Question about Motorola Mobility RAZR V3c Cellular Phone
Dust behind screen
Hi i have got dust behind the glass cover of the screen how can i clean it
  • 192 Answers
Wait for some minutes i am uploading vidio for that on rapidshare and will post here it's links after few minutes.
Posted on Jan 10, 2008
6ya staff
SOURCE:
Dust, how do i clean off the dust on the mirror and bulbs?
Hi, Johnny here, I looked for some time for the same, here it is- first the cover below the screen for the speakers is a push in snap cover, pop that off, you will see four screws on the left and on the right, take those eight screws out, now lift the screen up then out, an that's it, you're in. be very careful cleaning in there, soft cloth and mild glass cleaner.
Feb 19, 2013 | Hitachi 51F500 51" Rear Projection...
Hi, I have an Hitachi 42PD9700 plasma TV. When the TV is off you can see a mottled/patchy area on the top right hand side of the screen (this is still visible when the TV is on if you look closely). This...
Same problem. Gray clouds INSIDE the external (plexi)glass of the screen.
I guess either:
1 - Screen collection dust or some electrostatic phenomenon.
or
2 - Some coating peeling off.
1 may be solved by dismounting and cleaning.
Any solution you know about ?
Sep 22, 2011 | Hitachi Televison & Video
I have a Mitsubishi 60"
there may be dust behind the screen & also on the reflecting glass. u will see that upper back portion cover is removable. remove it & see that glass there is glass on inner side of cover. clean it, also clean the screen. u will see there are 3 picture tubes faces on bottom side, clean all of them.
if it does not work then u can increase brightness of tv by increasing "screen" control of tv which is on the lower back portion of tv. this can be done by any tv repair expert only.
Sep 05, 2011 | Philips Magnavox 51MP392H Rear Projection...
We need to clean our Sony KP-53N77. We have some spider webs inside the protective screen and our color is a little fuzzy. We have never had the mirrors cleaned. How do we access the areas to clean and...
Remove the back hardboard cover by removing all the screws and lifting the cover up and toward you.
Mirror will be above but usually doesnt get dusty. Try not to touch it if you can. Same with back of screen. If you have a spider web just use a soft dry cloth to wipe it away.
You will likely find the upward facing lamp lenses covered in dust. Clean these with a soft cloth moistened with glasses cleaning solution. Glass cleaner works too.
Mar 20, 2011 | Sony KP-53N77 TV
I have little spots all over the screen display, i believe to be caused by dust in the lens assembly. could that be the problem? i see a lot of dust behind the glass... how do i clean it?
If there is dirt or other deposits on the LCD panels they are usually most visible at the extremes of focus. They will be blobby. You may also be seeing dead pixels which are clearly visible when in focus.The lens assembly itself will be sealed and is unlikely to be the problem, don't worry about flecks of dust in the lens area. You can clean the external lens with a soft cloth, much like a camera lens.
Projector internal optics are non-user servicable. If you can't live with the spots it will need to go to an approved center for cleaning / or repair. You should be able to find out where via this page
Feb 14, 2011 | Sharp XG-E3500 Multimedia Projector
Smudge, streaks, rays imac 24 monitor clean inside LCD
Yep, you can clean the LCD and the inside of the glass, but you will need two suction cups for glass. The ones for picking up window glass work. Lay the computer on its back. Place the suction cups at the upper corners and pull straight away from the table. The glass is held on by magnets and may have tabs at the bottom, so once the magnets are loose you may have to lift the glass away from the bottom edge. Be careful, it isn't safety glass and can break if dropped. The hardest part is keeping dust from getting between the screen and the glass during reassembly. Try working in a dust-free environment. I use two micro-fiber cloths, one with screen cleaner and one dry. You can't believe how much static builds up on the inside of the glass. It just sucks in dust. Don't wear fleece or you'll end up with fuzz as well. Stand your iMac up to reinstall. Clean the outside of the glass so you can see any dust on the inside. Place the bottom in place first. As you prepare to move the top into place, have light behind and above you and view the glass with the black screen behind. You can see most of the dust that way. Good luck.
Apr 23, 2010 | Apple iMac 24" Desktop
Looks like dust behind front glass on phillips 46pp8621
The only way to remove the dust and or spider webs from that area is to remove the front bezel assembly and separate the protection screen, it's better to leave a svc. co. do this because the two screens behind that are very expensive. Hope this helps..
Feb 23, 2009 | Philips Magnavox 51MP392H Rear Projection...
Dust behind screen
take off the screen cover (the plastic) with a pin and clean it with a (magic) cloth.
Jul 15, 2008 | Motorola Mobility RAZR V3m Cellular Phone
Sand under screen of RAZR V3
Shoels,
You could replace the screen and glass lens/cover but I having done this procedure a few times, don't think it's worth it as the Razr is a fragile phone and the case's just snap fit together.
There are cell phone repair shops (depending where you are located) that will replace both the screen and glass cover for a fee.
I personally would just look for a shady spot to view my display in daylight, as the V3 isn't worth the trouble/expense to repair (in my humble opinion of course).
Good luck
Mar 18, 2008 | Motorola Mobility RAZR V3
Glass Dirty on the Inside
unless the warranty of your scanner has expired, you have to disassemble your scanner and clean the dust inside.
Sep 01, 2007 | Microtek SCANMAKER 4850 Flatbed Scanner
Motorola Mobility RAZR V3c Cellular Phone Logo
50 people viewed this question
Top Motorola Mobility Cell Phones Experts
vince
Lawrence Oravetz
Vernon Taylor
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
