Question about Muratec MFX-2500 Plain Paper Laser Fax
How to add an area code to an already existing phone number on a Muratec fax machine on speed dial.
  • ppura4 May 11, 2010
    Here is your solution
    » Brother
    » Canon
    » HP
    » Lexmark
    » Panasonic
    » Samsung
    » Sharp
    » Other
    a
    Genius:
  • 1,218 Answers
Go to Muratec web site and download(FREE) the operators Manual.
Page 2.1 of the manual details the "Auto-dialer" and page 2.2 explains how to enter or change numbers.
Muratecs Web site is www.muratec.com
Posted on May 28, 2010
HOW TO SEND FAX INTERNATIONALLY
Sending a fax to another county is easy - almost as easy as sending a fax to someone in your own country. The only difference is the phone number that you'll dial.
When sending a fax from one U.S. city to another, you dial a 1, then the area code, then the seven-digit phone number. When sending a fax from the U.S. to another country, you usually dial 011, then the country code, then a city code (which is like an area code), then the phone number. (The phone number isn't necessarily seven digits.) Check out the web site www.HowToCall.info, which will give you the specific country and city codes for the place that you're trying to send a fax to.
Other than figuring out the phone number, faxing internationally is identical to faxing domestically. Fax machines in other countries use the same protocols as ones in the United States, so you should have no difficulty communicating with a foreign fax machine. Older fax machines and noisy overseas phone lines may cause the transmission to take a bit longer than you're used to, but it should get there.
The first time you send a fax to another country, it might be a good idea to listen in as the fax machine dials. On some fax machines, you can press the "Dial" button to hear the dial tone, and dial the number manually. Listen for the ring and fax tone, then press the Start button to send the fax. You might want to do this the first time you send a fax overseas, just to make sure it's working as expected.
Oct 06, 2010 | Office Equipment & Supplies
I don't understand the one touch dialing on the HP 2140
Hi Suzeo. Many HP fax machines have the function you are requesting. It is called the broadcast fax feature. Look in your owner manual for this feature. If I knew which model you have I would have researched it for you. IF by chance, your machine does not have this feature, it would be money well spent to replace your current machine with one that does. Depending on how many pages the daily fax is, I am estimating that you are spending an hour or more each day on this task. J.
Jul 03, 2010 | HP Office Equipment & Supplies
We are having problems with our Muratex F110 fax machine. It won't send long distance faxes. the phone company says it is not on their end. any suggestions?
Well technically it's not on thier end. Let's remember that a fax uses a normal home style phone line.
So ask yourself these questions.
#1 Do I have long distance service on this phone line?
#2 If I do have long distance service do I need to do any kind of special dialing sequence to access long distance? Like a 9 or an 8 or any other number before dialing outside of your local area.
In some cases( businesses usually) a special code needs to be entered after dailling the number.
Most fax machines have a hansdset on them. Do this simple test. Lift the handset and dial a known long distance number and listen to what the operator message says. If all else fails call your phone company and ask them if this line has long distance capability.
Sep 22, 2009 | Muratec Office Equipment & Supplies
How do you add a number to the speed dial
Press the Phone Book button and follow steps for Speed Dials.
To use the one touch keys on the left side. Hold down a button until the display asks for a fax number. To edit an existing number, do the same thing.
Jul 18, 2009 | Samsung SF-560 Plain Paper Laser Fax
I have a lexmark x4270. Having problem sending fax. Sending local number, it's OK, but sending a different area code, it uses the local area code then the first 7 number of that number. Because someone...
Hi zoaj,
More then likely you have the fax set up to USE A DIALING PREFIX.
Therefore it is automatically doing this, regardless of what you input.
Follow the proceedure below ( which comes directly from the users manual for your printer type ) to change this. Delete the " USE A DIALING PREFIX " information.
once that is done, it will no longer automatically add the prefix for you. :)
I have BOLDED the relevant information below that pertains to this.
Please take a moment to evaluate my solution. Your appropriate rating of my solution would be greatly appreciated.
