Question about Frigidaire ATF6000ES Front Load Washer
Door Lock/COntrol board?
I have a Frigidaire LTF2140ES3. Close door and start washer. Door lock doesn't come on. Can hear relays from around the control board functioning, but nothing happens (Does not draw water on wash cycle, does not drain/spin on drain and spin cycles, etc.) Replaced control board and door lock. Still functions the same way, keeping the door lock on. Solutions?
4 Suggested Answers
Jahn27
  • 1554 Answers
SOURCE: frigidaire frontend washer LTF2140ES3 will drain not spin
There is an auxiliary switch in the door lock and switch assembly that is activated at the end of the wash cycle to advance to the spin cycle. When the machine works except advancing to the spin cycle, it signifies that this auxiliary switch cannot be activated and the door lock and switch assembly is faulty. Replaced the door lock and switch assembly (part #131763202) to fix the washer.
Disconnect power to the machine. Open the washer door then look for the retaining hoop securing the door seal around the lip of the door opening. Stretch the retainer spring of the door seal retaining hoop then remove it.
Carefully peel off part of the door seal from the lip of the door opening near the door lock and switch assembly. Remove enough of the door seal to gain access to the door lock and switch assembly.
Remove the screws securing the door lock and switch assembly to the front panel. Once the screws are removed, lift the door lock and switch assembly then pull it away from the front panel.
Take the door lock and switch assembly out of the machine. Disconnect the wires from its terminals then connect it to the new door lock and switch assembly.
Put the new door lock and switch assembly back into position in the front panel and secure it with the securing screws.
Properly put the eased part of the door seal back over the lip of the door opening then secure it with the retaining hoop.
Posted on Mar 10, 2010
tunde007
  • 2382 Answers
SOURCE: My Frigidaire LTF2140FS1 will not
Hi, if your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out.
To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port.
Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job.
If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump.
Posted on Nov 23, 2010
heatman101
  • 43501 Answers
SOURCE: Frigidaire Gallery Front Load Washer
The best way to check is to use an electrical meter and check for power going to the motor....if you have power and the motor does not run then the motor is bad...
It is also very possible that the motor is not getting power and that a relay is bad...that could be much more difficult to track down...
heatman101
Posted on Apr 06, 2011
FRIGIDAIRE FRONT LOAD WASHER WON'T START. DOOR LOCK WILL NOT LOCK. DOOR LOCK LIGHT IS OFF. PULL START HANDLE OUT/ NOTHING. HEAR CLICKING WHEN TURNING SELECTOR SWITCH/BUT WILL NOT LOCK DOOR OR TURN LIGHT ON...
Good Morning REDS, thank you for your inquiry!
I understand that your door indicates it is open and your washer will not operate. Try resetting the unit by either unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and turn on the washer. Select a normal cycle, confirmed the latched is securely latched and verify if the washer will start. If the washer will not operate then it possibly have a faulty door lock assembly or a communication problem with the control board. At this point, it would be advisable to contact an experienced appliance repair tech to assist further.
Sep 11, 2013 | Frigidaire ATF6000ES Front Load Washer
My fridgidaire model #LTF2940ES3 is giving me an error code E47 what is this
Very likely the problem is a bad door lock. It is very common problem with Frigidaire front loaders. You have to measure the resistance of the wax motor in the door lock assembly (the orange piece on the right side of the picture). I don't know why Frigidaire call it PTC. Very confusing. The normal reading should very close to 1500 Ohms. Otherwise verify all wires from the door lock assembly to the control board and, if everything is fine, replace the control board.
showpartimage.aspx?forumimg=ap4455026
If the door switch is bad, replace with this part.
If the control board is bad, replace with this part.
Oct 15, 2012 | Frigidaire ATF6000ES Front Load Washer
I am getting either an E6E 0r EbE code on my affinity washer . I hear the relays clicking but nothing happens .
Hello chuckthom980 - Typically EBE indicates that there is an issue with the console control. Contact a professional to have the main control board replace.
Sep 30, 2012 | Frigidaire GLTF2940ES Front Load Washer
Door lock sensor on affinity washer
It sounds like the entire door latch assembly needs to be replaced. The sensor inside is no longer communicating correctly with the main control board.
Aug 29, 2012 | Frigidaire ATF6000ES Front Load Washer
I have a frigidaire front load washer that gave me a error 47 code. what can that be.
The circuit thinks the unit is in spin cycle - Remove the door lock assembly and measure the resistance of the PTC. Shorted or open, defective door lock assembly. Reads around 1500 ohms, defective Main Control Board.
Aug 19, 2012 | Frigidaire ATF6000ES Front Load Washer
My Frigidaire frontload washer (model #LTF7000EG0) wont start because Door luck button comes on saying it won't lock. Please Help??
My guess is that being that the lock is electronic, either the lock is defective or there is a problem in the control board in that it's not telling the lock to lock the door. I would have a tech check the board.
May 08, 2012 | Frigidaire Washing Machines
Frigidaire frontend washer LTF2140ES3 will drain not spin
Mar 10, 2010 | Washing Machines
I have a Frigidaire LTF2140ES3 washing machine. No matter what I select, I hear the door lock click, and then random clicking as it tries to go through the modes, but nothing happens.
sound like you need a door lock. your door lock is not locking or not tell the control that it is locked.. should try 6 times to lock before it will give up trying... hope it helps
Sep 18, 2009 | Frigidaire ATF6000ES Front Load Washer
My washer is stuck in pause mode and when I checked an the error it was E41 code
E41 Control board thinks the door switch is open. Remove the door lock assembly and measure the resistance of the PTC. Shortedor open.Defective door lock assembly. Around 1500 Ohms. Defective control board.
My Frigidaire affinity washer doesn't start: the "door locked" button doesn't come on though the door is closed properly
If the washer fills with water, but will not start the wash cycle or spin, it is 1 of to things. the most common for frigidaire front load affinitys is the door lock assembly. I have had to replace numerous of these. if the door lock indicator is not on when it tries to wash, you need to replace the door lock assembly. if the door lock indicator is on, but wont wash, it is likly that you have a bad motor control board.
Dec 01, 2008 | Frigidaire Affinity ATF7000ES Front Load...
Frigidaire ATF6000ES Front Load Washer Logo
99 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
