Question about Intel Motherboard
How to repair of no display on the monitor - Intel Motherboard
  • jadenb333 May 11, 2010
    i need to know the makke of your laptop, model, and things that lead up to this.
  • 149 Answers
This can be due to the bad RAM or else the capacitor problem on the motherboard of your computer. You can solve the issue by changing the display capacitor on the motherboard. Get it done by a good technician who has knowledge on chip level problem solving.
Posted on Nov 18, 2009
No display
The Viewsonic VG1921wm monitor uses the same power supply board that the Optiquest Q19w uses. When that monitor has display problems like you are having the most common cause is bad capacitors on the power supply board. When the capacitors go out the power board does not put out the correct voltages to drive the back light circuits and the driver circuits so you get no display. There is a very good chance that this is the problem with your unit and it would be worth having a look at the power supply board. Here is a link to a repair guide for the Optiquest monitor and since they use the same power supply board it should help you check you board and show what needs to be replaced to repair it.
http://www.ccl-la.com/blog/index.php/how-to-repair-a-optiquest-q19wb-monitor/
I hope this helps.
Jun 20, 2012 | ViewSonic VG1921wm 19" Monitor
Hp monitor has vertical yellow line. Is this dead pixels and not repairable? Have checked all cards and cables. Line is permanent.
Unfortunately, your display problem is not repairable, except by replacing the display panel itself. What's happened is that something in the electronics built in to the display panel has failed, and it's keeping that column of pixels stuck on all the time. There isn't any way to get at those electronics to repair them, so the only cure is a new display.
This kind of defect would be something that the manufacturer would fix if the monitor was still under warranty. Yours is probably out of warranty, but it can't hurt to check your owner's manual or the HP website, and see if there's any hope. If your monitor is past any warranty, it's time to look for a replacement.
I wish I had a more positive answer. Thanks for using Fixya anyway!
Jan 01, 2011 | HP 22"LE2201w Widescree LCD Monitor
I have 2 2006 VX910 LCD display monitors no display at all
You have a monitor with a common problem. After a few years some LCD monitorswill blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of he monitor. If you are good at electronics repair/soldering you can usually fix he problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts,replace any that look like the pictures and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping. I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
Jul 03, 2009 | ViewSonic VX910 19" LCD Monitor
Monitor displays image for second and displays black again
Your Monitor has a heat sink issue. A capacitor in the monitor is at fault and when it heats it tells the monitor to turn off the display to save the display from damage....Problem Cost to repair will supercede the cost to replace it...Wal-mart 15" monitor 119bucks --17" monitor 129...same at staples office supply (Poof) problem solved.
Mar 21, 2009 | Gateway FPD 1810 18.1" Flat Panel LCD...
HCL 17" monitor display problem
Hi there ,
It seems that you have a vertical section problem ,It might be possible some capacitor might have gone wrong
Jan 24, 2009 | Samsung SyncMaster 753S 17" CRT Monitor
Apple monitor
I THINK YOUR DISPLAY COLOR PROBLEM.
DEGAUSS YOUR DISPLAY, CHANGE YOUR DISPLAY COLOR RESET IT TO DEFAULT SETTINGS.
Mar 24, 2008 | Apple Studio Display 17" LCD Monitor
Horizontal black line in monitor display
Yes, it can ve repaired. The problem is if it will be cost effective. I would hook up another monitor just to rule out the video card. It probably is not the video card...but be safe.
LCD monitors are very easy to repair...and I would suspect the LCD itself...
Let me know if you need a source to purchase the LCD...you will price it yourself and determine if it would be cost effective.
If you have a CRT monitor...junk it...definetly too costly to repair abd parts are scarce.
Good luck to you my friend.
Seek PC Repair
Feb 10, 2008 | Samsung SyncMaster 213 T 21.3" LCD Monitor
Monitor stops display
most likley the monitor has an internal power supply failure, generally the cost of repair could be higher than buying a new one.If your monitor is still in its warranty period contact the manufacturer,if not do you know of a local tv repair shop that provides free estimates to confirm cost of repair vs. replacement?
Dec 14, 2007 | ViewSonic VA1703wb Monitor
Incorrect Color Display
i think it has magnet on the other side of your monitor try to locate the magnet and removed it. magnet can change the color and display of monitor. or contact an expert technician of monitor.
Nov 05, 2006 | Sceptre X20G-Naga II 20.1" Flat Panel LCD...
Intel Motherboard Logo
83 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
