Question about Sony PlayStation 2 (PS2) Console
Ps2 powers up, but disc is not spinning and
PS2 powers up, but disc is not spinning so it is obviously unable to read the disc.
    Guru:
  • 188 Answers
Following could be the reasons for not spinning any PS2 disc:
  • A dirty laser. Try cleaning the laser and see if it helps. If you can see crust or dust covering the laser eye, it may not be strong enough to read anything at all. If the laser looks clean, this is probably not the issue.
WATCH this video to clean lens
  • An unplugged laser cable. These things normally do not come out by themselves, but if you opened the ps2 that was spinning OK to clean the laser and/or removed the laser to clean it, plugged it in, now it's spinning 1/2 of a turn, the laser cable may not be in securely. If it is in securely, make sure it is plugged into the motherboard end properly.
  • A dead laser. On models 30001, 35001, and some 30001R, this is the most likely issue. These models are old and the original lasers were a bit unreliable.
No Spin At All If your spindle hub is NOT SPINNING AT ALL, NOT EVEN 1/2 OF A TURN, it may be bad or unplugged. A tell tale sign of it being unplugged is if you hit eject, the laser moves down the rail, and starts grinding because the PS2 keeps trying to move it down the rail even though it hit the end. There's a small switch on the spindle hub that tells the unit to stop pushing the laser because it's reached the end. Spindle hubs usually do not go bad by themselves, usually either the PS2 too a bad fall and it became bent [try spinning it by hand], or someone the cable out and put it in too many times [or incorrectly] and the silver contacts on the cable were detached.
Posted on Nov 29, 2009
My ps2 slim wont read god of war II disc but it reads all my other games just fine so please i need a solution
God of War II being one of the few Dual-Layer discs on the PS2, it is possible that your problem originates from your PS2 lens being unable to read it correctly. The PS2 Slim is supposed to be able to read Dual-Layer, thus you should try cleaning your lens, it may be dirty, leading to this kind of error while still able to read Single-Layer discs.
-Organicbeing
May 14, 2011 | Sony PlayStation 2 (PS2) Console
My ps2 Cant read my disc!
clean the disk with disk cleaner clean the lens of your ps2 with a cd cleaner meaning a cd with brushes on the other side of it or with some rubbing alcohol then it should let you read your games
Jun 19, 2009 | Sony PlayStation 2 (PS2) Console
The ps2 has trouble spinning and reading disc.
it means your playnstation lenses have a problem
Jun 15, 2009 | Sony PlayStation 2 Slimline Console
Sony PS2 discs that were previously used with memory card will not read. other games with no memory work fine. Discs are spinning but browser says disc could not be read.
everything you'll need...this is very common on the ps2 is it a slim or the big one...if it is the fat one here try this :)
http://arstechnica.com/articles/paedia/hardware/ps2.ars
Dec 27, 2008 | Sony PlayStation 2 (PS2) Console
Disc read error
get it repaired. obviously the drive is not spinning correctly for ps2 disc. so take it to a shop ask for a quote to repair.
most ps2 are about $99.00USD
Jun 07, 2008 | Sony PlayStation 2 (PS2) Console
Unable to read discs
  1. Solution based on a slimline ps2
  2. Check to see if a Music cd will spin in the console
  3. Open flip lid and examine the reset switch - check to ensure the switch is intact - you are looking for a small lever which is made of lack plastic. If its not there you need a new reset switch
  4. If the laser is not moving at all you will need to open up the console (WILL OBVIOUSLY VOID YOU WARRANTY!)
  5. Check the PCB switch at the rear of the console. This part connects to the lid of the ps2 if thats is broken you will need to replace - difficult to source but they are available
  6. Check the ribbon cable underneath the PS2 Laser for any signs of damages
  7. Check the ribbon cables x 2 which attach the laser assembly to the motherboard
  8. Remove the motherboard metal shield and test the SMD (SURFACE MOUNTED) fuses on the underside of the board use a multimeter for this
  9. If your console passes all these tests the most likely cause is a blown laser which is a simple part to source via ebay etc.
  10. If your new laser does not fix your problem then you have a blown RS2004 chip which is expensive to replace and usually not economical to do.
Dec 08, 2007 | Sony PlayStation 2 (PS2) Console
PS2 won't spin a disc
Take it to technician because it happen also to our PS2 and you can do nothing about it but to take it to a technician.
Oct 30, 2007 | Sony PlayStation 2 (PS2) Console
Slimline PS2 disc not spinning
my friend i have a ps2 that its cd does not rotate ( i open it completely ) and the lens is working the lens is producing a red ray and it is movinng up and down but just the cd motor doesnot rotate so i checked the smd fuses using my fluke dgital multimeter i found one that is open when i replace it the ps2 work perfectly fine for your information the smd fuses are marked ps1 ps2 ps3 ps4 etc
Apr 30, 2007 | Sony PlayStation 2 (PS2) Console
Sony PlayStation 2 (PS2) Console Logo
395 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
