Question about Brother DCP-8040 Copier
Need left hinge/spring box
I need the left hinge/spring box holder (plastic). The cheap plastic loops on top of the "spring box" that hold the left hinge pin broke off.
  • 1,110 Answers
Precisionroller.com
their part number is H7914
Brother part number is LP2403001
Posted on Nov 18, 2009
Testimonial: "Thanks!"
The lid to my whirlpool cabrio top loading washing machine will not open completely???
Hello. How old is your washer? Is there rust around the bleach dispenser near the left side hinge? What probably has happened is the hinge assembly underneath the top cover has rusted from the contact with chlorine and or fumes. These washers are notorious for rusting at the hinges, especially near the bleach dispenser. The parts involved are:
left hinge arm--w10389421
right hinge arm--w10389240
left hinge spring assembly--w10358931
right hinge spring assembly--w10358932
top cover--w10391067--if this needs to be replaced, call for service--it's a solid hour to 90 minute job for an experienced tech! You have to transfer ALL THE PARTS to the new cover and it's INVOLVED--trust me! If there is rust around the bleach dispenser and underneath the top cover, you might check your serial number with Whirlpool to see if you can get a new top cover for free covered by a service bulletin dealing with rusting. To raise the top cover, remove the top screws from the hinges on the rear of the washer holding down the top cover. Then, remove the screw and metal plate protecting the wire harness and pressure hose and set it aside. Next, from the front, slide the top cover forward 1/2 inch and lift up. Have a friend assist you in holding up the top cover. You can now access the hinges mounted underneath, check for rust, and also see how the suspension rods are mounted(they are very easy to remove since there is a slot in each rod holder located at each corner at the side of the tub near the bottom. You would pull up on the tub, release the top of the rods first, then reach down and unsnap the plastic clips(2) in the center of each holder. Use a headlamp or flashlight to see. The rod will drop down and can be removed through the slot. Reverse the procedure to install.
Also, in case your suspension rods get worn out(the tub has a hobby horse "bouncy" movement), the part number for the set of 4 is w10368625. The proper way to check the rods is to place your hands on the right and left side of the tub ring(the plastic cover over the basket) and shove smartly down and release--the tub should grip going down and pull coming up--no springy movement--just like shock absorbers on a car. It should come up and settle. If it has any bounce at all, the rods are worn--symptoms will be increased out of balance errors or the washer might start banging during spin. I hope this helps you. If you are hesitant about performing any of the repairs above, please call for service!
Oct 03, 2015 | Whirlpool WTW8600YW 4.6 cu. ft. Cabrio...
Left hinge broke on lexmark pro 905
Not a perfect fix, but this is what I did: There are 2 spring-loaded pistons located on the printer side of the hinge that cause this problem. I think there should be another piece of plastic that holds the top of the printer hinge down on these springs, but when this hinge is gone, the top of the printer is held upward by them. If you use some pliers to gently pull these spring-loaded pistons upward, you can easily pull them out, followed by the springs they cover. Once removing these, the top of the printer lies flat. The top is still unstable, but mine will now feed paper just fine and closes. Hope this helps! WebRepOverall ratingThis site has no rating(not enough votes)
Oct 23, 2012 | Lexmark Platinum Pro905 multifunction...
I need the spring that holds the heads down to the shaver. I dropped it and the spring flew out. It works great otherwise.
The spring (hinge) is attached to the head holder and is not replaceable. You will need to replace the head holder that includes this hinge. You will find this part for model 7737X at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/norelco-philips-7700-series-cool-skin-head-holder-with-hinge.html
Aug 10, 2011 | Norelco 7737X Electric Shaver
Hinge is broken on my lexmark X6500 so cover won't close
I have a Lexmark X6570 All In One Wi-Fi model. Just had the problem where I went to print and received an error message saying that the cover was open (when it wasn't). I noticed that the back right hand corner had slightly popped out of place for no apparent reason. Tried to pus it back into place with no luck.
Here's what happened and how to fix it:
There are two plastic hinges at the back of the 6500 series printers that allow the top cover to open for access to the ink cartridge carriage. The lower ends of the hinges are cylindrical shaped and each contains a very stiff steel spring inside. They are designed to prop the cover of the printer up and hold it open when opened. As the plastic material ages, it may weaken and the tension of the internal spring may break the round end of the hinge off. This causes the printer cover to not fully close (even though it may appear so). There is a switch in the main printer body that detects when the top cover it open (even partially), and the printer won't work in this condition.
