Question about Fisher and Paykel GWL11 Top Load Washer
Fisher and paykel washer doesnt turn on. no power . power at wall outlet
  • 60 Answers
There are solder in slow burn fuses located on the circuit board that can burn out if the pump gets clogged or broken and some other reasons that you can buy from Mouser electronics using p/n (mouser) 576-37416300410 or Mfg p/n 37416300410. The fuses are reddish, round cylinders about .5 inch high and wide. Anyone who can solder can easily fix this. Be sure to tag any connections that you remove although all you need to do to get the circuit board out to work on it is remove the small rubber hose and 2 electrical plugs connected to the board through the outside cover. There is paperwork inside the head of the machine (and there is the circuit board) with fault codes to help you determine what your specific problem could be but I had a no power problem recently and replacement of these 2 fuses fixed it. Let me know if you need further help!
Posted on Nov 22, 2009
  • petertrast Feb 09, 2010
    I get a 2 rating for giving you the right answer??? lol... glad I didn't give you the wrong answer...
  • 4 Answers
Curcuit board is bad
Posted on Nov 19, 2009
Gwl10u2 fisher paykel washer iwl15 can't get it to turn on? Checked the outlet,it's ok. Tried another outlet, still nothing! Help!!!
the fuse on the motor controller has blown. you can replace this fuse, but you will most likely have a short circuit / fault in the pump or motor. check for signs of wear on these, and check for earth faults before re powering machine with new fuse / motor controller.
Sep 17, 2013 | Fisher and Paykel GWL11 Top Load Washer
Fisher & paykel gw612 washer constantly trying to drain
The pump triacc in the motor control board needs to be replaced
by a technician, it's cheaper than getting a new board.
Apr 22, 2013 | Fisher and Paykel Fisher & Paykel Washer
Fisher n paykel nemo dishwasher won't go. Sounds
Check to see that the outlet pump (underneath) isn,t stuck eg sumething stopping the pump from turning.Also check that the outlet is clear where it connects to the sink outlet.Hope this helps.
Dec 13, 2009 | Fisher Dishwashers
Fisher@paykel Intuitive eco comes up with code 130 what is it or how do we fix it
rotary position sensor fault. underneath the machine. Unbolt plastic cover with 16mm socket all of the plastic will come off. Undo four 10mm bolts around shaft. Pull off the big round thingy with cooper wire on it carefully. The purple wire is connected to the sensor which looks like a computer card and fits between the copper things ,pull up the sensor carefully and unpug the connection clean off the blue stuff on contacts,use electrical spray cleaner. Put back together in reverse.
Comments: Aug 03, 2009 - if it still doesnt work reset the machine by turning it off at the wall and waiting 2mins and start again. If that doesnt work the sensor may need replacing.
Jun 26, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher paykel washer
please check the door of machine
Jun 06, 2009 | Fisher and Paykel GWL11 Top Load Washer
After power outtage my f/p washer is dead -no lights nothing
Only reset is to unplug it. Are you sure you have power at the outlet? If you have 120V at the outlet the power surge may have blown the controller, not a cheap fix :(
Apr 12, 2009 | Fisher and Paykel Fisher & Paykel Washer
Service/error code 130 on Fisher & Paykel intuitive eco washer
Jan 24, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Power wont go on fisher paykel eco smart GW11
first step is to make sure you do have power to your washing machine.
if you press your power button and you dont get any response,you will find the your electronic have gone.
Its called a power module.
They do have fuses in them.
Jul 31, 2008 | Fisher Paykel EcoSmart GWL15
Fisher Paykel Washer Machine
sounds like the main board has died check for water leaks near board or motor/pump.
Nov 29, 2007 | Fisher and Paykel GWL11 Top Load Washer
Fisher and Paykel GWL11 Top Load Washer Logo
416 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
marley mcelhinney
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
