Question about D-Link DSL 500 (DSL-500) Router
Constantly locks up and loses connection under moderate traffic(3 users max) never recovers only solution available is to reset
  • D-Link Master
  • 32,281 Answers
There are a few things that can cause you to lose wireless connection with your wireless router.
1. Weak signal strength, check the signal strength on your wireless card. If it is weak move the wireless router away from walls and if possible locate the wireless router higher up.
2. Have you secured your wireless router from people near your from unauthorized access? ie. change the default password, setup encryption use WPA2 or WPA, change the default SSID, and turn off SSID broadcast, and for added protection, enable MAC address filtering which allows only the MAC address/es of your wireless card/s to connect to your wireless router.
3. You could be getting interference from electrical sources such as air conditioners, arid welders, washing machines etc. If so the power supply to the wireless routers and computers etc should be connected to a surge protection power board, better still connect your computer equipment to an UPS (Uninterrupted Power Supply)
4. Check the channels of the wireless routers and access points in your area and change the broadcast channel on your wireless router to an unused channel or one that is currently used but has the weakest signal strength. This will minimize interference with your wireless router from other wireless routers and access points in your area.
Posted on Nov 18, 2009
I forgot ip address and password and want to factory reset
Connect the console cable, open a connection to the serial port via a utility such as PuTTY, and do the following:
1) Enter the user name "recover" and password "recover" to place your unit in password recovery mode. The unit will remain in password recovery mode for 30 seconds max.
2) Perform a hard reset by removing power, waiting 10 seconds, and then re-applying power.
3) Once the switch has rebooted, enter a new password for the "admin" user account.
4) Enter enable to leave password recovery enabled, or enter disable to turn it off. You are now logged in as the default "admin" user.
Note: If password recovery has been disabled, the only way to recover access is to return the switch to 3com.
Apr 20, 2013 | 3Com Baseline Switch 2924-SFP Plus
Tip
Top 3 Windows Vista Password Recovery Measures
If you've forgotten password on Windows Vista and cannot log on your computer again, you need to perform Windows Vista password recovery to bypass your lost Windows Vista password. But the problem for you is that how can you recover the password and will it be difficult to perform Vista password recovery? Below is a step-by-step guidance for you to recover Windows Vista password with 3 different methods.
Method 1: Perform Windows Vista password recovery with password reset disk
Windows Vista allows you to create a password reset disk with a USB flash drive in a few seconds. It can help you reset Windows Vista password when you forget it. Just try to recover Windows Vista password as follows if you have a Vista password reset disk at hand.
1. Start your computer and get to the Windows Vista login screen.
2. Type a wrong password, and then Reset password link will appear on the Vista login screen.
3. Click Reset password to enter to Password Reset Wizard screen, and then click next.
4. Select the right disk if you have more than one password reset disk, click next.
5. Type in a new Vista password and password hint, click next.
6. Click Finish when you've successfully reset Windows Vista password.
Method 2: Perform Windows Vista password recovery on safe mode
In addition to reset Windows Vista password with password reset disk, you can also recover Windows Vista password on safe mode. And the presupposition is that you have can log on computer with another Windows Vista administrator account.
1. Press F8 when your Windows Vista PC is booting. You will come to the Advanced Boot Options.
2. Select Safe Mode with Command Prompt and press Enter.
3. Enter safe mode with an available admin account. And a command prompt will appear.
4. Type net user in command prompt and press Enter. It will show you all accounts on the Windows Vista.
5. Type net user Mike 123456 (Mike is the locked admin account's name and 123456 is the new password. This depends on the setting of your computer) and press Enter. Now you have successfully created a new password on the locked admin account.
6. Type shutdown -r -t 00 and press Enter.
7. The computer will reboot automatically and then you can log on Windows Vista with the new password.
Method 3: Perform Windows Vista password recovery with Windows Login Recovery
Windows Login Recovery is efficient Windows password recovery software designed to recover Windows login passwords for any version of Windows, including Windows 7, Vista, XP, 2003, 2000, NT, 2008. It is not necessary for you to reinstall the system when you forgot or lost your Windows login password. But a blank CD/DVD or USB flash drive and an available computer with optical drive is required before starting to perform Win Vista password recovery as below:
1. Download Windows Login Recovery and install it in any available computer.
2. Run the program and insert a blank CD/DVD or USB flash drive into computer. You will see a default path of an ISO image file after running the application.
