Question about Car Audio & Video
I just bought a yamaha rx z1. i try to pluging to use the subwoofer is not working
    President:
  • 1,114 Answers
If you have it hooked up to a TV via monitor out, it's easier to do. Press "menu" or "GUI menu" go to "manual setup" then "speaker settings" then "subwoofer" and select "both" If you need more help, post a comment and I can help you further.
Posted on Nov 18, 2009
My RX-z1 yamaha receiver shuts off right when I turn it on, what do I do?
Check and make sure that you dont have any wires shorted out. Also make sure that its not in a tight enclosed space because it can overheat quickly. It also wouldnt hurt to hard-reboot the unit. Simply turn it on, then unplug power from it for about 15 seconds. If non of these options shed some light, than you might need to get it serviced.
Good Luck
Jan 08, 2011 | Yamaha RX-Z1 Receiver
Subwoofer
Without being able to access the receiver in person, the best advice I can give you is to sit down with your user manual and follow the instructions. You'll find, starting on page 85, the necessary settings for hooking up a subwoofer to the receiver. If you don't have the manual, you can obtain a pdf file at Yamaha.com: http://www.yamaha.com/yamahavgn/Documents/YEC/AV_Receivers/Manual/RX-V663_U-1.pdf
May 16, 2010 | Yamaha RX-V663 Receiver
Subwoofer plug broken?
Most likely the plug is ok but the level control for the subwoofer will need to be readjusted in the receiver, If the level cannot be raised making sure your source being used has subwoofer information, then there could be a problem in that circuit.
Jul 17, 2009 | Yamaha RX-V661 Receiver
No output from woofer connection
If I understand you correctly, your subwoofer does not have RCA jacks but speaker terminals only. This should solve your issue but I have seen less expensive ones in the past.
Mar 29, 2009 | Yamaha RX-V463 Receiver
Sound not coming through speakers correctly
Check that the speaker setting on the receiver is set to large not small. (if you have 6inch or larger woofers)
If you have only small speakers you will need a subwoofer.
Feb 22, 2009 | Yamaha RX-V363 Receiver
Yamaha RX-V850 receiver
how can i hook a subwoofer into yamaha RX-V850
Dec 25, 2007 | Yamaha Audio Players & Recorders
Unit shut off after 15-20 minutes
The problem is IC 451, (Yamaha Part # XU814A00) (Number on part PQ05RD11 Made by Sharp). It's a + 5V 1A Voltage Regulator.
It's located at the bottom of the power supply board mounted to the front heat sink. It's a four legged TO220 Package outline. So don't try to slip a three legged 5 volt regulator in it's place. This can cause serious damage and headaches. Change this part and everything should be good.
Nov 15, 2007 | Yamaha RX-Z1 Receiver
Car Audio & Video Logo
50 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
