Question about RCA Televison & Video
No filement on rca f36669 pix tube
No filement on rca f36668 pix tube
    Scholar:
  • 63 Answers
I assume you have either looked into the rear cover, or removed it. The worst case scenario is an open heater (filament) in the crt itself although this is not real common. If you can use an ohmmeter/continuity tester you can see on the crt pc board which pins are the filaments. Pull the socket off and check for low resistance between these two crt pins if low then odds are the filament is ok. The next thing is to check the solder at the filament connections on the crt board as often you will find "ring cracks" around them and they need re-soldering. The filament circuit is supplied from the IHVT (flyback). Generally with the socket unplugged from the tube you should find low resistance across these two connections also. You read back through the transformer winding if it is ok. If it tests open you may have an open fuse resistor or a bad solder connection at the flyback. The filament (heater) terminals are usually labeled on the main board at the transformer.
Posted on Nov 19, 2009
Can't find a service manual for an RCA f36668
Send your email address to me by Fixya, and get back a copy of it by return mail.
Dec 27, 2012 | RCA F36668 36" TV
My universal remote can't be used to turn speakers back on my f36669 tv
Not a surprise as Universals even if they program will be missing key and needed features.
Oct 31, 2012 | RCA F36669 36" TV
I have an RCA F36669 tv that doesn't stay on.
look to see if the wire is in tv. unplug there 28000 volts there and it hurt use a long handel sew drive to find out unplug tv
Jul 08, 2010 | RCA F36669 36" TV
My rca model f36669 makes a popping sound and cuts off and back on
That's hi voltage arcing. Dangerous condition were a component has broken down and is arcing causing the power supply to 'crowbar' or go into over current protection mode. Call a TV repair pro for an estimate to see if you want to keep the set.
Apr 26, 2010 | RCA F36669 36" TV
NO COLOR IN MY RCA F36668 TV
Could be a bad TV or it could be loose TV connections feeding to the back of the TV. Any poor or loose connections in the cable leads causes a loss of signal strength to the TV.
Old cables and connection supplying TV Cable to the house or apartment can cause this problem also.
Dec 05, 2008 | RCA F36668 36" TV
Color is all red - picture hard to see
Bought a new TV since it wasn't worth it to fix the old one.
Aug 30, 2008 | RCA F36668 36" TV
Where can I get the part?
Take your board to the local TV repair shop. They will be able to replace the individual micro switches and save you a small fortune replacing the whole control board.
Apr 13, 2008 | RCA F36669 36" TV
RCA CTC203
with your new flyback transformer ther should have had a resistor and cap in the kit.if you look at the fly back from the rear ,on the right side very close to the transformer.and on the other side 3 resistors one has changed value about 38k-ohm.
Mar 28, 2008 | RCA F36669 36" TV
Need new panel
the control panel,possible a bad component on it like a stuck switch ,remote p/u sensor
Mar 01, 2008 | RCA F36669 36" TV
RCA 32" TV - Model #32F531T - Faded to black
Isolate filament voltage from CRT,i.e. unplug Crt socket from pix tube.Measure filament voltage on CRT PCB.If present,suspect bad pix tube.If missing,solder any/all connects in filament circuit,meaning CRT board first then main PCB.
Aug 08, 2007 | RCA 32F531T 32" TV
Televison & Video Logo
56 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
