Question about Nokia 1208 Cellular Phone
N1208 2580 KEYPAD SOLUTION DIAGRAM - Nokia 1208 Cellular Phone
Ade accentua 6remote keypad shows spanner light but it will not allow for set or reset
You should check out www.reliable-store.com they have info on repair, service, wiring diagram, electrical diagram, fuse diagram, troubleshooting, PCV, owner's/service/repair/parts manual, fault codes, error codes, etc everything on all vehicles. must check it out
Feb 26, 2018 | Cars & Trucks
1200 keypad ic diagram
Did you drop liquid on the phone ? Take out the keypad and let the device and keypad both dry up for a little bit. put them back together and it should work.
Jul 25, 2013 | Cell Phones
Some keys on the keypad of my treadmill do not respond when pressed, namely the Enter, and numbers 1, 2, 3, 4, 5, 0. Thank you!
adjust the REED switch, test it, clean it, and tight the plug or connector very well.see the diagram
2) Ribbon cable tight for keypad, and tight the upper plug vs lower plug
3)replace the new batteries, same mark, same type, and same polarity.
See block diagram
God bless you
Nov 16, 2012 | Exercise & Fitness
Key bord
If all the keypad doesn't work you need to change the Keypad Filter (IC) of apply jumper to fix it.So, if you think you could not do better to contact mobile repairing shop.Thanks for visiting fixyaYou can see the diagram of Ic from this 2730 keypad ic - Google Search
Mar 07, 2012 | Nokia Classic 2700 Cell Phone
Keypad won't program to garage door opener, tried several times, keypad easily programs to 2nd garage door of 3 car garage, but not to main garage door. Need main garage door to open with keypad. Changed...
It sounds like the keypad is not compatible with the main garage door. Make sure the keypad is the correct only for that model number opener. Older models will not work with newer openers and vice versa.
Oct 02, 2010 | Sears Craftsman LiftMaster Chamberlain...
NEED SCHEMATIC TO CHANGE KEYPAD
i need blackbarry 9000 circuit diagram for sim cucector problem
Apr 07, 2009 | RIM BlackBerry Bold 9000 Smartphone
Keypad light n display light not working
display light and keypad not working i have changed keypad light ic and keypad coil what to do?
Jan 11, 2008 | Nokia 6070 Cellular Phone
Nokia 1208 Cellular Phone Logo
688 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
