Question about Ariens Garden
My ariens 824 wont go forward or reverse. snow thrower still works. wheels start to move a bit then stop
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 197 Answers
I would check your traction drive disc for wear or shredding.With low or little fuel in tank you can safely grab handle bars and lift machine up on it's auger housing.Then remove shield from under machine and inspect metal disc with rubber around it.If rubber looks worn you can get a replacement traction drive disc easily from most small engine repair shop's or go online and look for your nearest Ariens dealer.
Posted on Nov 18, 2009
Why doesn't it move forward or in reverse?
Many tractors and mowers have a key way on the axle and axle bore on the wheel hub.. Did you remove the tire and wheel from the mower axle? ..if you did most likely the drive axle key fell out of its slot on the drive axle and when you replaced the wheel it has no way to drive the wheels..try this start the mower put it in gear and try to move..have someone watch the end of the axle at the wheel
..if the key is missing the axle will be turning..but not the wheel..any good hardware store should carry them. just measure the depth and width of the key..something like 1/4,3/8 etc...good luck..
Aug 16, 2015 | Ariens Garden
Will not go in reverse
yes adjust the linkage so the drive wheel goes past center
of the alum drive disk
Mar 03, 2014 | Ariens Sno-Tek 28 In 2-Stage Gas Snow...
Craftsman snow thrower won't self propel
Have you also changed the drive pulley? It is probably worn out of specification.
I recommend that you contact your nearest authorized service center.
I trust this information proves useful.
Nov 19, 2013 | Agri-Fab Agri - Fab Snow Blower - 42"
Auger shaft jamed
Try removing the belt and turning it by hand. If that doesn't work, you may have blown something into bits inside of the gear case.
Nov 03, 2013 | Ariens Snow Blower. Sno-Thro Deluxe Drift...
Snow blower shift linkage hard to shift
use wd-40 penetrant to get the rusty bits to move
oil liberally when storing
Jun 10, 2017 | Craftsman Garden
I have a Toro 824 XL, electric and manual start, 2 stage, 5 forward and 2 reverse gears and everything runs great except the thrower. When I pull the handle to run the thrower, I get a screeching sound...
There is probably a pulley froze. Without seeing it can't tell you which one. But you can disengage the thrower and reach under and try to spin the pulleys, the one that won't turn is the culprit. Depending on your level of mechanical ability you may have to take it to the shop. Hope this helps you out.
Dec 09, 2010 | Garden
Wheels losing power on Ariens 5520 snowthrower
i would open the bottom access panel and tighten the tension on the drive belt. i had a simailar problem with my 5520, it wasn't my wheel drive, but my thrower. it would throw snow intally, but stop as soon as it got in deep snow. when i opened the panel, i noticed the the tension on the belt was really loose. so i pushed the fly wheel close to the belt and tightened the fly wheel..and VIOLA as good as new. hope that helps...
Feb 10, 2010 | Air Tools & Compressors
!332 Snow Thrower will not Start - At full choke
change gas filter and spark plug
Oct 07, 2009 | Garden
My snow thrower once engaged, will not move
depending on how old it is it is either belt or chain driven check those. but first check your shear pins in the axles to make sure the axle isn't turning inside the wheel those are the basic 2 prob i worked on them for 10 yrs for sears
Dec 21, 2008 | Craftsman 4 Cycle Blower/Vac
Garden Logo
779 people viewed this question
Top Ariens Garden Experts
Phil Walker
Phil Walker
Matt Olenzek
Matt Olenzek
enb54
Level 1 Expert
Are you an Ariens Garden Expert? Answer questions, earn points and help others