To fix this, open the top cover and carefully disconnect the 3 wire harnesses and the ribbon cable that run from the top cover to the base of the printer. Then remove the 'paper jam' hatch cover from the back of the printer. There are two phillips screws on the back panel of the pinter (one is located behind the paper jam hatch cover). Remove these screws (they secure the plastic hinges in place). You should now be able to lift the complete top cover/ scanner table assembly off the rest of the printer. Look for a steel spring about 3 inches long...remove this along with the round base of the hinge which may have broken off and remained down inside the printer. Glue this piece back onto the end of the hinge, but leave the spring out. Now reassemble the printer in the reverse order of disassembly and you should be good to go. Note that the top cover or the printer will not stay propped open on it's own with the spring removed, but this is not really an issue.
I am not sure if new replacement hinges are readily available from Lexmark or other sources.
Jul 23, 2011 | Lexmark X6570 InkJet Printer
Replace boot gasket
Hello, Remove the door hinges and plastic covers on the unused hinge screw holes on the opposite side of the door opening (door is reversible, so there are places to mount hinges left and right). Front panel will now snap out at top and lift off lower spring clips. One screw on each side will now release top panel and it will hinge up. Prop up with broom handle or something. Now you can get at everything. Rubber gasket is held onto drum with a cable loop and very strong spring. It rolls off the lip easily to disassemble but is VERY difficult to get back on without special tools or at least two people. Door side of rubber gasket is easy in comparison with rubber tabs inserted into slots and working the gasket into a groove. Hose clamp at bottom of rubber gasket to connect drain hose.
Thanks
Jun 10, 2010 | GE WSXH208A Front Load Washer
Need spring that holds the head to the shaver and rubber cover that covers it.
On model 7775X the part you are asking about is not sold seperately. If yours has come off, it is because the plastic that holds it is broken. You will need to replace the head holder which includes this piece.
You will find it available at shaveroutlet.com. See link below
http://shaveroutlet.com/norelco-philips-7700-series-cool-skin-head-holder-with-hinge.html
Apr 24, 2010 | Norelco Cool Skin 7775X Electric Shaver
Marvel, Model 61 RF ww-F made in 7-19-2000
Dear John,
Contact the factory directly at 800-223-3900 8:00am to 5:00 pm EST. I believe the bar pn is 42241938 (for the 2nd and third bar) and the top bar pn is 42241937. (I am going by memory so have them verify it). They also have a kit that has both side hinges and new springs for the freezer door. If you can't get through via phone contact Tim Malloy using tmalloy@northlandnka.com. He's a little overloaded but should get back to you within a day or two.
Nov 01, 2009 | Marvel 61RFxx 24-inch Refrigerator/Freezer
How to replace the cabin air filter in a 2000 toyota avalon xls
lower the glove box and its forward of that, should be a plastic panel to remove.
Sep 23, 2009 | 2004 Toyota Avalon
MIcrowave
check the door latches inside the oven, open the housing and spray some lubricants on the latches.
Feb 21, 2008 | Frigidaire FMV145K Microwave Oven
Brother MFC-8440 Doc. Cover Open Error Message
I had the same problem, found your site and all of your suggestions. I ordered the same left hinge assembly from Vance Baldwin Electronics
Part #LP2403001 for $11.03, shipping from FL to OK was $9.23 UPS, so less than $20 and my MFC-8440 is working again! I did have difficulty placing the screws without a second pair of hands so have someone help you hold the lid. Make sure you removed the set ***** from at least the back of the left hinge assembly so that you can remove the "case" that holds the springs and sticky white parts. (Yes, I am a girl) :-). My husband will be so suprised when he gets home and sees that it works now because it was on his honey do list this weekend. Also, make sure that you replace the set screws and clean the scanner appropriately before use. I really like this site, it saved me a lot of money this time. Take Care!
Aug 22, 2007 | Brother MFC-8440 All-In-One Laser Printer
Brother DCP-8040 Copier Logo
180 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
