Oven door is locked with code E1-F5 Kenmore M#665-5002-102
  • Anonymous Mar 16, 2014
    I have Kenmore Gas Rang model 790.7423 Stainless. I accidently pushed oven door lock instead of self clean. After 8 hours, doo is still locked. Can I clear this?
  • 187 Answers
First thing to make sure of is that your oven cleaner is not on delay start.Clear it if it is. You also might have a child safety lock that was put on by accident (with not model I can't verify that, but look for a lock symbol). If you can not find a clear button, try to reset the oven cleaner- set it to go off in five minutes and the lock should release. If none of the above works, go to your breaker box (or unplug it) and shut the power off. It should reset the electronics. If this does not work, please leave a comment telling me what kind of over it is, how it is powered, etc. thank you for your question.
Posted on Nov 18, 2009
  • 2 more comments
  • Karlene Harlow
    Karlene Harlow Jan 28, 2014
    Model is 790.4907 I can not make the "flex clean" button activate. I have been to the breaker box and turned the power off for several minutes. My grandson messed with some of the buttons last night and now it is stuck in this mode
  • margaret silva
    margaret silva Feb 01, 2014
    Model is 790.9417 nothing you suggested worked trying to unplug and restart . is there a time that i should wait to restart ?
  • Judy Kirby
    Judy Kirby Feb 22, 2014
    I tried turning off the breaker, no luck. Door locked light still on. So then I tried to start a self cleaning but the minute I hit "delay start", the display showed "loc".
  • Judy Kirby
    Fixed it. YOu have to hold the "off" button down for 3 seconds or longer. Doing that both locks, and unlocks, the oven door. Sure didn't find that in the owners manual though.
My whirlpool oven is showing an E1 F5 code. It did it once but I can't clear it now.
E1 f5 code oven - YouTube
? 1:51
https://www.youtube.com/watch?v=5F1vwVpmG9U
Dec 28, 2014 - Uploaded by Jay Dornbos
Door locked then threw the code so now the door is locked and will not open. ...Whirlpool Oven - has E1 F5 ...
Nov 23, 2016 | Whirlpool Ovens
I have a Kenmore Range Model 95012102. After canceling the self cleaning oven process the code E1-F5 appeared on the display panel and the oven remains locked.
The F5-E1 error code means that one of the switches on the door latch hasn't fully set itself to the door open(non clean) mode. One thing to try is to open the oven door and push the light switch in by hand while pushing the clean button on the control and see if the latch will open just a little more thusly the switch will open a bit more into the normal mode.
If by pushing the clean button...waiting 5 minutes (whith the door open)then push cancel and see if the latch fully opens..the door latch switch would need to be replaced.
The part number for the latch asm. which includes the switch is W10107820
GENE
Sep 05, 2011 | Kenmore 95012 / 95014 Electric Kitchen...
Kenmore 95024 Electric Range The self clean cycle Door stuck shu
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jun 27, 2010 | Kenmore 95022 / 95024 / 95029 Electric...
Oven door is locked after trying to clean and getting error code E1 F5
E1 F5 means your unit is having a problem with the door latch and lock assemble turn the power off for 10 min. and after turning the power back on wait another 10 min. before opening
Apr 05, 2010 | Whirlpool GMC305PD Electric Single Oven
Oven door locked E1 F5
hi..
The manual says F5 means "failed circuit in control". This means that the control panel is burned out.. So just replace this..
Thank u
rate me!!
Jul 25, 2009 | Kenmore Ovens
E1 F5 came out and door is locked
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.%^RF
Jul 20, 2009 | Kenmore 92022 / 92024 / 92025 / 92029...
E1 F5 Error on Whirlpool Accubake Oven
The lock latch is located directly in the center upper portion of the door. It is a hook shaped latch that lock by turning downward. This lock gets stuck in this position which causes the e1 f5 error code. Locate the latch through the vent holes in the upper front of the oven door. Insert flat headed srew driver into vent hole and gently push latch up to a horizontal position & simply open door. Once unlocked, push cancel on the control panel.This will clear the error code and resolve the issue.
Apr 07, 2009 | Ovens
Kenmore oven locked after celf cleaning
Aug 12, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Computers & Internet Logo
107 people viewed this question
David Payne
David Payne
