Question about Frigidaire 24 in. FDBB944C Built-in Dishwasher
Frigidaire dishwasher fdb1100RHC0 not working
  • 10,515 Answers
Follow the below guide :-
Power from the house
Is there power getting to the dishwasher? This can be difficult to test, because dishwashers are usually wired directly to an electrical circuit, rather than plugged into the wall. But at least check for a blown fuse or a tripped circuit breaker.
Door switch
The door switch is important because, if it's defective, the dishwasher won't work at all. To reach it, you need to remove the control panel cover, or sometimes the interior liner of the door. If it's defective, you need to completely replace it.
Wiring
Often the main wiring connection from the house, at the dishwasher, burns and breaks the connection. If that's the problem, the wires must be repaired/replaced as necessary. If that's not the problem, check the wiring to the door switch, the wiring between the door and the lower part of the dishwasher, and the wiring to the timer. Repair any broken, burned, brittle, or defective wiring, using the proper appliance-grade wire and connectors.
Timer or selector switch Although it's uncommon, the timer or the selector switch may be defective. If so, you need to replace the defective part, because neither of these can be repaired.
Procedure to Check Door Switch
http://www.partselect.com/repair.aspx?appliance=dishwasher&part=test-door-switch
Procedure to Check Timer
http://www.partselect.com/repair.aspx?appliance=dishwasher&part=test-timer
If problem persists, it sounds to be Faulty Control Board. You need to check the Board and the Wiring.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Nov 18, 2009
I am trying to locate an owners manual for a Frigidaire Dishwasher model # FGHD2433KW1
Below is the link, you can download it
http://www.manualslib.com/products/Frigidaire-Fghd2433kw1-2885301.html
Dec 05, 2015 | Frigidaire Dishwashers
What is an i30 error code for frigidaire dishwasher
Hello friend, thanks for your inquiry!
On your Frigidaire dishwasher "i30" stands for aqua control. You should perform a reset on your dishwasher and that could clear any false error codes. To reset your dishwasher you can flip the household circuit breaker off for ten minutes. If that does not work you could be experiencing an issue with your water inlet valve or control panel. I hope this information has been helpful. -Matt
Oct 10, 2014 | Frigidaire 24 in. FDB1050REC Stainless...
Frigidaire professional dishwasher buttons don't work
I appreciate your inquiry, friend!
I have identified a few possibilities as to why the buttons are not working on your Frigidaire Professional dishwasher. It could be a stuck button on your keypad and I would recommend pressing every button to see if one is stuck or loose. It could be that the keypad or control panel needs to be replaced. This is not a simple DIY job and I would recommend reaching out to a professional technician for proper diagnosis. I hope this helps. -Matt
Sep 25, 2014 | Frigidaire Professional Series 24 in....
Most common problem is a burnt out water valve, which would need to be replaced. When you turn the dishwasher on, does the motor run after a few minutes? If not, it's possible that the latch is faulty. It can fail, so the dishwasher thinks the door is open, and nothing will work
Apr 07, 2010 | Frigidaire 24 in. FDB126RB Built-in...
Frigidaire Dishwasher - Spray Arm Not Working
This all may be due to an impeller problem in the pump housing under the lower washarm. If the impeller is damaged/bad the pump will not circulate water through the wash system correctly. On most Frigidaire dishwashers the lower washarm and top pump cover can be removed fairly easily to check it out.
Go here for: Frigidaire-Dishwasher-Parts
RepairClinic.com
appliance parts, help & more
May 08, 2009 | Frigidaire Dishwashers
When a dishwasher has been checked for obstructions in the sump area and the spray arms can spin easily (by hand) plus the spray arm holes are not blocked, you end up with either a broken impeller or a failing wash pump motor.
If you would like more details of have more questions, please post comment back here, OK?
Good Luck!
Apr 26, 2009 | Frigidaire 24 in. FDB510LC Free-standing...
Frigidaire Dishwasher Energy Star blinking lights.
Hmmm...don't know why this worked, but it did. When the lights were flashing when I tried to start my Frigidaire dishwasher model#FDB1500LF, nothing would happen...just blinking lights, so I went to the house electrical panel, found the switch for the dishwasher, turned off & on again, and now the dishwasher works.
Go figure.
Feb 16, 2009 | Frigidaire 24 in. PLD2560LCC Energy...
Frigidaire 24 in. FDBB944C Built-in Dishwasher Logo
329 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
