Services and controller app has encontered a problem and needs to close
    President:
  • 2,185 Answers
What particular service and controller app are you trying to run but having problems with? What OS are you using, windows xp or vista?
Posted on Nov 18, 2009
Why is my Samsung s5 overheating
1. Screen Brightness (auto best)
2. Location Services
3. If you don't need it turn off wifi
4. Turn on power saving mode
6. Make sure bluetooth is off
7. Close all apps except the one your using
8. Use apps that can disable autostarting apps
Jun 03, 2016 | Samsung Cell Phones
Macromedia projector problem
Right clicking on the desktop shortcut to the software, go to "Property", click on the "Compatiblity" tab and put a check in "Run this program in compatiblity mode for:, now try all the choices in the dropdown box (win95, win98/win me,etc. etc) one at a time til it works. Hers work when I selected Windows Nt 4.0 service pack 5. Hope this works
Jul 05, 2008 | HP Media Center m7060n PC Desktop
05 mustang gt codes po 2104 and 2112 replace tcm and tps
P2104 - Throttle Actuator Control (TAC) System - Forced Idle Description: The TAC system is in the failure mode effects management (FMEM) mode of forced idle. Possible Causes:
  • Open or short in multiple accelerator pedal position (APP) sensor circuits.
  • Damaged APP sensor.
  • Damaged powertrain control module (PCM).
Diagnostic Aids: This DTC is an informational DTC and can be set in combination with a number of other DTCs which are causing the FMEM. Diagnose other DTCs first. Application Key On Engine Off Key On Engine Running Continuous Memory All
P2112 - Throttle Actuator Control (TAC) System - Stuck Closed. Description: This powertrain control module (PCM) fault status indicates the throttle plate is at a lower angle than commanded. Possible Causes:
  • Binding throttle body, stuck closed.
  • Damaged PCM.
Diagnostic Aids: Application Key On Engine Off Key On Engine Running Continuous Memory All GO to DV1 Are you familiar with electronic throttle control ? You have a dc electric motor on the throttle body an at the gas pedal there are APP pedal position sensors that send voltage signals to the PCM which in turn controls the electric motor opening an closing the throttle ! By what this P02112 states the throttle plate is binding , which means it could be bad or just needs to be cleaned ! You will need to disconnect the electrical connector an see if it is binding by pushing it with finger or thumb . which is ever easiest !
GO to QE1
Apr 08, 2015 | 2005 Ford Mustang GT
How do I get rid of one gmail acct??
From the Google forum:
https://productforums.google.com/forum/#!topic/gmail/enuR5sA8qLw
How do you delete a Gmail account?
If you'd like to close or delete your Gmail account then you can do so by following these instructions:
Visit this page after signing into the account you would like to delete Gmail on: https://www.google.com/accounts/b/0/EditServices
You will have two options:
a) "Remove Gmail permanently": this removes the Gmail service but keeps any other Google services (Calendar, Drive, Blogger ...). All your emails and contacts are deleted permanently. You need to specify a non-Gmail email address as your new login for other Google services that you log into. If you want to delete or close your Gmail account but still use other Google services like Google Drive, then this would be the option for you.
or
b) "Close account and delete all services and info associated with it": this removes the whole Google account including all services that you used with this login (Youtube, Picasa, Blogger ...). This step is irreversible and you can never use the same username again. If you want to delete or close your Gmail account as well as any associated services with your Google account then you would choose this step.
If you are a Google Apps user (aka your email address is through Google but does not end in @gmail.com), then you will need to contact your organization's Google Apps administrator who will follow the procedure here for removing your address from the Google app domain: https://support.google.com/a/answer/33314?hl=en
We're sad to see you go! If you have recommendations on what would make the product better, you can submit it by clicking the gear icon in the upper right hand corner of Gmail and selecting "Send feedback"
Jan 31, 2015 | Computers & Internet
We cannot find closed caption
Do you have the X1 service? If yes, then hit Xfinity button and scroll over to settings (looks like a gear to the right of "Apps". Then go to "Device Settings". You'll see it there.
Sep 27, 2014 | Panasonic Televison & Video
Can Badoo mobile app turn on when someone sends you a message and would look like you had been on line in the app
you have to actually turn off the app services from running in the back ground. Badoo is an app which runs on the background even iff you close the app window itself. If you go to Settings.>Apps> Running apps, you will see its still running. If you select the app and stop the running services you will then be offline.
That is why its important to read the app service agreement before you download. it will tell you if the app has a service like this ahead of time. These services also affect battery life.
Jul 12, 2014 | Cell Phones
Volume control won't go away. Windows 8
right click on it, click settings and turn off start automatically. then right click on it again and click close.. Its a service that comes with the software, there are other ways to disable it but that's the simplistic one..
Dec 27, 2012 | Lenovo Computers & Internet
Everytime i try to log in to facebook it wont let me and says internet explorer has encontered a problem and needs to close
you can use mozilla fire fox browser also but for permanenet solution for this error you can repair your windows operating system or try by running chksak command in run window.
Nov 16, 2009 | E-Machines eMachines T3830 PC Desktop
Saitek 380 does not work properly with xp sp3
a lot of games need the xbox 360 controller i have encontered the same problem and i just use a xbox 360 controller
Mar 29, 2009 | Computers & Internet
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
