Question about Garmin nuvi 885T GPS Receiver
My screen stop at "loading map" - Garmin nuvi 885T GPS Receiver
  • 2,335 Answers
There are two solutions to get your Garmin Nuvi 885T running smoothly again. I have posted detailed directions in the Tips section of this Fixya website. Follow these two links to find step by step instructions on how to perform both the hard reset and the software upgrade.
I hope that helps.
Posted on Jan 01, 2010
Wont stop loading maps
If your garmin nuvi wont stop loading maps, then you need to reaet the unit to get it to work perfectly fine once again. Try to hold down the power button for about 15 seconds and the gps receiver will restart, this time it will load normally and show you your maps.
If that does not solve the problem, then you need to back up your maps then format your gps receiver from a computer then restore the software and maps back on, that should do the job for you.
Hope this helps.
Dec 23, 2010 | Garmin Nuvi 465T Car GPS Receiver
European maps wont load
you'll need a mandatory firmware update
click here
Mar 15, 2008 | Navman F20 GPS Receiver
When I insert the Micro SD into the Garmin, the maps are not being read off of the card. When I try to plot a coarse it states "No Maps" loaded.
  • Press TOOLS
  • Press SETTINGS (or LOCALE on some models that don't have a settings icon)
  • Press MAPS
  • At the bottom of the screen press MAP INFO
Your map names should be shown with a tick beside them. If the maps aren't loaded the tick is probably missing. Press the map name and the tick will appear. The map is now selected and should load.
Nov 27, 2010 | Garmin nuvi 1300 Car GPS Receiver
1300 nuvi screen comes up loading maps and stops
A Garmin Nuvi 1300 that freezes on 'loading maps,' or is acting erratically is symptomatic of having corrupt firmware.
To correct this, I recommend backing up your favorites, clearing all user data, and if it still is stuck, then updating your Nuvi firmware.
Follow these three steps to take to get your Garmin Nuvi 1300 running like new:
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin WebUpdater to replace its firmware / system software.
I hope that helps.
_______________________________________
Garmin Nuvi 1300 Manual Download
Garmin Nuvi 1300 QuickStart Download
Garmin Nuvi 1300 Favorites Backup
Garmin Nuvi 1300 Hard Reset
Garmin Nuvi 1300 Webupdate
May 19, 2010 | Garmin nuvi 1300 Car GPS Receiver
My Garmin 765t stopped navigating
There should be a small reset switch on the back of most garmin gps units. with the unit on, depress the reset switch with a pen tip or small object until the unit shuts off and restarts. It may take a little longer to pick up the satellite but it will reque the unit and unlock the navigation screen.
Aug 01, 2009 | Garmin nuvi 765T GPS Receiver
Nokia E71GPS map jam
may be .... take backup and then type ... *#7370# ...default code is 12345 the phone will restart ...try again
Oct 15, 2008 | Cell Phones
Nav system
Installing the DVD Map Disc Your dealer/retailer may have installed the map DVD. If the map DVD was not installed, do the following to load it:
Read the following steps completely.
  1. Turn the ignition on. The vehicle must be in P (Park) to perform this operation.
  2. Press (power) to turn the navigation system on.
  3. Press the NAV hard key.
  4. Touch the Insert Map Disc screen button. The screen opens to access the map DVD slot.
  5. Load the map DVD partway into the slot. The system pulls it in. The screen cannot be closed until a double beep is heard.
    Notice: Pressing directly on the navigation screen may cause damage. Repairs would not be covered by the vehicle's warranty. Do not press directly on the navigation screen.
  6. To close the screen, slightly push up on the two outer corners until the screen is in position. Then push the screen in by pushing on the four outer corners until a click is heard.
  7. Set the search area. See "Setting the Search Area" earlier in this section.
Ejecting the DVD Map Disc The navigation portion of the system cannot be used if the DVD map disc is not loaded.
  1. Press the MENU key to enter the Menu options, then press the MENU key repeatedly until Nav is selected or touch the Nav screen button.
  2. Touch the Map Database Information screen button.
  3. Touch the Eject Map Disc screen button. The screen tilts, exposing the map DVD slot.
  4. Press the eject button, located next to the DVD map disc slot, and the disc ejects. Pull the disc out. The screen cannot be closed until a double beep is heard.
  5. To close the screen, slightly push up on the two outer corners until the screen is in position. Then push the screen in by pushing on the four outer corners until a click is heard.
Oct 07, 2008 | 2007 GMC Acadia SLE
Cannot upload update
Problem resolved. It seems to have taken several hours for gps to update.
Thanks anyway.
Jul 21, 2008 | Garmin StreetPilot C330 GPS Receiver
Quest .No maps coming up on screen
I already suscribed,and ,no , its not fixed.The person I was assigned had less of a clue than I did.What do I actually get for my $19.99 that I sent on paypal????
Mar 16, 2008 | Garmin Quest GPS Receiver
Cannot load map in my Garmin Streetpilot i3 GPS
i dont think you can upload maps to an i3, it can only load pre-loaded maps on micro-sd cards.
Sep 22, 2007 | Garmin StreetPilot i3 GPS Receiver
Garmin nuvi 885T GPS Receiver Logo
112 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
