Question about Ricoh Aficio 1232C Color Copier
Cant open scanner features on my ricoh 1232c - Ricoh Aficio 1232C Color Copier
  • 903 Answers
Did you let the copier sit for a couple of minutes? Sometimes when you turn the copier on it won't let you get into the printer or scanner features for several minutes, for no apparent reason. Letting it sit and coming back a few minutes later usually works.
If not, and you still can't get in, the print/scan software may be bad. Turn the copier off and reseat everything -- DIMMs, hard drive, SD card -- everything you can see attached to the controller board (the main circuit board). Even unplug and reattach the connectors.
When you reboot the copier, it should work fine. (Remember to give it a couple of minutes before trying to get into the scanner features.)
If you still can't get in, try to isolate the problem. Can you access the scanner screen on the copier by pressing the "scanner" button? Can you get into printer features?
Posted on Jul 18, 2010
Ricoh 1232c sc 672
The correct way to get into service mode is to first press the Yellow "CLEAR" button then press the numbers 1 >0>7 then press and hold the Red "STOP" button.... Good Luck
Jun 08, 2012 | Ricoh Aficio 1232C Color Copier
Aficio 1232c erreur 122
SC122
[Cause]
SDRB board is faulty.
[Resolution]
Replace the SCRB board and ground.
AND
SC122 occurs while scanning.
Does not occur when scanning at the same magnification; occurs when copying and enlarging.
[Cause]
Scanner motor is faulty.
[Resolution]
Replace scanner motor.
And one thing to check is to make sure the set screw that locks the cable pulley to the scanner drive shaft didn't back out or shear off.
Sep 22, 2011 | Ricoh Aficio 1232C Color Copier
Comment enlever message sc 570 sur ricoh 1232c
This error code is related to a Insufficient oil.
The fusing oil tank is in the rear of the machine.
You have to call Ricoh to supply the oil.
See you
Mar 29, 2011 | Ricoh Aficio 1232C Color Copier
The display panel on my Ricoh Aficio 1232C says, "Toner Bottle - 1 is full". What does this mean and what should I do? Rob Buckler
open front door ull see 2 bottles marked 1 and 2 pull it out and empty the waste toner
Be aware its very messy.Idealy u should have a replacement one.
Nov 30, 2010 | Ricoh Aficio 1232C Color Copier
The display panel on my Ricoh Aficio 1232C says "Used Toner bottle - 1 is full". What does this mean and what should I do? Rob Buckler
used toner bottle is full so you have to take it out and empty it. open the front cover, you will see one bottle in the middle and one lower down with 1 and 2 written on it. pull it out and empty it and fit it back.
Ricoh Aficio 1232C rpcs When I try to print the red light appears on the printer saying 'load by pass tray' even though I have selected Auto tray. Normally the machine prints fine.
when you selected auto tray was that in the driver or microsoft settings ? microsoft settings will overide the copier settings driver. look under file then page setup to see what it is set for.
May 20, 2010 | Ricoh Aficio 1232C Color Copier
Ricoh Aficio 1232c REFILL
You can't use any other brand of color toner to refill the AF1232, you'll have all kinds of issues. They do have compatible toners (generic) for that model but highly recommend OEM.
Mar 31, 2010 | Ricoh Aficio 1232C Color Copier
Ricoh Aficio 1232C prints with red-violet tone
download the RPCS driver from the Ricoh support site and then when you will install the driver go to preference then user settings and adjust the contrast and other options until you get the color of the printed image as you wish to be
Dec 14, 2009 | Ricoh Aficio 1232C Color Copier
How to Link Scanner from ricoh aficio 1232c
Download Twain Driver from ricoh site and you can use any softwere that suports twain scaning i use microsoft scan that comes with office 2003
Oct 18, 2009 | Ricoh Aficio 1232C Color Copier
Ricoh Aficio 1232C Color Copier Logo
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
SOURAV KAPOOR
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
