Question about Nikon Optics
Elevation is turned all the way up and at 50ytards
Elevation is turned all the way up and at 50 yards im still shooting 3" low
    Problem Solver:
  • 17 Answers
Also a common fault is incorrect mounting.
take scope out of the mounts
mount the bases to the rail, position them, tighten them up
place scope in mounts, align scope and put rings on finger tight
recheck the alignment, use a spirit level an plumb line if you need to, and tighten the rings in a criss cross pattern, (not enough to damage the scope though)
I have come accross many poeple connecting mounts to the scope and then to the the rifle.
If that doesnt work, try swapping the front and rear mounts around.
Then resort to packing shims under the rear mount.
hope this helps
Robbie
BSA owners group
Posted on Nov 19, 2009
    President:
  • 2,702 Answers
This is a common fault with fitting cheep mounts on your rifle,,
a nikon scope is realy for "air rifles" but having sead that there very strong scopes, i have 4 of them all fitted on full bore rifles,,308,(7.62) .303 british enfield, .22-250 and a 357 mag rifle? and none of them have shook apart yet! and i found that on a full bore they do shoot low,,,to get over this problem you could change the mounts to the ajustable type witch is pricy,,or a cheep way out is to pack the bottom of the rear scope mount out with a strip of 35mm film,,(the rear being the end you look throw),you only need to life the rear end of your scope 25th of an inch to rise its point of impact by 6" inchs at 100 yds as the nikon scope is one click (1 thou of an inch) = 1/4 of an inch at 100 yds so 25 thou will raze it by 6.25 inches (- bullet drop!) just undo the scews that hold down the rear of the scope and slip a bit of old 35mm film under the scope then nip the scews back up again and try it out,,,if its still low put in a bit more packing,,,but you can only get about 4 bits of film in before its likley to bend the scope tube!!! mind you with 4 bit under it you will be shooting at the moon??? its much cheeper that ajustable mounts,, all my scopes are packed out like this and they dont creep or slide or loos point of aim even after 300 rounds in a day?
Posted on Nov 18, 2009
My 3x-9x.40 scope shoots low and to the right,what does one click on elevation and wind represent?
Most scopes of this type move the bullet impact 1/4 inch at 100 yards, or 1/4 minute of angle.
Sep 19, 2010 | Tasco 3-9x40 World Class Riflescope 30/30...
Keep having to resight scope
Sounds like they are right. The cross hair adjustment mechanism may be defective. I'd call bushnell and see what they can do for you.
Bushnell Corporation
9200 Cody
Overland Park, KS 66214-1734 Kansas City area - (913) 752-3400
Consumers - (800) 423-3537
Dealers - (800) 221-9035
Fax - (913) 752-3550
Apr 08, 2010 | Bushnell ® Elite® 3200 3 - 9x40 mm...
I inadvertantly changed my elevation adsjustment.
this is an excellent article on zeroing a scope.
http://www.outdoorpros.com/How-To-Guides/How-To-Zero-A-Rifle-Scope/5
Apr 06, 2010 | BSA ® 2 - 7x32 A/O Sweet 17?? Rifle Scope
How do I adjust the elevation?
I suggest that you, consult the manufactures model to rectify the issue
Dec 20, 2009 | Barska Optics Barska Varmint Riflescope...
I can shoot my centerpoint scope on my .22 and it
When adjusting a scope just move a few clicks at the time, after every few clicks tap the scope with a screw driver handle. Fire 2 rounds for group tap and fire the third round it should be in line with the 2. Keep that up till on target. Let the gun sit till cold and re-fire for grouping, 2 rounds, wait then the third. To keep shooting round after round can get the reciver warm enough to wedge the scope in its bases, causing your problem.
Oct 13, 2009 | Optics
Scope elevation adjusted allthe way up & still shoots low
Bushnell sells nylon inserts for scope rings that fit inside of the scope rings and will affect the height of the ring to correct the problem. If you install them on the front scope ring, it will correct it and realign the rings correctly. It appears that the front ring towards the muzzle is not as high as the rear ring near the breach. This is why that even though the scope's adjustment is elevated as high as it will go, it is still hitting low because it is actually pointing down because apparently the rear ring is higher off the barrel than the front ring. The Bushnell inserts can correct this.
