Here are the error codes for Dacor:
DACOR
Range/Stove/Oven Fault Codes Failure
Code
Condition Check/Repair F0 Clock pushbutton is stuck in a depressed position Check clock buttons F1 Element relay circuit failure Control board may be bad F2 Oven temperature exceeded the clean runaway temperature (self clean only) or the cooking runaway temperature (cooking modes only) Call for service F3 Short Circuit in the oven temperature sensor Check oven temperature sensor for continuity, if no resistance (zero ohms), replace F4 Short Circuit in the oven temperature sensor Check oven temperature sensor for continuity, if no resistance (zero ohms), replace F6 Failure in the EEPROM check comparison (only time of day and timer will operate) Call for service, electronic clock control is usually the cause of the problem F7 Failure of the self- clean automatic door latch system Check door latch and switch(es) F8 Failure of the door latch motor. Occurs when the motor runs for two minutes without the door locking in self-clean mode Check door lock motor and door latch
Nov 08, 2007 | Dacor Epicure ERD30 Dual Fuel (Electric...
SELF CLEANING DOES'T WORK
"F8" ERROR MESSAGE. This indicates a door latch failure.
Jun 25, 2007 | Dacor ECS130 Epicure Electric Single Oven
Dacor Preference RSD30 Gas Kitchen Range Logo
580 people viewed this question
Top Dacor Kitchen Ranges Experts
Dan Webster
Dan Webster
240cpa
Jaime Hernandez
Are you a Dacor Kitchen Range Expert? Answer questions, earn points and help others
