Question about Fuji FinePix Z10fd Digital Camera
I have a furjifilm finepix z200fd camera. I actually have two of them. I bought one and had it a year and it just stopped turning on one day. I bought another, cuz i liked the camera and just thought it was something we did to break the first one. a few months later the second one just stopped turning on. i think it may be the slider to that you slide to turn it on. Is there any ideas on what to do to fix it?
5 Suggested Answers
  • 5 Answers
SOURCE: I purchased a Fujifilm finepix Z20fd camera from
have you tried putting your battery in different ways and did you push it in all the way to hear it click
Posted on Nov 12, 2009
  • 11967 Answers
SOURCE: Fuji FinePix A345 Digital Camera lens is stuck, I
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Dec 17, 2009
Testimonial: "Thanks a lot, this is a F**king great solution, man you should post it a tip or something it's grat "
SOURCE: My lcd screen on my finepix s1000 fd seems to have
Try pressing the EVF/LCD button. It could be that you've mistakenly changed to the view to viewfinder only???
Posted on Jan 13, 2010
SOURCE: Finepix j38 zoom error
I Fixed mine a few times what i did was turn it on it would scope out and back hold it and keep it from going to back in then go to pictures then exit it should be working fine now
Posted on Jun 06, 2011
My fuji finepix s5600 shuts down when i want to take pics,
Try cleaning the battery contacts in the camera first with a pencil eraser and then with a cotton swab lightly dampened with rubbing alcohol.
Jan 07, 2010 | Cameras
Hi there, i recently bought a fujifilm finepix f50 camera from walmart but when i got it home i realized it did not have the qualities i wanted, so i went to future shop and bought the F70EXR which i...
Walmart's return policy reads as follows: Exceptions to 90 Day Return Policy:
  • 45 days with receipt: Computer components and computer accessories.
  • 30 days with receipt: Camcorders and digital cameras.
Nov 10, 2009 | Fuji Finepix F50FD Digital Camera
My FinePix J10 is not working even after changing the battery
Your son probly jamed it in there to hard then the spring mybe broke
Jan 30, 2009 | Fuji FinePix J10 Digital Camera
My Camera Won't Turn ON
I'm one who had the same problem but I just noticed that if I hold my finger down firmly on the "ON" button for a few seconds the camera finally turns on. Please let me know if this also works for you. Maybe it's the answer for all of us!
Jan 24, 2009 | Fuji FinePix J10 Digital Camera
Camera Won't Charge
my finepixz3 got wet. but after a few days it worked! but when the battery ran out it wont charge. is it the battery? it turned on a few sec when its in the cradle but it wont last after a few seconds it would turned off. is it the battery or the camera itself?
Sep 01, 2008 | Fuji FinePix Z3 Digital Camera
Camera mode won't come up. . .
Just a quicky, this happened to me whilst in warranty and it required a replacement PCB (printed circuit board). Sorry for the bad news
Dec 14, 2007 | Fuji FinePix S5000 Digital Camera
I hav fuji a330 and it stops as soon as i clik
My sister & I bought this same camera for our mom & she has had this same problem from the very 1st day.... I've researched it, and the onlysolution I've found is to purchase a 3V DC Charger for the camera. This will bypass the battery issue all together. I hope this helps.
Oct 31, 2007 | Fuji FinePix A330 Digital Camera
Fuji FinePix Z10fd Digital Camera Logo
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
