Question about Elna Sewing Machines
I have an Elna Carina Electronic SU sewing, looking for quilting
I have an Elna Carina Electronic SU sewing machine. I am looking for a quilting foot - S 425.341 that is listed in my manual. Can you assist me in finding this part? I realize my machine is older but it still works beautifully and cannot afford a new machine at this time. Thank you
  • 155 Answers
SOURCE: I need to thread an
Needle Faces Where?
I Need to Tighten the Tension....
Changing a Needle
Need Help
Basic Questions-
Bobbin Assembly Popped Out!
Do You Think My Machine is Fixable?
How to Change a Broken Needle
Needle Bar Adjustment
Oiling an Elna 3007
Getting the Timing Belt Off?
What Size Needles for My Machine?
How to Oil my Machine?
Where to Oil??
Stitch Length Knob Woes
Can't Seem to Put the Bobbin in Correctly
Timing Belt Tension
Adjustments
Running Very Slow-
Oiling Points on Singer 257
Oiling My Singer Touch & Sew
Singer 457
Featherweight Case Odor
Brother XL2010 Q's
Does My Machine Have More Than One Belt?
Cannot Seem To Adjust the Tension
What to Do About a Gumming Up Needle
How Tighten My Bobbin Tension, Please
Is it Covered Under Warranty?
Proper Threading Instructions?
Just a Foot Pedal?
Simple Threading Instructions for a 1036
Threading a Singer 600
Replacing a Blade on a Johnson Ruffler
Changing the Needle
Lubricating a Singer 1036
Thread Balling Underneath
Warranty Info
Machine Covered in Hardened Oil
Spindle Stuck?
Do Motors Die?
Singer 457
Brother Sewing Machine
Servicing My Machine-
Belt Replacement
Lubricating My Sewing Machine
check out this thanks.
Posted on Oct 26, 2008
  • 11 Answers
SOURCE: Elna walking foot
If your SU is an Air Electronic model i.e. 80's model, Elna didn't make a walking foot to fit. However, if you've got a walking foot that is the same height from sole plate to the screw fitting as a standard Elna foot then you could give it a try. The walking foot connects to the presser bar with a screw but the needle bar also needs to hook into a secondary lever on the side of the walking foot to make the foot actually move. Probably sounds very confusing . Check the movement of the foot manually by hand turning the fly wheel to see how it works before you actually use with the motor to minimise any problems if the foot doesn't fit.
Also you'll probably only be able to do straight stitch with this foot due to the clearance around the needle plate.
Posted on Oct 28, 2008
SOURCE: have a 1970's elna su supermatic but cams don't work
There are two types of discs - single and double.
For the thinner single discs do as follows:
1.Turn stitch width knob to "0"
2. Turn stitch length knob to "0"
3. Insert the single disc
4. Turn the top selector to "A"
5. Make sure the needle selector is in the centered position.
6. You may now choose any stitch length or width you wish. I usually try "3" for the width and 1/2 for the length to start.
For the thicker double discs do as follows:
3. Insert the double disc
6. You may now choose any stitch width.
7. The stitch length must be put on "A" - this is the difference between the single and double discs!
I hope this helps!
Posted on Apr 09, 2009
Tally Girl
  • 1133 Answers
SOURCE: Elna Carina service
Search yellow pages for local sewing machine repair men, then ring them and ask if they can replace the capacitors on your machine. If they start talking knowledgably about the Carina then I'd take it to them. In user groups, these types of technicians are called OSMG (old sewing machine guy) and they are worth their salt. There is also White Sewing Center in USA. website www.whitesewingcenter.com, and they specialise in Swiss Elnas.
Posted on Jun 16, 2011
Tally Girl
  • 1133 Answers
SOURCE: Elna Carine Electronic Sewing Machine
You should be able to buy a manual online but it may be a cd or image pdf file. Try www.sewingpartsonline.com or www.sewusa.com. If they don't have the Carina but have the Air Electronic SU, model 68 then this will be almost the same. Main difference is the Carina has the needle up/down button.
