Question about Lionel Trains Classic Freight Train Set
How do I disassemble lionel fast track? - Lionel Trains Classic Freight Train Set
When I my brand new Lionel train on the track, the red light goes out. Is there a short in the loco?? This isa the Polar Express 73-0218-250 model Xmas is tomorrow!!
I am assuming that the throttle is off when you put the train on the track. If off, then you are correct that there is an internal short in the engine. You might try disassembling the unit and looking for a pinched wire specifically from a roller(s) (center rail pickup). You might also check for a short between a pickup roller and a wheel with a VOM. Make sure the wheel is not the one with the neoprene belt.
Dec 25, 2014 | Lionel The Polar Express Train Set
The Lionel lines train is going too slow and it
time to clean & lube your train & track.
here's a couple link's that should help :
Maintaining Your Lionel Trains
Cleaning Track
Nov 11, 2014 | Crafts & Hobbies
Lionel toys
see attached pdf.
Jan 19, 2014 | Lionel Crafts & Hobbies
Looking for instructions for lionel fast track automatic switch
Try contacting the Lionel Service Department on
586 949 4100 or use their website contact service. Contact Lionel Trains
Oct 12, 2013 | Crafts & Hobbies
Check out these Lionel Customer Service Videos.
http://www.lionel.com/CustomerService/service-documents/video.cfm?documentID=6334
http://www.lionel.com/CustomerService/service-documents/video.cfm?documentID=6337
Dec 31, 2012 | Lionel 6-30068 North Pole Central...
CANNOT GET THE UNCOUPLING TRACK SECTION TO WORK THRU TRACK POWER - WHAT IS PROPER WAY TO HOOK UP RED AND BLACK WIRES? LIONEL FASTRACK
Track power is not recommended for this uncoupler. Use an aux fixed supply of at least 10 to 13VAC for the supply. You have to move a jumper on the bottom of the track to do this. Then there will be four wires needed. Two for the aux power (hot and common) and the other two which go to the pushbutton switch.
Note: Same goes for Lionel FasTrack Remote switches. Run the switches from a 10 to 12 VAC aux supply. There is a jumper you remove on the bottom of the switch to connect an aux supply.
Apr 27, 2011 | Lionel 12020 Fastrack Remote Uncoupling...
My new lionel train slows down on far side of the track
There is bad contact in the track connections. You can sand the track connection sites. Another method is to run another power wire to the other end of the track where the train slows down. Even better is 3 or 4 evenly spaced power wires from the transformer to the track.
Jan 26, 2011 | Lionel New Haven Freight Train Set
Need lionel trains on track instruction manual for nintendo DS
I have uploaded the On Track manual to scribd.com.
Look here:
http://www.scribd.com/doc/76894727/Lionel-on-Track
or search for lionel_on_track.pdf
Nov 23, 2010 | Lionel Trains: On Track for DS
Ι've just joined 2 ovals 40x60 lionel fastrack, used some other items 2 Lionel 6-12018 FasTrack O-36 MANUAL SWITCH RH, 2 Lionel 6-12017 FasTrack O-36 Manual Switch LH, A few 6-12014...
It sounds as though you may have two defective transformers. Lionel has reported problems with some of their smaller transformers. I would have the transformers and the engines checked by a Lionel service station or contact their customer service department for help.
Nov 12, 2010 | Lionel 40 Watt Transformer Train Set Track...
Lionel Trains Classic Freight Train Set Logo
394 people viewed this question
Top Lionel Crafts & Hobbies Experts
Jeff Hogancamp
Jeff Hogancamp
ray gallant
Traindoc
Level 1 Expert
Are you a Lionel Craft and Hobby Expert? Answer questions, earn points and help others
