Question about Bulldog RS-1100/GM-12 Remote Starter & T-Harness Kit
Model rs1100 when i completed the wireing and pluged in the red +wires all i get is a clicking noise
  • 389 Answers
The unit is in "safety mode" . To exit safety mode on 4 Button Remote, ground the hood pin switch if installed, press and hold the brake and push any button on the remote the clicking should stop. Take the ground off the hood pin switch and release the brake, then test the remote.
Posted on Dec 30, 2009
I installed a bulldog RS1100 remote starter. Afterwards when I tried to remote start it the only response I received was the parking lights flashing three times.
Check that the blue wire goes to the -input. If it is then check each of your other wire connections to be sure they are secure and have not slipped.
Dec 14, 2014 | Bulldog Vehicle Parts & Accessories
Install bulldog rs1100 remote starter
Maybe a relay stuck on closed?
Nov 25, 2013 | Cars & Trucks
I need to be walked through installing a Bulldog self learning anti theft bypass module 791 on 2007 GMC Sierra 2500 HD SLE. Thanks!
Here have information about #791 bypass module: Bulldogsecurity Model791
IF YOUR REMOTE STARTER IS CLICKING AND/OR FLASHING THE PARKING LIGHTS AND IS NOT RESPONDING TO THE REMOTE, IT IS IN SAFE MODE AND NEEDS TO BE INITIALIZED BY DOING THE FOLLOWING:
If you have a 4 button remote, you must ground the black/blue hood pin wire (raise hood if hood switch is installed). Apply 12volts to blue/black brake wire (press and hold brake pedal if wire is installed). Press and hold any button on your remote until clicking and flashing stops. Unit will now respond to the remote. Remove ground from hood pin wire and voltage from brake wire. If you have a 2 button remote, hold brake and press any button on the remote until clicking and flashing stops.
ADDENDUM
If you have an RS1100 or RS1200 and your vehicle runs for several seconds, shuts off, restarts, runs, and shuts off again, perform the following step: Connect the Black/White tach wire (from the 16 pin plug) to the heavy gauge White Ignition 1 wire and program the unit for Tach Mode (bottom of page 19).
Witch model alarm have your vehicle?
Good luck.
Mar 10, 2010 | GMC Sierra 2500HD Cars & Trucks
After installing a rs1100 remote starter the vehicle keeps giving several error codes (which I reset but they keep coming back). I'm not sure if the ignition (white) and the starter crank (orange w/black)...
Other details can find in the Bulldogsecurity ModelsRS1100_1100E_114
TY for use Fixya, good luck(remember rated this help).
Mar 02, 2010 | Remote Starter with Keyless Entry
Clicking noise for a day then no cooling at all. Fan running, but doesn't sound like compressor kicks on.
You should replace the overload/relay , which is the piece pluged onto the side of the compressor . This piece has a plug , with 2 or 3 wires , pluged into it , and is easily replaceable . Since you gave no model number , I cannot give you a part number , so , be sure to take it with you ( model number ) , when getting the part , so you get the correct part .
Nov 22, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Nakamichi SS-5 humming noise at stand-by nmode
Nakamichi service center in New Delhi. call +91 9871371720
Jun 26, 2009 | Nakamichi SoundSpace 5 Shelf System
My Alpine CDA-7863 does not read when I turn the ignition on,the screen does not read,it just make a clicking noise.I have no idea how to manually wire it .I just bought a 1996 tahoe and this Alpine was in...
1. you can go here and get a wiring manual with right model #.
http://www.alpine-usa.com/US-en/support/
2. The red wire goes to ignition switch/key.
Yellow wire goes to constant hot/battery.
Black wire is ground.
Blue wire is for power antana you do not need to hook that to anything.
You can look at this diagram for a little more help it is not your radio though but it will give you a reference point to look at. All radio red,yellow,blue,black wires are the same on all radios.
http://vault.alpine-usa.com/products/documents/OM_CDA-9884.PDF
go to page 42 on this site for wire diagram.
Good luck with problem.
Dec 15, 2008 | Car Audio & Video
Remote won't work and parking lights blink
the blue wire needs to go to -input then unit should work
Nov 03, 2008 | Remote Starter with Keyless Entry
Bulldog RS-1100/GM-12 Remote Starter & T-Harness Kit Logo
289 people viewed this question
Top Bulldog Security Vehicle Parts & Accessories Experts
Matthew Spark
Matthew Spark
John
John
Are you a Bulldog Security Vehicle Part and Accessory Expert? Answer questions, earn points and help others
