Question about Air Tools & Compressors
Pop off valve on return line leaking compressor keeps running turn compressor off stops leaking whats up?
  • waynespaintw Nov 19, 2009
    I FOUND THE PROBLEM WAS THE PRESSURE VALVE IN TOP OF TANK AND THE POP OFF VALVE WAS FAULTY COST ABOUT $30 BUCKS.
    Problem Solver:
  • 7 Answers
Once the pop off valve reaches its opening point, it will stay open as long as the pressure is above that point. When you shut the compressor off, the pressure leaks down until the pop off valve closes. Sounds like the pressure regulator is set a little too high. If you can turn the regulator switch down, it should fix it.
Cabinetman54
Posted on Nov 19, 2009
Husky air compressor
Josh:
Your compressor shouldn't run more than ten to fifteen minutes before shutting off. The pressure should be posted on the machine somewhere ( a decal usually says xxxpsi). You evidently have an air leak somewhere. On the bottom of the air tank there is a valve for draining the tank of air and any moisture. Make sure to close that valve by hand only (Screw it in all the way by hand and remember, you are working upside down, so don't get confused as to which way to turn it). If the valve will not unscrew to drain the tank, you can use a pliers to loosen the valve to let the air out, but be sure you are turning it in the correct direction or you'll break the drain valve!! Now that you have the drain valve closed, turn the compressor on and watch the pressure gauge. When the pressure gauge reads the pressure on the decal, the machine should turn off. If the pressure gauge stops climbing before it reaches the specified pressure, you have an air leak somewhere. You can either feel for the leak at the air line connectors by hand or mix a dish soap and water solution the pour on the air line connectors to look for the leak. Keep the soap solution away from the motor!! When you find the leak, drain the tank using the drain valve at the bottom of the tank, disconnect the hose coupling that is leaking and wrap Teflon tape around the threaded portion of the male end of the fitting (3 wraps should do it) and reconnect the coupling ( tighten it well). Close the drain valve and start the compressor again. and check all fittings for leaks again.
Jun 04, 2013 | Air Tools & Compressors
I have a ingersall rand 2475e compressor that the valve that the small copper tube goes to started leaking. replaced the valve and put back together and now pop off valve on the line from the compressor to...
Sound like a bad receiver tank check valve. Located in top of the tank and the pop off valve is screwed into it. If check valve is good you need to remove the heads and check the finger valves. I believe you'll find your problem in the check valve
Sep 12, 2011 | Ingersoll Rand Ingersoll-Rand 80 gal. Air...
I have a air compressure with a square d 9013fhg44mix pressure switch. The problem is where the 1/4 air line goes, this valve leaks when ever the compressor is off. Once the compress is on it is off and...
The 1/4" line is very necessary and there are no adjustments on it. When the tank reaches full the pressure switch turns off the power and opens the valve to the 1/4" line to bleed off pressure from the air pump and feed tube so the motor can turn over the next time the tank drops to the kick in pressure. Every time the pressure switch turns the motor off a small amount of air should be heard coming out of the bottom of the switch for three to five seconds and then it should stop completely. If air continues to leak out of the switch by the 1/4" line, you have a bad tank check valve. The tank check valve is the brass fitting at the other end of the 1/4" line where the feed tube from the air pump goes into the tank. It keeps air in the tank after the pressure switch turns off the motor. Easy to replace, find the one you need for your model compressor.
Mar 25, 2011 | Square D 9013FHG14J52M1X Air Compressor...
My 1 hp. 12 gal. air compressor is not building air pressure the motor runs the pressure won't go above 20 lb.
It could be that the input air filter is badly clogged. I might more likely be that the Non-return valve on the air tank input is not sealing properly and not allowing the tank to build up pressure. This valve is at the end of the main pipe runs between the compressor and tank. It could also mean (less likely) that the poppet valves inside the compressor cylinder head are not sealing properly. Other faults could be worn rings on the compressor pistons or a bad seal between the compressor cylinder head and block.
To check the Non return valve allow compressor to build up some pressure and then loosen union nut on Non return valve. There should be some air released at first but should stop if valve is ok. If leaking remove valve and check for dirt and clean. If valve still leaks replacement is the only fix.
Sep 14, 2010 | Craftsman Air Tools & Compressors
Compressor runs great but pops off at 125 then bleeds down to 80 then tries to restart.i have changed high presure pop off.
It souds like a sticky "non return valve". See the fix below.
The non return valve is the chrome part with a hex cap adjacent to the upper tank. Remove the cap and make sure the piston moves freely. Slight resistance is ok, but if it sticks your compressor willl continually blow off air.
The check valve or "non return valve", as listed in the Hitachi parts manual is definitely the culprit here, but there is an alternative solution to replacing the entire valve that was actually suggested to me by a Hitachi Tech when I stopped by my local service center to pick up a new non return valve. Obviously, the rubber piston swells and sticks to the point that the spring under the piston can't over come the friction. I removed the piston and carefully reduced its diameter, by hand, with varying grades of wet or dry paper and it now operates perfectly. If one is uncomfortable with such a repair, at least keep it in mind for a quick jobsite fix. I have now been running my repaired compressor for several months without issue.
Aug 20, 2010 | Hitachi EC12 Portable Electric 2hp Air...
My ec 12 compressor will run and shut off around 125 psi and then it bleeds off untill it turns on around 80 psi Ive replace the pressure switch and its still doing this Why?
Jun 25, 2010 | Hitachi EC12 Portable Electric 2hp Air...
The compressor relief valve keeps popping, compressor runs
What pressure is it popping off at? You might have to adjust the pressure switch to a lower setting.
Apr 01, 2009 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
With compressor running the relief line blows off
check that the non return valve is not stuck closed
hope this helps ian
Feb 24, 2009 | Campbell Hausfeld Single Stage Air...
Clarke hunter 60 2.5 hp compressor , trip switch keeps tripping
if you are talking about the brass valve with a small pin in the middle.it leaks untill the pressure get to 15-25 lbs then the pin pops out and stops leaking and the compressor pumps to pressure. this is normal that valve it a cold start valve that allows the compressor to start with out binding
Dec 09, 2008 | Air Tools & Compressors
Air Tools & Compressors Logo
352 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
