Question about GE Profile Arctica Stainless Steel Top Freezer Refrigerator
GE Profile Arctica PSS25SGNA BS Icemaker is not working seems to be filling with water but no ice.
  • GE Master
  • 4,654 Answers
The water dispenser and ice maker side run separate sides of the water control valve. Fill ice maker with tap water and let it freeze. If it dumps the ice then does not refill then the water control valve is the problem. I will be back soon with a photo and some links, Thanks, Sea Breeze
Posted on Nov 18, 2009
  • John Tripp
    John Tripp Nov 18, 2009
    I want you to try the water in the ice maker first. If that works then we need to replace part number Click Here=> WR57X10032
  • John Tripp
    Sorry about that my browser stopped. Below is a photo of the water valve. If it happens to be the ice maker at fault there seems to be no replacement parts because it's electronic. The model Ice Maker is the click here=> WR30X10093 if you need to find me click=> HERE Please let me know if this information was helpful or if you need more assistance feel free to let me know, and visit some of my sites=> Appliance Parts and Technical Services on that page you can download a Service Manual for the Profile/Artica you can also get assistance from=> Appliance Repair Point and Click and from myself, Just let me know, Thanks, Sea Breeze
GE GSL25IGRE BS slow water dispenser
Sounds like your water valve may need changing, and has filled up with sediment, slowing the water flow.
Mar 29, 2010 | GE Profile Arctica Stainless Steel Top...
GE Fridge icemaker is not working - Help!!
I installed a new icemaker (cost approx $100) and its making ice. Very easy to install yourself (remove 4 screws holding part below icemaker, then unplug icemaker, and unscrew the 2 screws holding it in place.). Good luck-
Jan 28, 2010 | GE Profile Arctica 25.4 Cubic Feet...
Ge profile arctica side by side- ice maker and water dispenser not working..have already replaced the water filter
The water dispenser and the icemaker both operate on different soleniods on the water valve so the chances of a bad valve are slim. I would assume you issue is in your water supply. The easiest thing you could try first would be to check your saddle valve that taps into your main water line to supply the ref. They are known for calcium deposits which obstruct the flow of water. This issue is IDed by very slow water pressure through th door. If its gunked your icemaker fill tube may also be frozen.
Jan 11, 2010 | GE Profile Arctica Stainless Steel Top...
Arctica won't make ice; ice was frozen solid yesterday. After removing, it won't make any more ice cubes.
As long as the ice trays are filling with water, it's not actually the function of the ice maker to make ice. Ice simply forms because the freezer compartment is cold.
The icemaker's function is to sense when ice is formed in the trays and to dump the ice into its container.
This requires the use of a thermostat to sense the water/ice temperture and 'tell' the icemaker when it's time to dump the ice.
During the dump cycle, a heater briefly comes on as the arm swings through the ice cube compartments to assist in loosening the ice cubes and make them easy to dump.
If the icemaker is filling with water but you get no ice, I suspect that either the control circuit (thermostat, relays, and wiring) is not 'telling' the heater to come on, or the heater is burned out.
Some units also have a timer circuit such that both the timer contacts and the thermostat contacts must be close in order to initiate a dump cycle (i.e., it must be time to dump and the water in the cubicles must be frozen).
A skilled homeowner could make these repairs, but if you don't feel comfortable taking your icemaker apart and testing the components, I advise leaving the job to a qualified repairman.
I hope this helps. Good luck.
Sep 12, 2009 | GE Profile Arctica 25.4 Cubic Feet...
My ice maker will not work, Ge profile Arctica.
Here you go...my dad had the same issues...Good Luck!
http://www.youtube.com/watch?v=sW2yqQjEcLI&list=HL1329704348&feature=mh_lolz
Jun 23, 2009 | GE Profile Arctica 25.4 Cubic Feet...
Water seems to be flowing into icemaker fine. When I turn on the icemaker the water flows for a few seconds then stops, I have waited to see if the cycle to dump works and it seems as if it never attempts...
If your freezer temperaures are good i.e. it freezes ice cream and the like, then you need to replace trhe icemaker. Typically, under normal conditions, the icemaker would dump a load of cubes @ every 1-1/2 hours. Icemaker part number WR30x10093 @ $148.00 from Marcone Appinace parts or AP Wagner
Apr 09, 2009 | GE Profile PSI23SGR Arctica¿...
GE Profile Arctica - Frig Freezing Food
Replace the damper assy, in the Refrigerator section. The damper door is stuck open. Very common problem on these refrigerators.
Nov 24, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Profile Arctica Icemaker
YOU CAN PULL THE FRONT COVER OFF TO SEE IF THE GEAR WHEEL IS BROKE,OTHER THEM AT CALL YOUR LOCAL APPLIANCE PARTS STORE AND YOU CAN GET A NEW ONE FOR AROUND $70,THANKS-MIKE
May 29, 2008 | GE Profile Arctica Stainless Steel Top...
Ice trays overfill leaking into the basket
FIND ADJUSTMENT SCREW UNDER ICEMAKER COVER AND TURN DOWN ICE CUBE SIZE,REPLACE AUGER,THANKS-MIKE
Jan 13, 2008 | GE Profile Arctica Stainless Steel Top...
GE Profile Arctica Stainless Steel Top Freezer Refrigerator Logo
1,085 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