3. Select CD/DVD or USB drive to burn the ISO image file and click Burn.
4. After burning, insert the CD/DVD or USB drive to your locked computer.
5. Set the locked computer to boot from CD/DVD or USB drive. After setting BIOS to boot from CD/DVD or USB drive, the computer will restart automatically. And then you can recover Windows Vista password under DOS.
6. Choose the installation path of Windows, and enter the ID of the path.
7. All the user names will be displayed for you, and you can select one to remove its password by entering the ID of User Name. And then enter y to confirm your operation.
8. After removing the selected password, you can enter y to continue to reset other passwords, or enter n to finish.
9. After entering n to finish, eject the CD/DVD or USB drive and press any key to restart the computer. Now, you can log on your PC without password.
The above 3 methods can help you perform Windows Vista password recovery easily and safely. It is no need for you to worry if you forget Windows Vista password. Why not try this amazing Windows password recovery software to recover Windows Vista password instead of reinstalling computer?
on Sep 09, 2010 | Computers & Internet
How to reset Lenovo Windows 7 password
Forgot Windows password?Lost admin password? Have been locked out of computer?
Lost computer login passwords, which is a common problem for the computer users. So there are many solutions. One of the popular solutions is as following,
1.log on a computer that is linked to internet.
2. Free download Windows Password Recovery Tool 3.0
3.Burn the downloaded .ISO file onto a blank CD
4.Insert newly created CD into the locked computer and then reboot it
5.select the account you wanna reset the password.
Jun 25, 2012 | Lenovo Computers & Internet
I forgot my password and dont know what it is or how to unlock it can you help
Hack HP Computer Password ' Erase HP Desktop / Laptop Password Without Being a Hacker
  • In my received E-mail that people ask to recover lost PC password, a quarter of people are using HP computers. So I prepare this tutorial specially for these HP users.
Apr 18, 2011 | HP Pavilion ze4400 Notebook
I have forgot my dell inspiron 1545 HDD and Admin passwords; I don't know what to do? Please help me. Thanks in advance.
In consideration of remaining all programs and data of the computer,I recomend you to use a passowrd tool:Windows Password Rescuer.It supports all versions of windows operation system.Recover Windows password without lose anything.Here are the simple guide:
Step 1: Download Windows Password Rescuer Personal and install it in any available computer
Step 2: Burn a bootable CD/DVD or USB flash drive
Step 3: BIOS settings of your locked computer to make it boot from CD/DVD or USB flash drive
Step 4: Reset Windows password successfully.
You also can use Windows Password Rescuer to add a new user with administrator privilege to your Windows. With this New user account you can logon your locked computer directly to copy important data from the locked computer if you want to reinstall your Windows system at last.
When you finish two steps, you can login your windows quickly without any password.
You also can reffer to this article: Recover Windows admin password safely and quickly.
Feb 19, 2011 | Dell Inspiron 1545 Notebook
What tool do you recommend if you forget your VISTA password?
For recovering Windows logon Password safely, I recommend software program Windows Password Seeker. Not only support XP/Vista/2000/NT, but also compatible with windows 7, it works perfectly to remove Windows logon Password. I wrote it to a Usb memory card. Booting up and clearing my password within just 4 minutes. You can Search Windows Password Seeker or download it from:http://www.passwordseeker.com
Aug 28, 2010 | Microsoft Windows Vista Ultimate Edition
Needs really badly help forgot the password for "password authentication system u cannot access the data on this computer without correct password!!!
Here's how to reset your password:
  1. First reboot Windows XP in safe mode by re-starting the computer and pressing F8 repeatedly as the computer starts up.
  2. Then (in safe mode) click Start and then click Run. In the open box type "control userpasswords2" (without the quotes, of course)
  3. You will now have access to all the user accounts, including the administrators account and will be able to reset the lost password.
  4. Just click the administrators user account (or the target user's account), and then click Reset Password. You will need to add a new password in the New password and the Confirm new password boxes, and confirm by clicking OK.
  5. All done, you have recovered the lost password
Hope you'll have it resolved soon :-)
Jun 27, 2010 | Dell Inspiron B130 Notebook
Espresso machine loses steam than recovers in minutes
It sounds like a heating element issue. Those elements look like a single unit but are actually made up of 2 or 3 independent heating coils - one may not be working. So, you're only getting 1/2 to 2/3 heating capacity, which isn't noticeable until the machine is under heavy steam load.
Dec 11, 2008 | Nuova Simonelli Program VIP Coffee Maker,...
Log on password not known
try administrator and admin or password or just leave it blank
Apr 21, 2008 | Computers & Internet
D-Link DSL 500 (DSL-500) Router Logo
122 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
