Question about Husqvarna Garden
The pulley won't pull!!! - Husqvarna Garden
  • 169 Answers
MOST LIKELY THE ENGINE HAS SIEZED UP....MOST COMMON FAILURE IS LACK OF LUBRICATION BUT IN SOME CASES THE CRANKSAFT SEAL FAILS CAUSING IT TO RUN LEAN.
Posted on Nov 19, 2009
Power cord does not retract immediately
Coleman Powermate Generator 5000 Watts / 6250 Watts ...
? 3:27
https://www.youtube.com/watch?v=IROa5QfPqkU
Nov 8, 2012 - Uploaded by Carlos Roman
This 5000 watt generator is great for backup power at home or forpower ... Coleman Powermate Generator 5000 Watts / 6250 Watts ... This feature is not available right now. ... folding handle, 1 quart, of oil, and 25ft generator convenience cord. ... How to convert a generator recoil starter to an electric starter!
pull cord won t retract Power Generators Questions ... - Fixya
www.fixya.com > Forum > Tags > pull cord won t retract
Power Generators pull cord won t retract questions and answers. Ask your pull cordwon t ... Question about Powermate Powermate 5000W Generator. 2 Answers · I was running my coleman powermate 6250 gen power ... cord 6250 trips out ... The pullcord does not rewind onto the pulley when pulled. At first I thought it was ...
Best Portable Generator Reviews
Feb 03, 2016 | Coleman Powermate Powermate 5000W...
Won;t start just stopped iin the drive way
Seized the engine , put socket an breaker bar on crankshaft pulley an see if you can turn engine by hand .
Nov 30, 2015 | 2007 Chevrolet Chevrolet Silverado 1500
Sthil whipper snipper fs38 won't engage the starting pull mechanism, it turns but won't grab drive coupling
remove the recoil cover and check the dogs that engauge the starter to the flywheel
Jul 28, 2012 | whipper snipper stihl fs 38
Belt siezed on chevy silverado
Probably a pulley that won't turn from seized bearings. Pull the belt off and check all the pulleys for free spinning. One will likely need replacing.
Good luck.
Jun 03, 2012 | 1996 Chevrolet K1500
Gx160 pull cord rope broken
1. Buy a starter repair kit or get five feet of nylon rope similar to what was in the starter from a Lowe's, The Home Depot or the like.
2. Remove the three bolts holding the starter on the motor and remove any remaining rope on the pulley.
3. Line the hole in the pulley up with the hole in the starter housing and thread the rope through both.
4. Tie a tight knot in the end of the rope and cut the tail off so it won't interfere with motor but not so short the knot comes undone.
5. Thread the other end of the rope through the t-handle and tie a knot in the very end so the handle won't come off and the rope won't be pulled into the starter during the next part.
6. Pull the rope up between the starter housing and pulley and get the rope into the notch in the pulley. Turn the pulley clockwise with the rope in the notch to put tention on the spring. Give it four turns.
7. When the notch gets back to the hole in the housing, hold the pulley and pull the rope back into place from outside the housing.
8. Let the pulley turn slowly so it retracts the rope.
9. You want four windings on the pulley and the t-handle to be held against the housing. If you don't get four windings on the pulley, give the pulley another tension turn (Step 6). If you have four windings and the t-handle isn't held against the housing or you get more that four windings, shorten the rope at the t-handle.
10. Reinstall the starter and you will be back in business.
Mar 06, 2012 | Honda Garden
Dvd tray won't open
The tray needs a new motor with a new pulley that does not slip on its shaft and get a new belt too.
It is easy to pull the dvd tray unit out of a GO VIDEO DVD+VCR machine to replace the motor with new pulley on it and the belt should be renewed too.The motor NOW may run only to push out the tray but it will not pull it in to LOAD the DVD or CD.
This is what I found after troble-shooting the function.
From Jim, and I need the same things. Can anyone tell me where I might buy those idems? lemsojim@gmail.com
Oct 07, 2011 | GoVideo Go Video DVD/VCR Combo
I replaced the pull cord on an mtd mower. and now it won't rewind the cord?
You have to tension the spring before installing the cord. Remove the cord. Put the recoil assembly in a vise. Prepare the ends of the cord so they can be threaded into place. Spin the pulley in the proper direction until it is tight. Align the hole in the housing with the hole in the pulley. Thread the rope in and knot it and pull tight. Slowly let the spring tension retract the rope. Cut the rope to length, install handle, knot and test.
Gary
Aug 27, 2011 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Put new belt on Part# 137292700 and it won, t turn the drum
one possibility is the belt isn't on tension pulley pulley,the proper placement is the belt goes on the top of pulley aand the pulley is pulled slighty by hand and the belt fits on the under side of the motor pulley watch this video for proper confugeration of belt on tension(idler pulley) and motor pulley pause vidoe at the 1:18 mark for a real good picture of proper alignment
http://www.youtube.com/watch?v=-PdL6cI8aPU
Aug 08, 2011 | Frigidaire FEX831CS Top Load Stacked...
Recoil pulley assembly keeps binding. Rope stays in pulley, but won't retract. Must remove motor housing , loosen 3 pulley hold down guides, & uncock the pulley. spring tension on recoil is fine....
Have you ever replaced the recoil rope, if you had is it a larger rope then the one that came with it? If so, that could be the cause of the binding. I had that difficulty once.
Aug 05, 2011 | Garden
Squealing from the engine when started, but not for long, after driving or reving the engine it stops whats going on
the bearings on the idler pulley need to be oiled when the engine is warm the bearings start to move esier due to the amount of torque they are under if it still squeals after oiling you may need to replace the pulley. if you replace the pulley repace the belt with it, so you won't need to pull it apart for a second time.
Jun 30, 2011 | Volkswagen Eurovan Cars & Trucks
Garden Logo
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
