It takes my electric over a long time I think to
It takes my electric oven a long time I think to reach the set temperature. For example, it takes 20 minutes to reach 350 degrees. Isn't that too long?
  • 187 Answers
That is a long time, but please give more information on what type of oven you have, and how old it is if the following does not solve your problem. First, Make sure you have not covered the bottom of the oven with any type of barrier to keep the oven clean (aluminum foil or inserts), it blocks the vents. If it is an older convection oven, preheat on bake and set the convection after it has preheated. Check the elements. Lift up the bottom panel and do a visual check of the element. Take out the bottom panel and turn the on oven on somewhere near 450-500 degrees. Visually inspect the element and see if there are bright red areas and dull areas. If the element has red hot areas and dark areas, you need a new element. If the element does not get red at all, you need a new element. Electric ovens usually have an upper and lower element, so you should check both before replacing one. The broiler element should be visible without removing anything, just look at the top of the oven after you set to broil. Lastly, make sure the oven door shuts snugly and that any gasket around the door is in good condition. If you don't know if the door is tight enough, just lean up against it to see if it preheats more quickly. The oven also has a temperature sensor, but from your description, that would not be the case because you did not mention trouble maintaining the temperature.The good news is that elements are usually cheap and easy to replace. Try to find your owners manual, it will tell you what part you need. If not, write down as much info on your oven that you can and take the element with you to the parts store. If this is not helpful, leave comments with more information and I will attempt to solve your problem. thank you for your question.
Posted on Nov 18, 2009
Why hasn't the oven reached the set temp when the buzzer sounds indicating desired temp has been reached?
What are you using to measure the temperature of the oven? If you using a typical round oven thermometer, the reason is that your thermometer response is slow. It takes about 20 minutes for those thermometers to reach and display the actual temperature, and your oven is probably reaching it's set temperature in about 10 minutes. You really need an electronic thermometer or at least one of those liquid thermometers which you can sometimes find at Ace Hardware or True Value Hardware stores.
Apr 29, 2015 | Kenmore Kitchen Ranges
Oven Switching Off
I have a few questions. Does the oven reach the set temperature? How do you get it to go back on? and if you do not set the time do you have the same problem?
Dec 06, 2007 | Electrolux EOB6632 Electric Single Oven
Why is the oven bell not ringing when it reaches the set temperature.
If the temperature reached at it operating temperature and oven display doesn't showing how much time left for ready screen then most probably its IO board gone.
I have seen many cases like this, and replacing IO Board fixed the problem.
Please rate my work
Thanks
Sagar
Sep 19, 2014 | TurboChef TORNADO Electric Oven
On a Frigidaire Gallery oven, it takes forever for the oven to heat to the set temperature. 20-30 minutes. This seems like a very long time. Once it reaches the temperature the oven temperature is fine,...
Replace the door seals, they are the thin rubber strips around the front of the oven when the door is open. They are simple to change as they just clip on.
Jun 26, 2014 | Hotpoint RGB745 Gas Kitchen Range
Oven will not preheat
You have burned out element(s). Lowering the wattage, therefore increasing the time it takes to reach set temp,
Apr 05, 2010 | GE JBP66 Electric Kitchen Range
My oven won't reach temperature all the time. it
It is adjustable. Pull off the temperature knob behind it you will find the adjustment to raise or lower the temp. You will need an oven thermometer to test after you adjust.
Sep 30, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
How do I calibrate the oven temp?
Oven Temperature Adjustment Option for the MSG5770
If you think the oven should be hotter or cooler, you can adjust
it yourself. To decide how much to change the oven temperature,
set the temperature 25°F higher or lower than the temperature
in your recipe, then bake. The results of the “test” should
give you an idea of how much to adjust the temperature.
To adjust the oven temperature:
1. Press the BAKE pad.
2. Enter 550° by pressing the number pads “5, 5, 0”.
3. Press and hold the BAKE pad for several seconds until 0°
appears in the display.
4. Press any number pad to change the temperature. Each time
a pad is pressed, the temperature changes by 5°F.
• Press repeatedly to reach +35°F. Continue pressing
to reduce the temperature up to -35°F.
• If the oven temperature was previously adjusted, the
change will be displayed. For example, if the oven
temperature was reduced by 15°, the display will
show -15°.
5. When you have made the adjustment, press the
CANCEL pad and the time of day will reappear in the
display. The oven will now bake at the adjusted
temperature.
NOTE: Do not change the temperature setting more than
10° at a time before testing the oven.
It is not necessary to readjust the oven temperature if there
is a power interruption. This adjustment will not affect
broil or clean temperatures.
Feb 08, 2009 | Maytag MGS5770 Gas Kitchen Range
How to set the timer
1. Set the oven to the required
temperature.
2. Press the g button.
3. Set the total cooking time with the +
button (see the example in the
illustration right, showing 1 hour and
30 minutes).
4. Press the h button.
5. Set the cooking finish time with the +
button (the example in the illustration
shows 12.30 hrs.).
After setting the display shows the
time of day and indicates »AUTO«.
The oven cooling fan will start
immediatley.
At the pre-set time, the oven will be
automatically switched ON.
The settings can be corrected at any
time.
When the pre-set cooking finish time
is reached, a signal sounds and the
oven is automatically switched OFF.
To turn the signal off, briefly press the
h button.
6. Turn the oven selector switch to the
0 position.
7. The »AUTO« symbol blinks.
Important: It must be switched OFF
by pressing the E button.
Also here is the manual.
https://portal.bsh-partner.com/portal(bD1kZSZjPTAwOQ==)/PORTALFRAME.HTM
Good Luck
Jan 20, 2009 | Neff U1721 Double circotherm Electric Oven
Preheating Oven
Cold Stove, you may not be able to. The issue here is that oven manufactures put on their units a fast preheat. However it isn't possible to preheat an oven for 7 to 9 minutes and bake short time bake items properly. Also the oven sensor will respond faster than the absorbation rate of the sheet metal in the oven liner. To preheat an oven properly takes 15 to 20 minutes before putting in the food. I see this will a lot of current ovens. Sounds like a normal format of the control.
Feb 03, 2008 | GE JBP24 QuickClean Electric Kitchen Range
GE XL44 Oven Temperature Issue
Have you tried replacing the bake ignitor yet?
Dec 06, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Computers & Internet Logo
50 people viewed this question
David Payne
David Payne
