Question about Sony Ericsson Cyber-shot C905 Cell Phone
I dont know the passkey of my c905 to connect bluetooth to other device,would you help me
Bluetooth cant searching another device? what i should did for that?
Depending on your computer and any bluetooth devices make sure both have bluetooth are either turned on or made bluetooth discoverable
Bluetooth Pairing
Bluetooth pairing is necessary whenever two Bluetooth devices connect to each other to share resources.
A trusted relationship is established between the devices using a numerical password, commonly referred to as a passkey.
Depending on how often one Bluetooth device connects to another, the user might opt to have the passkey saved for future connection attempts or prompt to enter the passkey each time the devices request communication with each other.
Bluetooth Pairing Service
In most cases, Bluetooth devices are paired only once, and the details of the relationship are saved for later connections.
The pairing service, an integral component of all Bluetooth devices, is responsible for maintaining a list of devices that have made successful connections in the past.
It is essentially a passkey manager remembers the specific details for other trusted Bluetooth devices.
If a user has a reason not to allow automatic connections for specific devices, the Bluetooth pairing service will not store passkey details.
Preparing to Pair Because Bluetooth is a standardized-communication method, making trusted connections between Bluetooth devices is a straight-forward and simple process.
Before attempting to pair two Bluetooth devices for the first time, it is recommended to have both devices fully charged, turned on and Bluetooth enabled.
At least one of the devices must be set to discoverable mode, which means for a short period, the device will be announcing its presence to other devices within its range.
Pairing Bluetooth Devices
Have the second device search for other Bluetooth devices.
There are many types of devices on the market and just as many ways to put your device into discoverable or searching modes.
It is recommended you view the documentation for your specific devices to determine how to enter these modes.
Within 30 seconds, you should see the devices have found each other and a prompt to enter a passkey will be presented.
Bluetooth Pairing Passkey
The passkey is a four-digit number you supply at the time you are establishing your trusted relationship between devices.
If a specific passkey is set by the manufacturer, you can try "0000," or you might have to find the passkey in your device's documentation and enter that instead.
After you enter a passkey, the other device might prompt you to enter the passkey you entered. When the passkey is verified on the other device, the two have been paired.
The Bluetooth device and passkey information are stored using the pairing service so future pairing attempts do not have to be made unless desired as a security precaution.
Bluetooth software
You may wish to check out Bluetooth Command Line Tools a set of console utilities designed to work with Microsoft bluetooth stack.
Other Bluetooth resources
Visit our free premoderated Directory of Bluetooth Resources.
Aug 04, 2013 | Computers & Internet
I don't know my passkey for bluetooth on my iP-max2 or where I can find it
Passkey is the pairing code generated to authenticate a bluetooth device when it is connected for the first time.
If you have connected the device before and has not removed it, you can send and recieve files directly when your bluetooth device is in range. On the other hand, if you have removed the device or trying to pair it for the first time, it is necessary that you enter the passkey.
For that you need to follow these simple steps:
  • Have the device in range.
  • Open Bluetooth devices sheet on your laptop.
  • First, click on bluetooth settings and see that your computer is discoverable by other bluetooth devices. Enable it if necessary.
  • Close the dialogue box and click on 'Add Bluetooth Devices'.
  • It will show a list of all available devices.
  • Select the device you need to connect.
  • It will automatically generate the Passkey for that device.
  • Enter this passkey in the device and you are done.
I hope it will solve your problem.
Please don't hesitate to ask anything else related. I am following up.
Always at your service.
Regards.
Oct 24, 2010 | Acer Computers & Internet
My laptop have got a build in bluetooth but i dont know how to connect it please help
hi
  • Open your computer's Control Panel center to access your Bluetooth Device settings. Click on the Windows icon or the "Start" icon on your computer desktop's taskbar at the bottom of the screen. When the pop-up menu opens, click on the "Control Panel" link.
  • Step 2 Access your Bluetooth Device settings. When the Control Panel opens, click on the settings link that reads, "Bluetooth Devices." This link will display all of the possible actions and settings you can take regarding your laptop'smag-glass_10x10.gif Bluetooth technology.
  • Step 3 Configure your laptop's Bluetooth technology. Select the "Start the Bluetooth Device" action. The blue and white Bluetooth icon will appear in the Windows System tray within the computer desktop's taskbar.
  • Step 4 Network with another device in order to import and export files. Double-click on the blue and white Bluetooth icon on your computer desktop's taskbar. A Bluetooth dialog window will appear on your screen displaying your Bluetooth technology portal. Click on the "Add Devices" action. You will then be asked if your laptop would like to search for other compatible devices. Click "Next" to proceed. You will be prompted to choose a passkey for the pairing. Create a simple passkey and click on the "Pair" option. When the notification is received by the other device, enter the same passkey to pair the device to your laptop.
  • Jun 20, 2010 | Acer Aspire 5500 5570-2609 Laptop
    Cannot connect via bluetooth to Mac
    The default passcode for the Pogo is 6000.
    Sam
    Mar 17, 2009 | Polaroid PoGo Digital Photo Printer
    Need Bluetooth passkey
    a passkey is just a normal inserted between two bluetooth devices to connect them securely.
    Let it four times 0000 as your passkey
    Feb 17, 2009 | Motorola Mobility RAZR V3
    Passkey
    The passkey is 0000. If you have a problem, reset the headset. Turn the headset off and hold down the call button for 8 seconds until the headset flashes blue and red signaling that it is in pairing mode for the next 120 seconds. While the headset is in pairing mode, use the phone menu to search for Bluetooth devices and select "220Plantronics." (If the headset is already listed in the Bluetooth menu, delete it before searching to pair the device.) When prompted for a passkey, enter 0000. Headset will falsh blue when paired successfully.
    Nov 14, 2008 | Plantronics Explorer 220 Bluetooth Headset...
    PASSCODE
    hi have motorola h700 bluetooth device but i forget my passcode how do i reset it again i tried many passcode like 0000, 1234, 1111 ,2222, 3333,4444,5555,6666,7777,8888,9999, but its not connecting wat do i do nw.. plz solve my problem.... my email address is talk2nazim@yahoo.co.uk
    Aug 21, 2008 | Motorola Mobility Bluetooth...
    Im trying to set up my bluetooth on my cell phone. It finds my bluetooth an H700 motorola then I press pair and it says to ENTER PASSKEY, I dont know what it is. I tryed 1234 and it says failed to...
    passkeys should be entered for both devices.
    like when you are trying to paired your phone with you friend's
    it would then asked to type in a passkey, you can type in any passkey you like but it should be same combination with your friend's. (so you can use 1234 punch in on yours and your friends need to use 1234 code punch in his phone, so both bluetooth device will be paired successfully).
    Apr 28, 2008 | Cell Phones
    Cant connect to device through bluetooth or any other way!!
    your problem isn't making much sense. you say you are using bluetooth devices to connect your pc to your printer and it isn't working because you need a passkey (encyption key).
    Feb 21, 2007 | Belkin Bluetooth Access Point With USB...
    Sony Ericsson Cyber-shot C905 Cell Phone Logo
    Top Sony Ericsson Cell Phones Experts
    Computer Repairing
    Computer Repairing
    Sandeep Shenoy
    Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
