Question about Amana AEW3530DD Electric Single Oven
I have an Amana self cleaning built in convection wall oven model # AOCS3040 - every button on the control panel works - except - the up and down arrows which means I cannot set anything on the oven and therefore it is useless. If you can help me solve this problem that would be great.
  • 6,784 Answers
HI.Your issue will be with the membrane switch pad(touch pad). These two control buttons that you are referring to are damaged(circuit failure). This is not repairable. This will require you to replace the entire touch pad board. Once the touch pad is replaced, the unit will return to its normal operating status.
Touch Pad Part Number 31861403C
Posted on Nov 18, 2009
We just purchased a home that was built in 2003. It has a stainless steel double oven. The doors don't close tight. Is there a way to adjust them so they do? Thanks
I have the same problem on my AOCS3040 oven....door will not shut tightly so it loses heat and is about 25 degrees off plus the escaped heat makes the control panel get very hot during cooking.
Oct 21, 2010 | Amana AOCS3040 Electric Single Oven
On a Amana EvenAir convection Plus oven the convection blower comes on during the regular bake cycle.
There is a blower on the top of the oven, which turns on when the oven is hot enough. If the warm/hot air is coming out from top vent corners - this is the blower working. Even if you turn the oven off at that moment, the blower will still work until the oven cools down. This is normal.
Oct 12, 2009 | Amana AOCS3040 Electric Single Oven
My start button on my kenmore built-in oven w/microwave won't wor
my kenmore model number 911-47699100 oven doesn't work. Everything except the oven and broil works--cleaning, all timers, start button, etc. All that happens when you push start is about every 30 seconds, two relays can be heard making and breaking kind of like a click then immediately a clack. No error codes appear. Replaced sensor but that didn't work. Any help would be appreciated.
Mar 30, 2009 | GE JKP30WMWW 27" Built-in Single Electric...
Amana EvenAir Convection Plus Self Cleaning Oven will not unlock.
My oven was locked and would not open. No lock light was on but the oven was clearly locked. F9 error when I hit certain buttons.
Try this. I unplugged the oven for about 5 minutes. Plugged back in. A LOCK light came on. Held down "Oven Cancel" for a few seconds. Door opened and lock light went off. No more F9 error when I hit those buttons.
Dec 03, 2008 | Amana AEW3530DD Electric Single Oven
Amana Electric Oven Issue
My oven never reaches the proper temperature sitting for baking. Controls for the oven only is push buttons. How can I adjust this. This has been going on since I have bought the Amana
Oct 27, 2008 | Amana AOCS3040 Electric Single Oven
F1 error on SS Amana Convection wall oven
F1=Electronic range control failure
It is telling you may have a fauilty control...need to replace control or EOC
Jun 03, 2008 | Amana AOCS3040 Electric Single Oven
Amana Convection Wall Oven Model AOCS3040 Does Not Heat in any Mode
sure its possible, sounds like you've blown an over limit thermostat behind stove, gets too hot and for safety reasons cuts off unit untill replaced
Feb 11, 2008 | Amana AOCS3040 Electric Single Oven
Up/Down buttons don't work
This would usually need a keypad replacement. It may come as a whole console or as part of range control board. From what I see in pictures, it appears to be an insert panel that goes into console assembly. Looks to run about 200 dollars. You will need complete model and serial numbers off oven to order correct part. These parts are usually not returnable.
Nov 22, 2007 | Amana AOCS3040 Electric Single Oven
Amana AOCS3040 Convection Oven
If I were you I would contact Amana and speak to their service dept. and tell them your problem as maybe theres a service bulliten out or a common repair and if that they would recommend someone who can fix this model.. I tryed to look up this model and I couldnt find it. If that dosent help Go to http://repairclinic.com and ask the repair guru there for assistance.. Good luck
Apr 16, 2006 | Amana AOCS3040 Electric Single Oven
Open Questions:
Amana Convection Oven control pad problem Amana AEW3530DD Electric Single Oven Logo Popular issues: * turn * convection * turn off * View All » Related Topics: * turn * convection * turn off * View Less » * Print * Email * Flag This problem should be removed because: It's spam/self promotion It's in the wrong category It's irrelevant It's illegal It's inappropriate/offensive Other Reason: Problem with Amana AEW3530DD Electric Single Oven Amana Convection Oven - Beeping Continuously my amana convection oven, bought from sears, has continually started beeping. i've had to turn the power off because of this. it was doing it a few months back and then suddenly stopped; it has now restarted. Posted by avatarBetty Emadi on Aug 22, 2006 * + Add a Comment * Suggest a Solution 1. Add a Comment 2. * By avatarGuest Over a year ago * My Amana convection plus oven has started beeping and showing an F1 error. I have to turn off the range power to make it stop. This happened just after the warranty went off, earlier this year, and the repair place ordered a new circuit panel. By chance, I turned the power back on before they came to replace the panel, it had 'self corrected. It was fine for several months, now is beeping again. Anyone have a fix? Thanks. 3. Solutions (1) F1 code and continuous beeping. This is a common problem with that type of Amana control. The control panel has a design problem I think, and it gets dirty and worn over time. I have replaced mine once, and it happened again less than 2 years later. I took the control panel out, and inspected it. I found a web solution, that said to shim the control panel out away from the housing slightly because it rubs on the metal around the opening and damages the control board contacts. I could see little scratch marks on the plastic skin around the edge of the button area, so that made sense. I tried that, and it still did not work.....panel was still beeping. Mine seemed to be the timer control that was going on and off, and then eventually an F1 error. So, I took the panel out again, and actually peeled the control surface off of the control board. No going back now, I thought. I got it off....it is really sticky.......and looked at the control panel itself . It looked fine, but there was a lot of gunk and wear marks around the edge of the plastic button area. I cleaned it up with alcohol swabs, and checked to make sure none of the printed circuit paths had any wear or damage, and then put the cover back on the board. It was still sticky enough to go back on, and stay in place. I reinstalled it, and "bingo" no more problem. It has been fine for 3 months now. Yahooo! The pic below is just an example pic from the internet. My model is slighty different, but the panel looks basically the same.
Jan 23, 2012 | Amana AEW3530DD Electric Single Oven
104 people viewed this question
Top Amana Ovens Experts
Dan Webster
Dan Webster
Sal DeAngelo
Ismael Rodriguez...
Are you an Amana Oven Expert? Answer questions, earn points and help others