Here is threading up images to get you started.
Posted on Sep 28, 2011
Hello, Please can you tell me how to lower the dogs teeth on Elna SU airelectronic 68 so as to do free hand embroidery. Thank you julie Roberts
The owner's manual would have that information. If you don't have it, here's one:
Instruction Manual Elna 68
unfortunately, Elna manuals are usually not free
You could probably also ask your Elna dealer how to do darning on your machine. You will also need a darning or free motion quilting foot for your machine. Your machine either has the ability to raise/lower the feed dogs or the machine came with a darning plate to cover the feed dogs.
The following video series may have some information:
Vintage Elna Air Electronic SU Sewing Machine Series Part Overview
Nov 13, 2017 | Elna Sewing Machines
Did Elna Carina SU 66 originally come with a straight stitch foot and throat plate?
No, the Carina came with a standard zig zag plate and 5 feet I think from memory, the teflon coated foot , the embroidery foot, buttonhole foot, zipper foot and darning foot.
Nov 16, 2016 | Elna Sewing Machines
ELNA CARINA FOOD PEDAL NOT WORKING
Elna Carina has an air electronic foot controller, so you need to firstly check the air line coming from the round air pedal has no holes, is not crimped or squashed under the chair leg. Hold the plug end against your hand or cheek, squeeze the round bulb and see if you can feel a puff of air coming from it. If no, then check the air control black membrane for a hole, ditto the air line hose. You can still buy parts from sewingpartsonline.com for these Elna Carina Electronic 66 Parts . If the line and foot pedal are sound, then the problem lies on the internal actuator which is inside the right side panel of the machine. You can remove this panel by undoing two screws on the side (disconnect from power first!)
The panel will remain connected to the machine body by some cables, you may be able to check out the actuator and see if it is faulty. If its just a tiny hole in it, it might be repairable with a drop of superglue. For parts/service in the USA, Whites Sewing Center is the Swiss Elna specialist, and they may have spare parts in stock.
Feb 09, 2015 | Elna Sewing Machines
Elna carina snap on presser feet
Yes, any low shank should work. If it doesn't you can always regift it to someone.
Oct 27, 2017 | Sewing Machines
What make of walking foot would fit my Elna su air electronic sewing machine, thankyou
You need a low shank style walking foot. Even back in the 80's when your SU air electronic was new, the walking foot sold by Elna was an after market one, and not made by Tavaro. Same with the ruffler attachment, it was after market and actually fitted quite a few makes of machine.
I would just ask the dealer/shop if they will refund your money if you find it doesn't work just in case.
There is a low shank one on sewingpartsonline.com
http://www.sewingpartsonline.com/walking-foot-low-shank-p60444.aspx and they list the SU as compatible with it.
Take off the foot holder on your mache, and you need to fit the little open ended arm over the needle bar and the foot bracket onto the foot with your machine's regular thumb screw. The up and down movement of the needle bar operates the walking foot.
Jun 25, 2011 | Elna 2007 Mechanical Sewing Machine
I need an instruction manual for the Elna Carina Electronic sewing maching
There is a sewing guide available free here for the SU which is very similar to the Carina
http://www.arizonaexpressionz.com/elna_instruction_manuals/SU_air_electronic.pdf
but not an instruction Manual.
The SU, Carina, 500 and Jubilee all came with two books, instruction manual and sewing guide.
Oct 25, 2010 | Elna Sewing Machines
Elna su flywheel won't turn.
On the Carina SU there is a button on the flywheel to disengage when winding a bobbin. Be sure this button is pushed in.
Mar 05, 2009 | Elna 2007 Mechanical Sewing Machine
Sep 21, 2008 | Elna 8007
Sewing Machines Logo
275 people viewed this question
Top Elna Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Are you an Elna Sewing Machine Expert? Answer questions, earn points and help others
