Question about Panasonic Lumix DMC-TZ3 Digital Camera
Ring around the lense is bent and lens won't telescope open anymore
What settings do i need for rokinson2600 lense on my d5000 cheers paul
This lens lacks the electronics to communicate with the camera. You need to set the aperture ring on the lens to its smallest opening (largest f/number). You control the aperture from the camera body, the same was as on a lens without an aperture ring.
For the camera, you need to set it to the Manual exposure mode and set the shutter speed and aperture yourself. You also won't get any metering assistance from the camera. You can review the pictures and/or use the histogram to get the proper exposure, or use a separate light meter.
Sep 07, 2011 | Rokinon 6502600 f816 for Nikon
The lenses do not secure into the eyepiece. Also, I can not see anything through the telescope. I've tried during the day and at night. ??
Use the weakest lens the lens cap is off I hope lol I have a Meade scope and it has thumbscrews for the lenses that must be tightened evenly.It's tricky to see through a telescope especially if you have a strong lens in there instead of a weaker one.
Jan 03, 2011 | Vivitar (1607225) Telescope
What is h20
Is this a TELESCOPE question? You posted it in the Telescope Topic?
Please explain or repost it in the proper topic.
Thanks-
Sep 07, 2010 | KonusMotor 70 (90 x 70mm) Telescope
Tasco telescope[46-114500]cannot see anything through lens.bought
THE protective cover is the FRONT of the telescope!!!
The focuser is on the front like the picture above. TURN the scope around -- you have it pointing at the ground right now!
Read my TIPS on my profile page. And read this and look at the pictures:
http://www.texasastro.org/telescope.php
Jan 15, 2010 | Tasco Galaxsee® 46-114500 (500 x 114mm)...
I dropped my F10 with the lens open. The center part of the telescope is bent sideways. Some of the screws are odd-shaped and I cannot open the camera. Can it be fixed?
Yes. Provided the damage isn't to bad internally.
You need to find someone in your area who knows how to re align and inspect lenses. I'm in the uk if thats any help
Dec 18, 2009 | Cameras
Lens' in my new Voyager 78-9960 telescope fell out
The small squares are spacers between the lens elements. Most objectives have 2 parts, with one lens like() or (|. That is the one on the outside, with the outwardly curved side facing the object to view. The other lens goes behind it, making the stack look like: (object) --- ())| for the 2 lenses. Sorry, this page does not allow proper graphics, but I hope you get the idea.
Do not tighten the retaining ring too tight - just enough to hold in place. The lenses need a little space for thermal expansion.
Oct 17, 2009 | Bushnell SkyTour 78-9960 (700 x 60mm)...
I have the same Telescope and am looking for lenses
If the opening is about 1 inch then you need eyepieces that are .965 inch --
The common sizes are .965, 1.25 , and 2 inch.
.965 eyepieces are available for purchase on Ebay and here:
http://www.agenaastro.com/
Jul 14, 2009 | Tasco Luminova 40060660 (660 x 60mm)...
Panasonic FX-01 Lens zoom ring (around shutter release) loose on
must to open ur camera and completly open that lense and clean well all gears then fix it back it will work
Jul 11, 2009 | Panasonic Lumix DMC-FX01 Digital Camera
Camera attaching to telescope
Orion sells the camera T-RING and lens adapter-- and any other focuser parts you need-- look around their site and then call them.
http://www.telescope.com/
www.telescopeman.org
www.telescopeman.us
www.telescopeman.info
Mar 29, 2008 | Tasco Luminova 40114675 (675 x 114mm)...
Zoom error message
Press the power button on and hold it down while extending and twisting the telescopic zoom lens. It might fix your problem. In any case it could not make it worse Good luck!
Aug 07, 2007 | Olympus SP-350 Digital Camera
Panasonic Lumix DMC-TZ3 Digital Camera Logo
27 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
