After clossing door properly and inserting coins starting the machine by pressing start switch machine timmer, water valves drain pump every part is working except motor it remains idal while it is new. why the motor is not working?
    Brigadier General:
  • 4,088 Answers
If the motor is making a loud humming noise, look for (and replace) a 'start' capacitor which should be mounted on the motor or nearby. If it makes no noise at all, then it is not receiving power from the machine. Look for a defective relay or possibly the control unit itself. A less likely problem might be a broken wire wherever there is movement or vibration. Make sure that the motor can be turned by hand when the power is off. Hope this helps!
Posted on Nov 18, 2009
I have a brand new whirlpool wfw70hebw Duet washer that is stuck in the "draining" mode- the door is locked and the lock light is flashing red and it sounds like the drain pump is running. None of the...
I think you have a coin or something stuck in the drain pump itself. I have had to remove the pump,and take out the coin, reinstall it and it works perfect.
Jun 18, 2014 | Washing Machines
WHirlpool wtw6600
HI,
Unplug your washer and open up behind, you will see a thin tube coming down from the control panel (pressure switch to be precise) to the waste area below. Disconnect this carefully from the top, blow into it, air should pass through it should not be clogged; refit carefully. Before refitting, fit a similar tube to the pressure switch & blow - you should hear a click; if not there should be a problem with your pressure switch. Anyway refit your old tube & try the machine.
Sep 05, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
My indesit iwc6105 washing machine is not draining at all.
see this causes: and fix it. God bless you
Belt, Water Pump If the washer won't drain the pump belt might have broken or might have worn out. Check the belt and replace if it shows signs of excessive wear.
Drain Pump If the washer won't drain water the drain pump might be defective. It's also common for a small sock or other article of clothing to get caught in the drain pump or in the drain hose. Check both for an obstruction before replacing the pump.
Clogged Pump or Hose If the washer won't drain there might be a clogged pump or hose. It's common for small socks or other small clothing items to get into the water drain system and clog the hose leading to the pump or the pump itself. Remove the hoses from the pump in order to remove the article of clothing. Keep in mind that any water in the washer will pour out of the hoses when removed.
Drive Belt If the washer won't drain, should check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't drain properly, if at all.
Lid Switch Assembly If the washer won't drain the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't drain the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Drain Hose If the washer won't drain water check the drain hose. Be sure the hose did not get kinked behind the washer. Also, remove the hose from the pump and check it for obstructions.
Coin Trap If the washer won't drain the coin trap may be clogged. This washer is equipped with a device near the water pump called a coin trap. The purpose of this device is to trap any foreign materials that make their way down the drain. Normally, the coin trap can be accessed through an access panel. It is designed with the homeowner in mind and is normally easy to clean out
Oct 11, 2012 | Washing Machines
Hello I got zanussi jetsystem 1200. The washing machine don't want start and making clicking noise. The door won't close properly . Can you tell me what's the problem or what I have to do...
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Check this link to replace the inlet valve:
http://www.espares.co.uk/advice/washing-machines/a/7/1408/how-to-replace-the-inlet-valve-on-a-washer-dr.html
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the dry spin with the drain valve/pump activated so as to drain off all the water from the clothes during the spin.
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Please check the link below:
http://www.repairclinic.com/Washing-Machine-Troubleshooting?red=Washing-Machine-Repair-Help
Jan 07, 2012 | Zanussi Washing Machines
Frigidaire front load washer that will not start . it just buzzes. when it does start it stops after washing and leaves water in clothes asn buzzes.
it could either be a bad door switch or something stuck in the pump or a bad pump.if you set it to drain/spin will it drain out the water or does it buzz there?if it does drain i'd have to say you have a bad door switch.the model number you sent doesn't come up,you can unplug the machine,remove the hose that goes to the pump or run it before you unplug it and see if it's the pump making the sound or if the center of the pump can be removed to clean out the pump and check the pump for coins and junk,use a shop vac and vac out all the water in the tub and then lossen the hose or center of pump until water starts to leak out and vac it up as it comes out,check the pump and put it back together,add some water with a bucket or something and see if it drains out,if it doesn't drain and it sounds like the pump is making the noise you have a bad pump,if it buzzes and it's not the pump change out the door switch.the buzzing is electrical,things that could make this sound are the motor,the solenoids on the water valve or the door switch,if you can do some checks like see if it drains or try to find where the noise is coming from would be helpful.good luck and i hope this helps you out.
Oct 29, 2011 | Frigidaire ATF6000ES Front Load Washer
Washer starts to fill stops then drains F 81 error code
Whirlpool Error - lid (F81) - Open/Close Lid
NOTE: The letter/number in () is what is saved in the computer/control memory.
lid flashes when the following conditions occur:
? User presses START with lid open.
? User presses START after 2 consecutive machine cycles without opening lid.
? The machine/motor control cannot detect the lid switch opening and closing properly.
Hope helps.
Sep 09, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
I have a beko washing machine model wma 652s and the start/cancel button keeps flashing. It happened when I started a programme when I pressed the start button the machine failed to start. I've...
In this case the machine must start up to open the inlet and let the water in. If not this must be checked,If possible swap a board and check to confirm.
Once the inlett opens then the water flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Thank you for using fixya.
Aug 18, 2011 | Washing Machines
Power is being received by machine but the start wash button has no 'give' for pressing. Would I be able to fix it myself?
It is possible that the machine does not start off the cycle because there are errors or feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven from the flow into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
Aug 03, 2011 | Washing Machines
When I turn on my diswasher it only fills with water and won't drain or wash. It will go through entire cycle but never drains or washes.
It is possible that the machine does not start off the cycle because there are errors or back feedback from the inputs. For the program to start up the main program controller must initiate the INLET valve to open up and allow water to flow into. If this does not happen then the voltage at the inlet valve must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor .
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the drain valve/pump activated so as to drain off all the water .
http://www.espares.co.uk/advice/dishwashers/a/3
For spares click On:
http://www.espares.co.uk/search/dishwashers/p/1083
Jul 25, 2011 | Hotpoint Dishwashers
Motor running drum not emptying
sounds like maybe a blocked pump.Probably got a coin or sock or some lint in the pump.Has your machine got a filter ? What happens when you position the program switch on a spin section and turn it on ? does it pump out the water ?
Sep 14, 2008 | Hotpoint WMA64 Front Load Washer
Washing Machines Logo
60 people viewed this question
Top Washing Machines Experts
