Question about Uniden DECT 6.0 Cordless Telephone Expansion Handset
The numbers show up on the display and are stored, i would like to clear them
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Uniden Master
  • 102,366 Answers
What model Uniden DECT 6.0 phone?
Posted on Nov 26, 2013
How do I set and save a fax number as a speed dial
You can download the User Manual from here (temporary link): http://dl.dropbox.com/u/1322442/CANON%20CFX-L4000.pdf
Here is a transcript:
Storing Numbers for One-Touch Speed Dialing
Your Canon fax can store up to 120 phone numbers: up to 20 of your most frequently used numbers can be stored for One-Touch Speed dialing, and an additional 100 numbers can be stored for Coded Speed Dialing.
1. Press SET and DATA REGISTRATION
The display will show:
DATA REGISTRATION
1. SPEED DIAL SETUP
2. Press SET twice.
1-TOUCH SPD DIAL
01
3. Use the search buttons (up and down symbols) to select a One-Touch Speed Dialing button between 01 and 20.
1-TOUCH SPD DIAL
[1...7]
??¢ You can also do this by pressing FUNCTION, then pressing the One-Touch Speed Dialing button, then pressing FUNCTION again.
??¢ If a number is already stored at the button you select, that number appears.
??¢ If the button you select is registered for Group Dialing, GROUP DIAL appears.
4. Press SET twice. Use the numeric buttons to enter the fax number you want to store.
TELEPHONE NUMBER
TEL =
??¢ Press SPACE to enter spaces between numbers. (Spaces are optional and are ignored during dialing.)
??¢ If you want to clear a number or a mistaken entry, press CLEAR.
??¢ To enter a pause in the number, press PAUSE one or more times
Sep 22, 2010 | Canon CFX-L4000 Plain Paper Laser Fax
How do i store numbers? there is no manual.
DATA REGISTRATION
1 .SPEED DIAL SETUP
2. Press SET twice.
1-TOUCH SPD DIAL
01
1-TOUCH SPD DIAL
[1...7]
TELEPHONE NUMBER
TEL =
Sep 17, 2010 | Canon CFX-L4000 Plain Paper Laser Fax
How do I save a number
You can download the User Manual from here (temporary link): http://dl.dropbox.com/u/1322442/CANON CFX-L4000.pdf
DATA REGISTRATION
1 .SPEED DIAL SETUP
2. Press SET twice.
1-TOUCH SPD DIAL
01
1-TOUCH SPD DIAL
[1...7]
• You can also do this by pressing FUNCTION, then pressing the One-Touch Speed Dialing button, then pressing FUNCTION again.
• If a number is already stored at the button you select, that number appears.
• If the button you select is registered for Group Dialing, GROUP DIAL appears.
TELEPHONE NUMBER
TEL =
• Press SPACE to enter spaces between numbers. (Spaces are optional and are ignored during dialing.)
• If you want to clear a number or a mistaken entry, press CLEAR.
• To enter a pause in the number, press PAUSE one or more times
Aug 19, 2010 | Canon CFX-L4000 Plain Paper Laser Fax
What does MC,MR,M-,M+ on the calculator mean and do?
MR is Memory Recall
MC is Memory Clear
M+ is Memory add
M- is Memory subtract
These are used to add and subtract the answers to multi-step equations so you can do the small steps with the calculator, then store, change or recall the total as needed. You might add a long string of numbers in groups this way. Or you can do all operations in one parenthesis, then just store the total of each.
A good problem to illustrate this would be : (123 x 3) + (55 - 24) + (10^2) - (7 x 8) = ???
Using MR, M+ and M-, you can do each one as a group, and only store the answers. 123 x 3 = 369 so M+ to put 369 in memory. Clear it from the calculator. 55 - 24 = 31, so M+ to put this in memory and add to the 369 already there. Clear it from the calculator. 10^2 = 100, so M+ this to memory also to add it. Clear it from the calculator. 7 x 8 = 56 so M- this to SUBTRACT it from memory. Clear it from the calculator if desired. Now, when you then hit MR, you will get the total of all of these small equations in parenthesis -- 444.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Sep 18, 2009 | Office Equipment & Supplies
How do I earase the M2 button that is always on my screen?
Clear the display so that zero shows, then press STO M2 to store zero in the M2 registry. Any time there is a non-zero number stored in M1, M2 or M3, you will see those memories in the display to remind you there's something stored. There is no "clear memory" function on the TI-30XA, you have to store zero in the memory to clear M1, M2 or M3 from the display.
David
Dec 17, 2008 | Texas Instruments TI-30XA Calculator
After upgrate firmware problem in receiving fax
You most likely just have to reinstall it. Something in the upload to the machine just didnt go right. I have had to do those firmwarew upgrades a couple of times to make it work.
