Question about Brother HL-2040 Laser Printer
Paper Curling with Brother HL-2040
Paper is significantly curled by my Brother HL-2040 printer. What can be done to prevent this? I normally use 20 pound paper. When I tried 24 pound paper the problem still existed. I do not use the printer in a high humidity environment.
  • Cram834 Jan 11, 2008
    Thanks very much for your kind suggestion. I appreciate that.
  • Anonymous Dec 19, 2008
    Same paper curl issue here and I checked the s/n and I'm way up in the M7J2xxxxx.
    the software also has a feature, "reduce paper curl" which does help, but does not eliminate the issue. Trouble is, I print some reports, then fax them. due to the paper curling upwards, it jams often trying feed into the fax machine. It's a great printer other than the paper curl issue.
  • Brother Master
  • 1,113 Answers
Replace fuser assembly/have fuser unit replaced if you have tried fresh quality paper from a unopened ream. The first versions of these had the fuser and exit assembly modified by brother to help eliminate excessive curl last 9 digits of serial number are higher than D5J760210 have already been modified, if lower ie D4Z99999 need to get mod. fitted.
Posted on Jan 10, 2008
6ya staff
SOURCE:
Why my brother HL-2040 printer is not giving licking sound on startup
Brother International Customer Phone Number Shortest Wait Best Support
Phone Number
800-284-4329
Talk to a Human
Press 7 or Keep saying "Other"
  • Call Time
    Average Wait: 8 mins - 24 hours, 7 days
Oct 02, 2014 | Brother HL-2040 Laser Printer
Red paper light is on even though there is paper in the tray. brother 2040 model.
This is a paper jam. Remove paper try as well as the toner/drum unit. Take vacuum and clean out inside the printer. Separate the toner & drum units and vacuum-blow out the drum unit to get it clean. Run the drum wire cleaner tab (purple/blue tab at front of the drum unit) back & forth a number of times. Sounds like you've got a piece of paper stuck inside somewhere. In the back of the printer, there is a door that will open out and down...check here for a speck of paper that is causing the paper light to come on...it "sees" something is in the way) since this is where the paper curls up and out the top. Reassemble toner/drum unit. Before you put the paper tray back in, take a piece of paper and feed from the front (use light card stock or heavy weight paper since this will help push out anything inside that's in the way) and print a few pages this way. Then, make sure your paper is dry (hasn't been in humid area) and is lying flat (not curled at edges). That should do it
Dec 21, 2009 | Brother HL-2040 Laser Printer
I have a Brother HL-2040. The "paper light is on & won't print.
Sounds like a paper jam. There's a flap at the back of the printer-once open you should be able to see if the paper is stuck there. (Exactly the problem I had yesterday-I didn't spot it at first and it nearly drove me mad! :)
Good luck,
Raf
Nov 13, 2009 | Brother HL-2040 Laser Printer
FUSER TROUBLE HL 2040
This is a paper jamb problem. There is a piece of torn paper stuck in the paper path that is stopping the printed page from exiting properly.
Sep 30, 2009 | Brother HL-2040 Laser Printer
Paper is curling when it comes out of printer
either your using a poor quality paper or the heating element of the printer is malfunctioning.
Sep 17, 2009 | Brother HL 5250DN Laser Printer
Can the Brothers HL 2040 handle printing 65lb
It probably can but only from the front slot, the paper tray has to bend the paper around the roller in the front when feeding.
Aug 28, 2009 | Brother HL-2040 Laser Printer
Paper Jam lite is on ( no paper jam )
did you try turning it off and then back on?
May 27, 2009 | Brother HL-2040 Laser Printer
Paper curl
Paper Curl. Does the paper have a curl on the trail edge? (The last part of the paper to exit the printer)
If it is the entire paper replacement of the fuser will likely resolve this.
If the paper curl is on the trail edge then replacement of the upper delivery roller should be done.
Nov 03, 2008 | HP LaserJet 4 plus Printer
Brother HL-2040 Flashing Paper LED
Try send one paper manually, then it will pick up paper from the try automatically.
Feb 06, 2008 | Brother HL-2040 Laser Printer
Brother HL-2040 Laser Printer Logo
1,745 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Jim Keysor
