Question about Nikon COOLPIX S200 Digital Camera
Af? When I turn on my camera it won't go to view my pictures. It just flashes "AF" and the only thing I can do with it when I turn it on is take one picture. But then as soon as I take the first picture I can't take anymore but I can view my other pictures... can this be fixed or do I have to buy a new camera?
advance
  • 107 Answers
SOURCE: AF flashing green, red AF sign on screen - won't take pictures
When you depress the picture button you should both hear the camera making motor noises and see the image focus changing as it seeks the proper focus for the image. If no focus movement takes place and you hear nothing then the focus motor is either completely jammed or malfunctioning. Alternatively focus movement may take place but it never finds the right focus point. Or you may hear a buzzing or clicking sound when it should be focusing. These symptoms can be caused by impact or, more commonly, sand or other contaminants making their way into the delicate system which moves the focus element. The camera will require professional repair in either of these cases. David Millier Advance Camera Repair
Posted on Feb 24, 2007
SOURCE: nikon coolpix L5
oh well, just came back from the camera shop and apparently it is the button.
thanks anyway!
Posted on Jun 17, 2008
SOURCE: Camera won't autofocus
I too had D50 autofocus problems and ended up buying a new D300. I then learned that my issue was in the focus areas. The D50 has five focus areas. As you look through the lens, you will see one rectangle in the center and four to the top, bottom, left and right. You should make sure that the center rectangle is highlighted. Use the round thumbdial on the back of the camera to move the focus area.
Posted on Oct 31, 2008
SOURCE: AF area mode problem
I had the same problem and just changed the setting on both the camera and an attached lens to 'A' (from M) and it enabled those menus in the custom settings.
Posted on Jan 10, 2009
  • 115 Answers
SOURCE: Nikon 18-55mm AF-S/ VR lense shudder?
I believe you're hearing the VR in the lens adjusting. Try turning the VR off and see if you hear the sound. If not, then you have a normal operating lens.
Posted on Sep 18, 2009
How auto focus
Most camera's, and the Olympus to work the same with auto focus. You place the AF target o the place you want to focus on. (the part that should be in focus in your picture) then press the shutter release button half and wait tip the AF conformation mark lighter up on the view finder. (the little round in on the bottom left) Then frame the picture as you want it shot and press the button complete.
I'm not sure your lens has a AF / MF switch, but that should be on AF all the time.
When you use non AF lenses, your cmarea can't focus automatically.
It should work fine with the kit lens. (lens that was originally delivered with the body)
May 04, 2014 | Olympus E-400 - digital camera
Canyon eos auto mode= won't take a pictuRE
Push your shutter 1/2 way down. See whats the readings in view finder.
Jul 04, 2013 | Cannon EOS 50D Digital Camera
Canon ds6041 digital rebel problem with AF 70-33 mm
Try cleaning the contacts on the lens and camera body where they meet with a cotton swab lightly dampened with rubbing alcohol.
May 31, 2010 | Canon Digital Rebel / EOS-300D Digital...
Nikon AF light keeps blinking after taking picture
You've been ripped off. Try to return it for your money back. Threaten to call the BBB, the Attorney General, and your lawyer (bluffing, of course).
Feb 24, 2010 | Cameras
On AF but won't allow me to take the picture.. In M mode it takes a the picture
It could be a couple things.
Camera software is set to Focus priority. If it can't confirm focus, shuttter is locked. If you can reset that to release priority, it will take pix ok.
Otherwise,,,Send to repair guy.
Why can't confirm AF?
something physically outa place - dropped?
someting not talking to AF module? dirty contacts
dead IC
AF module died...needs replaced
The repair guy should clean, re-lube, and adjust,also.
Oct 18, 2009 | Canon EOS Rebel G 35mm SLR Camera
Sep 01, 2009 | Nikon D5000 Digital Camera
Nikon D90 Self-Timer does not work when flash is engaged.
The answer to your question can be found at...
This website
All but the very best flashes can not recycle atthat flash rate. For burst mode, you probably want to use focus modeAF-C or AF-A.
Morris
Page 73 in the manual; If the flash fires in L or H mode (pg. 65), only one picture will be taken each time the
shutter-release button is pressed. The shutterrelease may be briefly disabled to protect the flash after it has beenused for several consecutive shots. The flash can be used again after ashort pause.
The flash can take several seconds to recharge andduring that time the shutter is disabled. NR will also reduce thenumber of frames per second that you can take, and of course yourshutter speed has to be fast enough to allow for 4.5 fps.
In AF-S the shutter won’t fire unless the camera has achieved an in-focus state and the focus is locked.
In AF-C the camera continually focuses, but that isnot the same thing as being in focus. As you move the camera or yoursubject moves, the in focus state will come and go, but the camera willattempt to continuously re-focus. BUT, the shutter will fire even ifwhen the AF system has lost the in-focus state and the picture is outof focus.
In the D90 manual it indicates that the AF-A modewill only fire when the green in-focus light is on, just like in AF-S.The problem is that you probably won’t get 4.5 fps unless both thecamera and the subject are stationary and no time is lost between shotswhile the camera re-focuses.
Brooks
http://bmiddleton.smugmug.com/
Mar 06, 2009 | Nikon D90 Digital Camera with 18-105mm...
I can turn my camera on then the screen picture is all blurry and it won't do anything if you press the button as if to take the picture. The one thing i have noticed different is the letters [CAF] in the...
When the camera is set to C-AF (Continuous Auto Focus) mode the focus is continually aligned according to movement of subject or the camera even when shutter button is not pressed. The Continuous Auto Focus (C-AF) is disabled while the camera is zooming in and out. Once the camera stops zooming the CAF is initiated and the cameras focus is adjusted.
This is actually used for video.
Jun 06, 2008 | Samsung Cameras
Af and flash button flash continuously when camera switched on
How old is the camera? Take a new approach to Nikon. But costs are about right- it is no joke.
Aug 10, 2007 | Nikon Coolpix 5600 Digital Camera
AF problem
Jangles, I am having the exact same problem. Have you found a fix ?
Aug 13, 2006 | Nikon Coolpix 5600 Digital Camera
Nikon COOLPIX S200 Digital Camera Logo
18 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
