Question about LG enV VX9900 Cellular Phone
Well i have like 2 chargers for my phone the first charger wasnt any good. So i used the other one. Well Lucky me Found out it wasnt the Charger my Phone wont keep a Charge i find my self Charging it like 3 Times a day..Any ideas on what i should Do?
My phone charger is not charging the phone
Please change a new one and see whether the problem occur again or not? If it happen again then you need to repair your charger pin connection so please refer to mobile service centre.
thanks for using FixYa Good luck
Aug 26, 2011 | Sony Ericsson XPERIA X10 Cell Phone
My sony erricson K750i wont charge?
try your charger with another phone to be or try your phone with another charger to be sure the charger is good.
If the charger is good, then the next thing to check is your phone's charging port. Some times, the charging port for K750i is usually dirty, have dust, or may be rust and won't contact the charger well because of this, thereby, not making the phone charge.
Get a metal and use it to scratch all the areas of the charging port, then fix in your charger to see if it will charge.
If it still does not charge, then it means, you have to get another charging port.
You also have an option of using a desktop charger to charge your phone.
Good luck.
Apr 20, 2010 | Sony Ericsson K750
I have a accurian portable dvd player APD-3955 and it works but the charger doesnt charge it anymore. Now the battery died and I was wondering if it just needs a new charger. I got it June 2008.
I had the same problem and I found out that is definitely the battery. I had used mine only a few counted times and after 1 year the battery would not charge. I would plug it and the charge light would turn on and stayed for about 4 minutes and then turned off. I called axion and talk to customer support. The tech said that the internal batteries only last for a year whether you use the DVD or not. They would replace the battery for $60 + shipping costs. As you can see... it is not worth it....sometimes you are lucky and get good stuff for cheap but sometimes... you just get what you pay for.... and this is one of the cases. Yes, I am also very disapponted. What a piece of junk!!!! I can still watch DVD with either the charger plugged in or with the car charger. But it lost its Portable side.....
Dec 30, 2009 | Radio Shack Accurian APD-3955
My motorola hint phone says "unauthorized charger"
u have to turn off ur phone and then put the charger on..thts another way to fix it ..it can be any charger..u have to turn off ur phone then put the charger on
Oct 04, 2009 | Motorola Mobility Hint QA30 Cell Phone
I just bought a KA08 KA09 mini mobile but can't get it to charge. After around a minute the light goes green & red saying okay but I get nothing on the screen? can you advise me?
Use a nokia charger, they fit but very loosely in the little hole next to the usb/charger slot. You lucky mate my charger exploded as soon as i plugged it in! Luckily my old phone was a nokia though.
Sep 13, 2009 | Cell Phones
I BROUGHT OUT MY BATTERY AND CHARGED IT WITH A DESKTOP CHARGER
It was A Duplicate Batery -
It Wasnt the Genuine Nokia -
Hell it will Work -
U have to Charge it First through External Charegr -
When full Use it in Mobile -
Ur Phone Wont charge it with Charger -
Mar 06, 2009 | Nokia N76 Cellular Phone
Motorola W315
(If you are charging you phone inside your house) First make sure you have power to the receptacle you are using. test this by plugging in a lamp or radio into the receptacle you will be using.
I own the same phone and I have found that the phone has a small rubber cover that goes over the charging port. It's hinged but I found that it has to be removed in order to charge it because the charger can't connect securely with the rubber cover on the phone.
(If your are using a mobile charger) I have observed that my phone has a short in the mobile charger also and changes the ring tone after I charge it. My phone rings 1/2 of the time and I have found that this is a fault of the mobile phone charger. It charges the phone w/o any problem but the connection from the mobile charger is loose. This shorts out something inside the phone and changes my ring tone automatically.
Feb 11, 2008 | Motorola Mobility W315 Cellular Phone
My phone wont charge
I have the same phone and bought a new charger and it still wont work, it's the phone
Sep 13, 2007 | Samsung SPH-M500 Cellular Phone
LG enV VX9900 Cellular Phone Logo
Top LG Cell Phones Experts
skiffy99
skiffy99
Level 1 Expert
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
