Question about Maxtor 160 GIGABYTE USB2.0 EXTERNAL STORAGE 7200 RPM 8MB CACHE RETAIL 160 GB USB 2.0 Hard Drive
Computer won't recongize my Maxtor one touch - Maxtor 160 GIGABYTE USB2.0 EXTERNAL STORAGE 7200 RPM 8MB CACHE RETAIL 160 GB USB 2.0 Hard Drive
    President:
  • 2,185 Answers
If plugged in the first time, the external drive needs to be initialized from your computer. Here are the steps.
1. Plug in your external drive to your computer's usb port.
2. Right click your My Computer and choose Manage.
3. Click on the Disk Management from the left. The list of available drives will show on the right.
4. Right click on your External drive and select create partition (primary partition).
5. After that you now you need to format the hard drive. Choose quick format.
6. Right click again on the partition you've just created, now select "Format" and select NTFS.
7. Click Ok and follow the wizard as it will guide you until it is finished.
Hope this helps.
Posted on Nov 18, 2009
  • 979 Answers
Hello sir, hi and good day, there are several reasons why an external drive cannot be recognize by the PC, here are some possibilities:
  1. Compatibility issues, make sure your PC is USB 2.0.
  2. Defective USB cable.
  3. Bad USB port, check other USB slots if it works.
  4. incorrect device driver, well most USB devices are ready for windows, but check if there is a CD accompanied with your USB drive. If there is a CD, run the device driver.
  5. Your PC is too old, like running on windows ME, atleast you are/or should be using windows XP.
  6. USB port is not enable on the Bios setup.
  7. Your MAXTOR device itself is bad, so check it on other PC to see if it will work.
If things are still out, try cleaning or running an Antivirus software on your PC. call your dealer for information on the installation of the product.
My vista computer doesn't recognize my maxtor one touch 4 external harddrive...it doesn't recognize it on my xp either how can I fix this...I have a lot of stuff backed up on this and it is less than a...
HI,
What I would suggest, is to take the drive and install it as a slave drive. Make sure your pin settings on the drive are set to slave, and your main drive is set to slave. Then XP and Vista will recongize it so you can pull the data off it, then reformat the drive and see if you get any errors.
Good Luck
Mark
Oct 27, 2009 | Maxtor Hard Drive
My maxtor one touch iii is being recongized on the USB port the driver shows its good and everything shows its working properly, but I don't hear the drive spinning and when Windows XP recognizes the drive...
reseat cables to make sure the connection is solid and try connecting to a different usb port on the computer or try connecting it to a different computer. If you still can't see the drive after that, it's probably gone bad.
Oct 03, 2009 | Maxtor Hard Drive
My computer no longer recognizes my Maxtor One Touch III Firewire 400/USB 2.0
go to my computer proeprty then uninstall usb driver and then right clik any driver then clik on scan for hardware then it searches usb and install automatically.
May 22, 2009 | Maxtor One Touch III 500GB FireWire/USB2.0...
Just got new computer w/vista. Cant download maxtor software
Try this link. It has a software for Vista for your Maxtor drive. Download the ZIP version and install it. Hope this works for you .
http://www.seagate.com/ww/v/index.jsp?locale=en-US&name=ot3-emc-vista&vgnextoid=b6623428ab622110VgnVCM100000f5ee0a0aRCRD
May 14, 2009 | Maxtor OneTouch III Mini Edition (R01E100)...
Maxtor One Touch II - installation Software
I have a disk that worked for me and I am running windows xp. I also have the website address that is supposed to have the 98 drivers which could work perhaps. http://www.seagate.com/ww/v/index.jsp?locale=en-US&name=Maxtor_OneTouch_Drive_USB/Win98SE_Driver&vgnextoid=b07d8b9c4a8ff010VgnVCM100000dd04090aRCRD
Guess you could try them first and if that doesnt work I could perhaps make a backup of the disk/package/mail/ worth anything?
Feb 05, 2009 | Maxtor One Touch II E01H300 (EO1H300) 300...
Maxtor One-Touch 4 750gb power light flashes and goes out straight away.
Try to remove the drive and connect it directly to another computer.
If still doesn't spin up then most likely the board has failed.
Nov 03, 2008 | Maxtor One-touch III Mini 40 GB USB 2.0...
I have a maxtor icon with a lock on it. I click on "unlock" and nothing works i have maxtor one touch II 300 GB, i'm using windows XP SP3 my maxtor is locked. It is only recognized on my computer under...
Have you tried right clicking on the drive and going into properties. Click on security option and make sure that all the permissions for the drive are active with the exception of special permissions. Also look at the advanced security settings and make sure that you have full control permissions. Hope this helps.
Sep 10, 2008 | Maxtor OneTouch II 300 GB Hard Drive
Drive won't mount
i had a maxtor one touch go bad and had to open the case and take it out of the external casing and put it into my computer as an internal drive. then it worked fine. it was a single drive.
just today i had a maxtor TB drive go bad, and since i think it has two drives inside it i am very worried that i will not be able to do the same thing.
May 25, 2008 | Maxtor OneTouch II external hard drive...
Maxtor 160 GIGABYTE USB2.0 EXTERNAL STORAGE 7200 RPM 8MB CACHE RETAIL 160 GB USB 2.0 Hard Drive Logo
110 people viewed this question
Top Maxtor Computers & Internet Experts
Computer Links
Rick Arnold
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