But, before you do that try this. This may really be what you have to do.
  1. Press the [Menu / Exit] button on the Control Panel. 'System Data' will be displayed on the Display Screen.
  2. Press the [Left] or [Right] arrow button until 'Memory Clear' is displayed.
  3. Press the [Enter] button.
  4. Press the [Left] or [Right] arrow button to select one of the following items to be cleared from memory:
    • System ID: Clears the fax number and name from the machine’s memory.
    • System Data: Restores all options that can be modified to the factory default.
    • PhoneBK / Memory: Clears the speed dial or group dial numbers stored in the machine's memory. In addition, all scheduled job operations that have been reserved are canceled.
    • TX-RX Journal: Clears all records of fax transmissions and receptions.
      NOTE: To exit without clearing the item, press the [Menu / Exit] button.
  5. Press the [Enter] button.
  6. If necessary, repeat steps 4 and 5 to clear another item from memory.
  7. Press the [Stop] button to return to the Standby mode.
Nov 07, 2008 | Xerox WorkCentre M15i Laser Printer
Store & Recall Buttons
STO 1 puts the displayed value into memory location 1.
RCL 1 brings the stored value back.
Same for memory locations 2 and 3.
If there's something in memory, M1, M2 M3 will show in the display, clear the memory by storing the value zero.
Note that anything stored into memory location 1, 2 or 3 over writes what was there. Memory values are retained through power off/on.
To add the displayed number to a memory location (instead of replacing the value stored), use 2nd, STO, n
To exchange displayed and stored values, use 2nd, EXC, n
n is 1, 2 or 3
Get the instruction booklet from TI's website (pdf download) if you don't have one
Sep 26, 2008 | Texas Instruments TI-30XA Calculator
Job waiting message appears on screen.
You can selectively clear information stored in your machine’s memory.
1. Press Setup on the control panel. The display shows the first menu;
FAX NUMBER/NAME.
2. Press ➛ or ❿ until ‘MEMORY CLEAR’ appears, then press
Start/Enter. The display shows the items you can choose to clear.
• FAX NUMBER/NAME : your fax number and name are cleared from
• DIAL/SCHEDULE : clears the one-touch, speed dial, or group dial
numbers stored in the memory. In addition, all
the Schedule Job operations you have reserved
are also cancelled.
• JOURNAL : clears all records of transmissions & receptions.
• DEFAULT SETUP : restores all the option settings to factory default.
Only clear de Journal, don't clear the other.
Try this if it resolve the problem.
Nov 20, 2007 | Samsung SF-5100 Plain Paper Laser Fax
Speed dial list
***Storing a Number for Speed Dialing*** 1 Press Phone Book on the control panel. 2 Press Phone Book or the scroll button (􀂥 or 􀂊) to display ?Store&Edit? on the bottom line of the display. Press Enter. 3 Press Enter when ?Speed Dials? appears on the display. The display prompts you to enter a location number, showing the first available number. 4 Enter a one or two-digit speed dial number between 0 and 79, using the number keypad or scroll button (􀂥 or 􀂊), and press Enter. If a number is already stored in the location you chose, the display shows the number to allow you to change it. To start over with another speed-dial number, press Upper Level. 5 Enter the number you want to store using the number keypad and press Enter. To insert a pause between numbers, press Redial/Pause. A ?-? appears on the display. 6 To assign a name to the number, enter the name you want. For details about entering characters, see page 1.14. If you do not want to assign a name, skip this step. 7 Press Enter when the name appears correctly or without entering a name. 8 To store more fax numbers, repeat steps 4 through 7. To return to Standby mode, press Stop/Clear. ***Sending a Fax using a Speed Number**** 1 Feed the document(s) face up into the ADF. For details about loading a document, see page 2.2. 2 Adjust the document resolution to suit your fax needs. See page 2.3. If you need to change the darkness, see page 1.20. 3 Enter the speed dial number. ? For a one-digit speed dial number, press and hold the appropriate digit button. ? For a two-digit speed dial number, press the first digit button and hold the last digit button. The corresponding entry?s name briefly displays. 4 The document scans into the memory. The fax number stored in the speed dial location is automatically dialed. The document is sent when the remote fax machine answers
Aug 17, 2007 | Samsung SF-560 Plain Paper Laser Fax
How to clear all information from screen
screen has (m3)and (m1) in upper left corner, have not been able to totally clear screen.
Apr 10, 2007 | Texas Instruments TI-30XA Calculator
Uniden DECT 6.0 Cordless Telephone Expansion Handset Logo
23 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
