Question about NetGear RangeMax NEXT WNR834B Wireless Router
Router looks as if it is not getting power.
Router is not getting or receiving a signal. It is not even displaying a power signal and looks as if no power is getting to the router.
  • NetGear Master
  • 32,281 Answers
Check the power adapter plug with a multi-meter. The voltage at the plug should be slightly higher then the voltage that is printed on the label on the bottom of the adapter.
If you get a very low or zero voltage, then the adapter is faulty and needs to be replaced.
Posted on Nov 18, 2009
How do you switch from 2.4ghz to 5ghz On the asus black diamond router
No, it wont, routers can only display the signal they are going to get by changing the modulation setting of the router, thus not all of the modem have this option. The older version of routers do have option for modulation setting change but the later versions just have a auto mode which means that the router will automatically shift from one modulation to another whichever is available and better. You can even check the router you're using if it has access for modulation change. Look for the advance tab and there will be options as g.dmt, adsl, adsl 2+, readsl etc.
Dec 28, 2011 | ASUS Computers & Internet
Can i add an outdoor antenna to my belkin f5d8236? how? do I connect to one of the existing antenna leads and forgoe the other? Do i need two outdoor antennas connected to it? I am trying to connect to...
I think you can try:
  1. Homemade Pringles antenna - Eat a packet of Pringles (ready salted would be my choice) then follow this tutorial to convert it into a functioning directional antenna. Point it where you need a signal boost.
  2. Airport Express & kitchen sieve - Take an Airport Express and set it into a common metallic kitchen sieve to boost it's signal further.
  3. Try a parabolic dish - Hawking make a 802.11 B/G parabolic dish that basically pulls in a WiFi signal, performs some magic and boosts your range by up to 300%! It only costs $80 and it has a cool retro style.
  4. Cantenna - This is basically a pro version of the Pringles tin hack. For $50 you can buy a Cantenna that plugs into your router and extends your WiFi signal. It also looks cool.
Also see this:
The Wi-Fire uses a powerful directional antenna, highly sensitive receiver and proprietary software to find and enhance normal WiFi signals. With it, you can connect wirelessly to the Internet-even at low signal strengths-faster, more reliably and with a more consistently strong connection-than you are able to with an internal wireless adapter.
The Wi-Fire draws very little power from your laptop battery. It comes complete with everything you need to connect wirelessly to the Internet. Just install the Wi-Fire Connection Manager, plug the Wi-Fire into an available USB port and you're ready to start. It can rest on any flat surface, laptop display or flat screen monitor.
Dec 31, 2010 | Belkin F5D8236-4 Router
Problem for D-Link DIR-615 Wireless Router, Orange Power Light
I have had multiple problems with these routers. They tend to drop signals or have other issues that are hard to explain in a few short sentences.
After you rebooted did you open your browser and type in the IP address to connect to the router software?
can you be more specific?
Nov 24, 2009 | D-Link DIR-615 Wireless Router
Linksys wireless connected to router, signal fine, no web pages
First thing i would try is power cycling your equipment. Unplug the router and the Modem-
Plug the modem in first and once all the lights come on- plug in your router- then restart your computer.
Apr 09, 2009 | Linksys Wireless-G WRT54G Router
Computer connects to router but not to the internet
This seems to me at first look to be a problem with your ISP not accepting the credentials for your connection. I presume you tried restarting everything after resetting the router, but resetting it has erased your ISP login and password.
Apr 07, 2009 | Dell TrueMobile 1184 Wireless Broadband...
Looks like conected but i cant get internet
Router might not be set up with the modem. Your router broadcast wireless signal when it is powered on, so even if it is not connected to a modem(where you get your internet from)you will have a local connection. That's normal. You need to set up the router. Call linksys technical support, if they cannot help try http://technicalsupport.blog.friendster.com
Feb 24, 2009 | Linksys Wireless-G Broadband Router
Cant get internet after connecting to router
what security u r using on router WEP are u putting the correct key for that when ur pda detects the signal of ur router and one thing more try going near the router and also check the Power save option built in Windows Mobile un check it to get better performance for WIFI , go to start >settings>WIFI uncheck Enable power saving mode and then press ok and then try to connect. pls let me know if it works
Feb 22, 2009 | HTC G1
Computer stopped receiving wireless router signal
In this order: 1) Turn off all PCs and printers connected to the router. 2) Unplug your router's power cord. 3) Unplug your modem's power cord. 4) Wait for at least 2-3 minutes. 5) Connect the modem's power cord and wait for at least 2-3 minutes. 6) Connect the router's power cord wait for at least 2-3 minutes. 7) Turn on each PC separately and wait until it is completely finished booting before turning on the next PC.
If you still do not have connectivity, read the manual and change the channel of the modem. YOu may be experiencing some RF interference, ie microwave, wireless phone system etc...
Oct 29, 2008 | Linksys Wireless-G Broadband Router
HELP
I need more information to help you.
1. What is your operating system
2. When clicking on the signal symbol (next to the clock) what number is listed under received.
3. Are you using firewall software.
When using the old router there are no troubles except the lack of distance? if YES --> have you give the new router the exact right encryption information. (there is a big differance between WPA and WPA2 or WEB)
Good Luck,
Pascal
Regards,
Pascal
Jan 23, 2008 | NetGear RangeMAX 240 WPNT834 Wireless...
NetGear RangeMax  NEXT WNR834B Wireless Router Logo
170 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