Thank you,
Using the Fax Setup Utility Use this utility to adjust the fax send and receive settings. When you save these settings, they apply to every fax you send or receive. You can also use this utility to create and edit your speed dial list.
  • Click Start onestep.gif Programs onestep.gif Lexmark 4200 Series onestep.gif Fax Setup Utility.
  • From Lexmark All-In-One Center All-In-One Main Page, click Fax Setup Utility.
The following table describes the Fax Setup Utility tabs:
On this tab:
You can:
Send
  • Enter your name and fax number.
  • Select a maximum send speed and a print quality for outgoing faxes.
  • Choose whether to scan the entire document before dialing the number.
  • Choose whether to use error correction.
  • Select when to print a fax usage report.
  • Select when to print a fax activity report.
Receive
  • Choose whether you want to print a footer (date, time, and page number) on each page.
  • Automatically reduce an incoming fax to fit to the paper size loaded or print it on two sheets of paper.
  • Select whether you want to forward a fax or print it, and then forward it.
Connection/Dialing
  • Select the number of times you want the machine to redial and the time between those attempts if the fax cannot be sent on the first try.
  • Select the phone line format you want to use (Pulse, Touch-tone, Behind a PBX).
  • Enter a dialing prefix.
  • Choose how (manually, if fax tones are detected, or after a certain amount of rings) you want to answer incoming calls.
  • Select a distinctive ring.
Speed Dial
Add to, create, or edit the speed dial list.
Group Speed Dial
Create a group number and name, and then add phone numbers to the group.
Oct 11, 2008 | Lexmark Office Equipment & Supplies
Move to a different phoneline
You need to change the phone number in the settings menu to reflect the new location. Erase the old, enter the new. Dont forget the area code, if different.
Jun 10, 2008 | Muratec F320 Plain Paper LED Fax
Faxing problem
1) Plug a single line wired (not cordless) phone in to the exact same phone jack as the fax machine and dial one of the fax numbers you are trying to dial out to using the exact same digits. Does the call complete Y/N? do you hear a fax tone Y/N?
>>>>If either answer is "No" you have an invalid phone number. If both answers are "Yes" proceed to step 2.
2) When you off hook do you hear a "stutter" dial tone? Y/N?
>>>>>"Yes" This is your phone company telling you that you have unlistened voicemail messages in your mailbox. Dial in to your voice mail and clear your messages. "No" go to step 3.
3) 2 part question: Do you have call waiting and is your fax machine trying to disable call waiting when dialing out?
>>>>>In many areas *70 (star-seven-zero) will disable call waiting for a single phone call. If you try to disable call waiting when call waiting is not on the line, the call will not complete. This may come in to play in a speed dial situation.
+++Other things to consider+++
*Is outgoing long distance blocked on the line?
*Is outgoing regional intralata (same area code) long distance blocked?
*Is local calling blocked?
*Is a speed dial misprogrammed? Forgot to dial "1" Dialed "1" in error?
*Is there a wiring problem? >>>Try moving fax machine to a different phone jack.
There may be no magic answer for your problem, I hope one of these suggestions helps.
Nov 16, 2007 | Brother MFC 240C All-In-One InkJet Printer
Lexmark x4270
HOLD DOWN THE SPED DIAL NUMBER WHEN IT BEEP THEN ENTER THE NUMBER WITH AREA CODE YOU WANT TO DIAL, WHEN FINISHED HIT SPEED DIAL AGAIN.
Oct 12, 2007 | Lexmark F4270 Plain Paper Inkjet Fax
Change phone number on fax
FAX PRINTS OUT OLD PHONE NUMBER. FAX NEEDS TO REFLECT NEW PHONE NUMBER ON SENDING HEADER OF FAX
Apr 18, 2007 | Muratec F360 Plain Paper Laser Fax
Muratec MFX-2500 Plain Paper Laser Fax Logo
452 people viewed this question
Top Muratec Office Equipment & Supplies Experts
Kyocera HP Expert
Ben
Ben
Adorjani Laszlo
Are you a Muratec Office Equipment and Supply Expert? Answer questions, earn points and help others