Aug 23, 2009 | Bushnell BANNER RIFLE SCOPEPower: 3-9X40 /...
Hello, I have a Ruger 10/22 Target rifle with a Bushnell banner scope on it. It seems that the farther the shot the higher it shoots. I am 1'' low at 15 Yds 5 '' high at 50 yards. What the?
Hi.
http://www.rifleshootermag.com/shooting_tips/ballistics_0303/
this explains why the bullet seems to rise and fall at different distances. its not unusuall infact it will happen in 99.9% of firearms unless the firearm is set to a "Flat Trajectory" zero.
It seems like your fairly new to shooting and the "Exterior Ballistics Effects on a Bullets Trajectory"
my suggestion is that you take the time to read and DL or buy this software.
Sierra Infinity V6 Ballistics Software (i Dl'd it) and it is fantastic.
along with that they have a long range shooting simulator that will teach you about the mathematics of shooting and allow you to get some in expensive practice away from the range and prying eyes. This software will teach you to
1) Range a target just by looking at it in the scope
2) determine Elevation adjustments
3) Windage Adjustments
4) Accomodate the most daunting of variables for the amatuer shooter the weather
(any shooter can learn how the gun fires on a perfect day. it takes a good shooter to take into account the Barometrice Pressure, Humidity, Elevation (from sea level), and Temperature. And be able to hit the first time)
Regardless of your skill level this software is indispensable it will teach you the cores you need to know for when your software is broken or your pc is broken or its just not fiesable at the time.
it will increase the range from which you can shoot. (in 4 hrs i was shooting to 6oo yards, in two days 2100 yards)
ill check back incase you need other info like how to determine zero by inches of center
Apr 06, 2009 | Bushnell Optics
Cannot sight in riflescope for elevation, adjustment is maxed out
Try reversing the rings. Move the back one to the front, and the front one to the back. Turn your elevation adjustment, back to -0-, and start again.
Feb 01, 2009 | Bushnell BANNER RIFLE SCOPEPower: 3-9X40 /...
I have a Bushnell Sprotiew 4x, 15mm scope mounted on a Mossburg .22 rifle. My shots are hitting left six inches and low. Can you please tell me how to adjust this scope? Thank you.
Keep in mind Diane this is for a set distance. if you are taking a shot at a target further than your are set for (ie a target you wont get 3 shots @) remember how the bullet is travelling as it goes down range
one idea would be to set your rifle up down range and zero it in on a target (preferably paper) now adjust 1 MOA (try and have target @ 100 yards and 200 yards)
see how far the bullet moves for each moa adjustment. then check it against the next range.
this should remain constant @ a set number of inches per 100 yards.
so if you zero in @ 100 yards and then move 1 moa any direction and it adjusts (lets say and hope it is 1.047 inches") then you do the same for 200 yards. it should be twice as much movement. ie 2.094"
once you know what 1 moa represents on your scope you can adjust alot more accurately.
REMEBER the total inches of movement / adjustment per MOA is directly related to range (a precise range helps in shooting) so if your squirrel is 150 yards and your first shot is off 9" to adjust you divide 9" by the inches per moa so 1.5 (150 yards /100) X (Inches per 100 yards per moa you measured hopefully 1.047") its 9" divided by 2x1.047 = 9" / 2.094 = 4.29799
this number needs to be rounded to the nearest click on your scope (most are 1/4 MOA scopes and you can tell by looking at how many clicks/lines are inbewteen each large number on your windage and elevation dials
so to turn this into an adjustment we round 4.29799 to 4.25 which is 4.25 MOA or 17 clicks on a 1/4 min scope.
GL and any questions just post and ill help
not please rate this as fixya :)
Note i can provide EXACT information that would allow you to determine range, and windage and elevation adjustments by looking through scope and estimating range
then factoring in weather variables. NOTE you hafta enjoy math or just want to know how to shoot really well. :)
Dec 22, 2008 | Barska Optics Barska 10-40x50 Ao Varmint...
Optics Logo
347 people viewed this question
Top Nikon Optics Experts
Mark Campeau
Level 1 Expert
Are you a Nikon Optic Expert? Answer questions, earn points and help others
