Question about Acer Aspire 5610-4648 Notebook
Suddenly my mouse and roller bar stopped working
    Novelist:
  • 210 Answers
Fn + F7 (or thereabouts)
Usually enables/diables built-in trackpad for those who use an external mouse but keep accidentally moving the built-in trackpad while typing.
Posted on Nov 18, 2009
  • Michael May 05, 2013
    Spot on! This solved my problem. I must have pressed Fn+F7 in the dark when I went for Fn+F8 to mute. Problem solved immediately. Thank you very much
  • Steve Rand
    Steve Rand May 05, 2013
    Glad it helped! Thanks for the feedback!
2 Suggested Answers
anasourabh
  • 202 Answers
SOURCE: my mouse and roller bar stopped working - its
its a most probly issue wth ur mouse pad. connectivity were not proply. so kindly chk it out ur touch pad.
Mighty Mouse won't scroll down
1-turn mouse on back
2-there is a cover that holds the roller in place turn and remove
3- put roller and cover to the side
4-look inside there is a wheel and a bar
5-on the bar you will see some accumulation of dust and string, hair etc...
6-remove with eyebrow remover
7- put back roller and cover
Dec 19, 2007 | Apple Mighty MA086LL/A Mouse
How do you stop scroll from sliding down on its own on acer laptop aspire 4250?
Go to your control panel then choose the mouse option. Under the wheel tab you should see scrolling options.
Aug 17, 2014 | Acer Aspire Computers & Internet
The roller bar area is not working
It sounds like the touchpad needs replacing. Contact me if you can't get it repaired locally.
Jan 09, 2010 | HP Compaq 236076-001 Touchpad
Mouse suddenly not moving very well, and takes a long time or extra clicks to respond
There are several things that this could be. First, let's suspect the mouse itself. Make sure it has fresh batteries. If it's rechargeable, make sure it's charged. Be aware that rechargeable batteries WILL stop working at the end of their life. Another easy fix to clean the movement detection mechanism. If it's a ball mouse, take out the ball and clean the rollers. The dust will probably be wound so tight around them you'll think it's a rubber washer or something, but you can pick it off with a little trouble. If it's an optical mouse, clean the lens with a dry cotton swab. If this doesn't fix the problem, try plugging the mouse receiver into a different port on the computer. Check your computer for viruses, spyware, anything that might be slowing it down. Check to make sure you have the latest drivers installed if necessary.
Nov 25, 2009 | Logitech Cordless EX 100 Mouse
Light goes off & mouse stops working-have tried cleaning the light with alcohol on Q tip but doesn't help. it will stop working suddenly & start just as suddenly
If it has a wire to the back of the computer make sure its plugged in tight sometimes tahey come loose. if its wireless change batteries. If neither buy new mouse.
Sep 26, 2009 | Logitech Wheel Mouse Optical
Left mouse button all of the sudden stopped working
check all connections and restart computer. The p.o.s.t. will sometimes correct the problem. if not inspect the mouse physically and be sure all is well. It could be a switch inside the mouse if so simply take it apart carefully and check.if you have another mouse try it and see if it works this will let you know if it is your mouse or your computer. To test the bad mouse use it on another computer and see if it operates there.
May 03, 2009 | Gateway T-6330U Notebook
LOUD GRINDING NOISE ALL OF A SUDDEN , LOOSE BELT ?
you will probably have a faulty roller bar take of panel on bottom of vaccum. Now remove the roller bar hold the bar by both ends and try spinning. This should be easy and smooth if not pull off the end cap these will be very tight and check the bearings in each end i think you will find a few small metal balls rolling around inside if this is the case you need to replace the bar
Nov 06, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Acer Aspire 5610-4648 Notebook Logo
91 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
