Question about GE Advantium 120 Convection/Microwave Oven
Have a GE microwave model #SCA1000DWW 03. Was
Have a GE microwave model #SCA1000DWW 03. Was baking biscuits which it completed, but just quit working. It is on its own breaker...breaker was not tripped. The outlet that it is plugged into is working. Any suggestions?? Please help!
  • 4 Answers
SOURCE: dead microwave
There are replacable fuses inside. Taking the microwave apart requires removal of a lot of screws and the cover that can be rather bulky. make sure it's unplugged and safe before you begin. you can get replacement fuses at radio shack, ect. be sure to buy the same type and amperage. if the blow a second time there may be other issues.
Posted on May 27, 2009
pgh_pa_guy
  • 2992 Answers
SOURCE: microwave power shut off and stopped working
You can test safety thermostats with an ohmmeter. There should be a short circuit between the device's two terminals if it's closed. (This doesn't necessarily mean the device is good, though. It might be opening at too low a temperature when the oven is operating.) A high resistance or an open circuit means the thermostat has opened and needs to be replaced. An appliance parts store should have suitable replacements, or you can order from a number of online vendors. I usually start at the Sears parts site. They have part information for many models, and usually pretty fair prices for parts. But once you have the part number you need, a Google search will let you shop around.
It does sound like your oven shut down because of a thermostat. One is normally mounted on the magnetron tube that supplies the microwaves, and another is on the cooking cavity. I've had to replace these many times. If the main power fuse blows the oven will not come back on until it's replaced. But you might also have bad solder connections causing the trouble as well. I've seen solder joints on the control board and power filter board cause dead ovens.
If you're not absolutely sure of what you're doing working on a microwave, you might want to let a professional check it over and make an estimate. There are potentially lethal voltages present, and microwave leakage may be a concern as well.
Posted on May 28, 2009
MicrowaveSvc
  • 9098 Answers
SOURCE: My GE Profile Microwave/Convection Oven stopped working.
Chances are that the thermostat / thermal cutout / T.C.O. (whichever it uses) has opened.
This can happen when the magnetron overheats, either due to it's failing, or if the internal cooling fan is not working.
It may also that be the 15- or 20A ceramic line fuse or the oven cavity thermostat / thermal cutout / T.C.O. (whichever it uses) has opened.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
You should be able to get the fuse from a home center or local appliance parts store.
Accessing some components for testing and possible replacement will require you to remove the oven from the wall.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions here.
Posted on Jun 08, 2009
dmftrucker
  • 1922 Answers
SOURCE: GE Microwave JVM1870SK03-NO POWER TO UNIT, PANEL
change the units internal ceramic fuse and try this,may just be a fuse or if new one blows then could be h.v. diode.capacitor,thermal fuse,magnetron tube
Posted on Nov 09, 2009
SOURCE: GE Spacemaker microwave JVM140G just stopped
NO internal fuse. It is most likely, the magnetron, and or High power diode. As related In all likelihood the mangnetron has failed, or perhaps even the Power Supply. or a fault that is shutting the system down for safety reasons You need to have it serviced by a reputable service centre/man. Ensure you get a firm "Quote" before proceeding, and remember these days the cost of repair can equal or exceed the price of a new one.
Posted on May 10, 2010
I have a GE Advantium microwave model 2001 scb2001 03. It stopped working in the middle of a cooking and power goes completely out. A few days before that there was metal odor when using microwave
Betty, it sounds like you might have 2 problems and the power shutting off could be an end result of the metal odor you described. The power shutting off, more than likely is just a blown fuse. That is usually a simple and in-expensive repair. The metal odor could come from either your magnetron or from the high voltage transformer. Either one of those is going to be a rather expensive repair and if repair part stores in your area are anything like in my town, unless you repair them for a living or know someone who does, you can have some difficulty in getting those parts. Sorry for the bad news, but it might be simpler to just replace the microwave.
Feb 05, 2015 | GE Microwave Ovens
I baked a potato for 10 minutes, burnt it, and microwave oven quit working. Nothing works. Any suggestions for a reset button?
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101 ';
Jul 03, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
How do I get the burned smell from my Whirlpool microwave. All I did was overheat a biscuit. We've tried vinegar, baking soda, Fabreeze and lots of other stuff. Can you please help us? Thank you. ST
Spray the inside with Dow Scrubbing Bubbles Bathroom cleaner, let foam, wipe clean, and rinse. Then if the odor persists, mix one part vinegar, two parts water in a bowl, set inside the Microwave and turn on for five minutes.
Jun 15, 2011 | Whirlpool MH7135XE Microwave Oven
My GE microwave Model #JE1860BH 03 will not heat. It started to arc for a few times then quit heating. Everthing else works. Can you help?
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
heatman101
Apr 25, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
I have samsung CE103VD microwave.could you plz tell me what temperature n what time should i set to bake a cake on convection mode?
I too have the same problem i try to bake cake and it turns to become biscuit or it dosnt cook in the centre
Sep 17, 2010 | Samsung MT1066SS Convection/Microwave Oven
Ge sca1000DWW microwave - how do I remove the grill (above the door) to give it a good cleaning?
See the video at our site or the service manual.
Jul 03, 2010 | GE Microwave Ovens
GE Microwave wes1384sm2ss quit cooking. it
Owners of a GE WES model might want to look at this blog post.
Nov 28, 2009 | GE JE1640 Microwave Oven
Ge jvm1870 it won't heat anything, all other items work
Ok, if this unit has stopped heating, this will confirm a major fault within the Magnetron. this device is responsible for the heating affect and, you will need to replace this damaged part in order to restore proper heating functions in you microwave oven.
Mar 03, 2009 | GE JVM1870 Microwave Oven
GE Advantium Microwave not heating food
If you want it fixed call sears for service. I would not recommend taking this microwave apart if you dont work on them for a living. only because there are 14 million thing that need to be remove to do a simple repair.
Dec 04, 2008 | GE Advantium 120 Convection/Microwave Oven
GE Advantium 120 Convection/Microwave Oven Logo
128 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
