Question about Samsung HLP5085W 50" Rear Projection HDTV-Ready Television
I have samsung hl-p5085w and the bulb shuts off i turn the tv right back on and it works for like 40 mins and does it again any thoughts?
  • 336 Answers
Hi,it sounds like your lamp is going bad,its symptoms are : will shut off and on,led indicators.The lamp on your set last 6000-8000 hrs 2--3 yrs and its made by Philips .Found it here: http://www.discount-merchant.com/Samsung-BP96-00677A-OEM-Replacement-LAMP-BULB-p/samsung-bp96-00677a-lamp-oem.htm?Click=48173 If you've replaced the lamp before it might be the board that powers it ,it's called the ballast.Good luck nad God bless you!
Posted on Nov 18, 2009
Samsung hl-s5087w.... Tv is 4.5 years old, and is about 200 hours into its 3rd bulb. Yesterday, very similar to when the bulbs burnt out, it shut off. I thought that it may be getting too hot, so after it...
Above the light is a temp sensor with a blue and white wire plug. This sensor is the problem for all these shut downs in my opinion. Pull out plug and jump it with a wire or paper clip bypassing sensor. Tv should work now!!!!
Apr 23, 2011 | Samsung HL-S5087W DLP TV
I try to get tv 50" Samsung HL-P5085W i want to know if this kind of tv works good
Yes. This is a good set. Picture is good. But keep in mind that Samsung no longer makes this set and stopped making DLP tv"s. Parts are dwindling.
Apr 09, 2010 | Samsung HLP5085W 50" Rear Projection...
My samsung hl-p5085w is humming all the time and
Samsung is known for bad color wheels and for what you describe it surely sounds like the color wheel bearing if going out on you,you will need to replace the color wheel you can find more help @ fixyourdlp.com and if you want to buy the part you can find it @ http://www.discount-merchant.com/SearchResults.asp?Search=color%20wheel?click=52978 or @ http://www.samsungparts.com/search/search.asp , just so you can be 100% sure you will need to get the part number from the actual color wheel that you already have,
Please rate this if it was helpful,as a do this for free
Regars
Jan 04, 2010 | Samsung HLP5085W 50" Rear Projection...
HL-R4266W shuts down and a faint clicking sound can be heard
I believe I read somewhere that when you open the back cover over the lamp, there is a special little black switch that needs to be in the up position when you put the cover back on, or the TV can shut itself off randomly.
Aug 16, 2009 | Samsung HL-R4266W 42" HDTV-Ready...
Our Samsung HL-P4663W DLP is makes noise and shuts off
It is the color wheel, inside the light engine. The bearings get dirty and makes it harder for the wheel to spin causing that whin.
Jan 06, 2009 | Samsung DLP HL-P5663W 56" TV
SAMSUNG TV MODEL HLR5067W
Sounds like the lamp to me. The projection lamps get hotter as they age and the TVs have a sensor to monitor the temp and shutdown the TV if it get too high
Projection TV makers charge an arm and a leg for their replacement lamps. They make it easy to do but as a result the custom lamp assy is expensive. The trick is to buy just the bulb for your model TV from any number of us aftermarket sources at a fraction of the lamp price and install it in the old lamp yourself. Really easy.
Jan 05, 2008 | Samsung HLR5067WX 50" Rear Projection HDTV
T.V. turns off unexpectedly
there may be some problem in the power device section on the main board.......the power ic`s will not be functioning well due to heating
Jan 02, 2008 | Samsung DLP HL-P5663W 56" TV
Samsung HLP5085W 50" Rear Projection HDTV-Ready Television Logo
306 people viewed this question
Jerry Greenberg
Jerry Greenberg
