Question about Exercise & Fitness
My Nordictrack treadmill has the electronic panel work, but the motor appears to be not working. Help i am getting fat!
    New Friend:
  • 64 Answers
Your treadmills needs a motor controller. It could probably use some belt lubricate also. The heat that's created from the friction of the walking belt and the board under it causes an extra drag on the motor. The control board sends more power to the motor to make up for the loss of speed. This will eventually kill the controller. So lubricating could be a key factor to not damaging a new control board right away. Hopefully this helps.
Posted on Nov 18, 2009
Nordictrack treadmill commercial zs will light up the incline works fine but the belt won't move
the motor drive assembly is seperate from all the electronics that you program and the incline motor ,although it may not work if there is a "Saftey 'Clip that attaches to the machine and clips on yourself
it wont work without this "or if this Magnetic Clip is 'Faulty,
If you can lay Machine down on its side or look for a plastic cover at the front or underneith and see if you can Unscrew and access the
motor ..there may be a Overload Reset Button or Fuse just after where the Main Power Cord goes into the Tredmill.
tred mills also are common for getting pet fur and hair in the motor which can get caught up in the Brushes, (I Think it is Most likely a Fuse or overload switch that is inline with the main Drive Motor.(if you can post exact Model# of TREDMILL I can have a look at the Electrical Diagram and make a more accurate conclusion ,Cheers!
Aug 19, 2016 | NordicTrack Exercise & Fitness
Only the plus button on console works nordictrack c900i
Most buttons (all but incline 6 through 12) on my C900i stopped working all of a sudden. Long story short... it was the ribbon cable connections on the back of the control panel. Its 6 screws to get the panel off, and then 10 screws to open the panel. Cut the zip tie so the connection wires can be pulled through the hole in the back panel cover. And then take the iFit module off after you open the panel to allow fully removing the cover. The little white piece on the ribbon cable connectors slides up to allow the cable to slip out. Search youtube if you've never dealt with ribbon cables/connectors - they're very common in electronics. You can also search for how to clean the cables. In my case, simply disconnecting/reconnecting was all I had to - this fixed every button on my panel.
Jan 27, 2014 | Nordic Track NordicTrack C900I TREADMILL...
I own a Nordictrack 7000R and the console just quit working. It turns on like before, but now only speeds 3, 8 and 12 work...no other function operates...no start/stop, incline anything. I really love...
All electronics should have a surge protector. So when the power flickers and send a power surge to electronic plugged into the wall the circuit board is protected like your computer.
Nov 03, 2013 | Nordic Track NordicTrack Commercial 1500...
Error code 660 & 595
Ray here, I had the same codes Icon couldn't ID them, new motor, then motor control board was troubleshot by me & my tech guy has never been the same, if it's a commercial grade unit, it starts wth a C, the motors have a lifetime warranty, so don't buy one, 9 out of 10 times it's the MCB ">
Oct 15, 2013 | Nordic Track Nordictrack C2050 Treadmill...
My fan won't work on my nordictrack 4400R treadmill. What should I do to get it working.
please test the voltage in the motor fan with DVOM. IF There are voltage , and the motor is NOT running , replace it.
However you must tight very well all the connectors. Test the fuse in the treadmill see the block diagrams attached for troubleshooting.
God bless you
Jan 09, 2013 | Exercise & Fitness
Stops dead during workout
Dear Sir:
Most of the problem with this situation is lack of lubrication and regular maintenance.
The treadmill is very complex electronic equipment. The friction between deck vs walk belt is Enough for to protect the equipment, the electronic design shut down the treadmill, for to avoid damage to the electronic components.
2nd failure is main motor board. But you must lubricate your equipment, see your instruction manual or user guide. If you do not have you can download free from Nordic: www.Nordic.com, go to service customer, then parts%Manuals, give your model, etc, and download for free.
sincerely. God bless you
ernesto cuadra
managua, nicaragua.
Feb 14, 2012 | Nordic Track NordicTrack Treadmill, A2550
Only certain buttons on the NordicTrack exp1000 treadmill work.
1) You must check the flexible cord between display board vs controller motor board, and tight very well
2) Try to access to the keypanel and clean with special spray (clean contact you can find in radio schack or computer store).
3) Try to Measure the +5Vdc for I.C. including EPROM, ROM, etc.
4) And try again.
5) Measure if the power supply to display is coming out from the Lower board or Motor controller board. If not the Motor controller is faulty. You must replace it.
Use Dvoltmeter.
Remember 90% aprx the Motor controller board access to the function in the display board, elevation motor, power input, etc.
sincerely.
Nov 22, 2011 | Nordic Track Nordictrack Exp 1000...
Nordictrack motor will not run when start button is pushed.
Likely the cover of one of the motor brushes popped off. Unplug the machine before you pop it back in place, then try it again.
If that doesn't work, most likely it's the motor control board, or possibly the console, or finally just a loose connection behind the console.
But most likely, it's the motor brush cover. I've been seeing that alot with this model.
Oct 29, 2009 | Nordic Track NordicTrack Treadmill, A2550
Exercise & Fitness Logo
78 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
