Question about Hitachi 57SWX20B 57" Rear Projection Television
TV: Hitachi UltraVision no Picture.
TV: Hitachi UltraVision 57SWX20B. I turn it on and I hear it turn pop on, but there's no picture. Any suggestions?
Hitachi Ultravision power light on but on picture
Posted on Nov 19, 2009
Have a hitachi ultravision model # P50S601 picture is good but tv pops. Any ideas?
popping is not a good sign. see if you can ask a repairman and take the set to him. popping occurs before dying completely I hate to say.
Feb 12, 2015 | Hitachi Televison & Video
I'm not getting any red in my picture on my hitachi rear projection ultravision tv
A model number would help here but if it is older and uses 3 picture tubes carefully with the back off and set on does the red one come up and produce a red image?
Dec 12, 2012 | Hitachi Televison & Video
How do I fix My 50 inch Hitachi Ultravision TV?
Likely the lamp in the set has failed here which does make sense if the picture was dim before---a lot of lamps just before failing all the way dim down.
Apr 25, 2012 | Hitachi UltraVision CineForm 55VG825 55"...
Hitachi 42" ultravision...power light on, hear
Tries pushes the power switch on the remote few times,each times push wait like a 1 mins or 2 mins for the tv Tuner signal board to take it effect.This process should get ur tv picture back,because the tv Tuner signal board it is old and having problems,evenually require replacement of a refurbish tv Tuner signal board.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish tv Tuner signal board for the replacement.
May 23, 2011 | Hitachi UltraVision 42HDS52 42 in....
Hitachi model 57SWX20B , Sound, but no picture
I had similar problem with my 57xwx20b TV as well. I'd unplug it from the wall for at leas 30-40s and plug it back in, the picture would return as normal. It will come back from time to time but the same procedure will reset the video board and the picture will return. I'd also check to make sure that the TV has the latest firmware from Hitachi as well. The FW for the ATSC tuner is upgradeable via the SD card and Hitachi website will give you the procedure. This fix all kind of problem with my TV from blank screen, green screen, flashing screen, pinkish screen because the old FW was built before the final standard. Apparently, it interferes with the video board and causes it to go amock. Good luck.
Jul 28, 2009 | Hitachi 57SWX20B 57" Rear Projection...
I have a 50 inch hitachi ultravision that has no picture or sound but power light is on
Probably a 'cold or detatched' solder joint on a component on that perticular circuit board you are 'wedging' with a plastic rod.
Apr 16, 2008 | Hitachi 43UWX10B 43" Rear Projection...
Hitachi Ultravision Digital TV Model 57SWX20B
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
Or send to ptscorp.com
http://www.hdtvoice.com/voice/index.php?s=
good luck
please mark the post with a fixya
Feb 08, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
Hitachi ultravision
Check IC601, C603 for leakage, I601 and vertical pulse detector QN05
for poor convergence check RK42 for open circuit.
Dec 20, 2007 | Hitachi UltraVision CineForm 55VG825 55"...
Hitachi 57SWX20B 57" Rear Projection Television Logo
2,308 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
