Question about Belkin (F5D8231-4) Wireless Router (F5D82314)
Router will not go wireless. all lights come on
Router will not go wireless. all lights come on except wireless light.
  • 481 Answers
The "wireless" (second) light on this model does not indicate that the router's wireless features are active, it indicates that a computer is connected to the router wirelessly. If the "router" (fourth) light shows three little "radio wave" symbols, the router's wireless capability is on.
Posted on Nov 18, 2009
  • Macs R We
    Macs R We Nov 25, 2009
    I see you didn't rate my solution highly; if it was not of much help, I can be of more help if you explain more about what symptoms you are seeing other than the light bulb.
5 Suggested Answers
  • 5 Answers
SOURCE: I have a 2wire router
First of all, log onto the router via LAN port, select my network, click on wireless setting and ensure the wireless is ENABLE then click save to save the new setting. Use your laptop to connect to your router. Once connected the light will lit green. At some point lock your network.
Posted on Jan 14, 2009
vineetbajaj
  • 10 Answers
SOURCE: all lights are on my belkin n f5d8236 v2 wireless
Hi
try resetting the router first, then upgrade the firmware on the router & reconfigure the router
Posted on Apr 07, 2010
SOURCE: All lights for my Belkin N router are on except
Possible the wireless capabilitiy of your router is turned off and the security is turned off meaning that there is no security key in the router settings yet,
you will need to get in your routers default gateway check by going into the Dos Promp, type in IPCONFIG this will show you your IP address and default gateway type your default gateway in the address bar of your browser IE or Firefox ths should ask for a user name and password to get in your router the default user name will be admin and the password can be blank or password, or admin as well, depnds if your internet service provider change the password and user name of the router. once in the router check wireless settings look if the wireless is turned on the router and for the security just create a network security key to hav that light turned on if you want.
Posted on Jun 20, 2010
drifterK
  • 4924 Answers
SOURCE: all the lights on the
this means that you do not have a wireless connection successfully made...the light will turn blue when you connect a device on it ..If it works OK ..it means it is normal ..as long you do not have a connected wireless device on it ..the light is supposed to do so ..but if it does like that during a wireless connection it means either the wireless is not turned on into the settings or it is not working ..
In this case..you should get into the settings via the browser..using the Ip address...
ex:http://192.168.1.1
or whatever the address it is ..(IP of the router )
in there choose the wireless and re build the settings ..and enable it ..
But ..from what I know it is supposed to do so ...I mean yellow light ...as long as you do not have a successful made connection on the wireless ..
The light turned blue means a working section ...for example if you have a usb attached the usb led will be blue...and so on ..In case a section is turned off..it may act like this ...and this is something you have to check ..
If you never changed the password and admin user name ..they will be like the factory ones...meaning admin for both
Posted on Jan 02, 2011
I have a ATT 2wire modem and all lights are solid green except the wireless light and if theirs too much activity online then it shuts all the other lights off except the power light
Wireless is supposed to blink. Check to see if the power outlet might be giving out. If not, then you might have to replace the router.
Jan 13, 2014 | 2wire 2700HG-B Router (2700HGB)
Power light is on but other light is off
Hi, maybe it´s necessary to restart router, in the following link you can download manual and find the process to do it: WCR GN AirStation Technology 150Mbps Router Access Point and Bridge
Nov 11, 2017 | Buffalo Technology Buffalo Airstation...
My linksys wrt160n wireless router light is blinking
Welcome to FixYa
Indication of Router Lights:
  • Power light blinks. If LAN or WAN cable is plugged in, their respective lights will flash on activity.
  • Power light turns off for several seconds.
  • All lights, except power light, turn on and then off.
  • Power light blinks slowly, then faster, and WLAN light will turn on.
  • Once Power light and WLAN light are on solid, the router is fully rebooted.
A working router should show solid green power light. upgrade the firmware of the router.
If this Helped you-Rate me..Thanks for Using FixYa
Jun 30, 2010 | Linksys WRT160N Wireless Router
All light are on (solid blue) except the wireless
The wireless indicator (LED) only lights up blue when a it has a connection to a wireless device.
Once a device (laptop, printer,etc) is configured with the settings that match your router, the blue light will turn on unless there is a physical proble with the router itself.
Is this router new and you're trying to get it setup or was it functioning before and now there is a problem?
Aug 25, 2009 | Belkin (F5D5231-4) Router
2wire modem wireless light isn't on
make sure that the wireless is available with that model and if it is make sure wireless is enabled
Jul 21, 2009 | 2wire 1000hg DSL Modem & 802.11g Wireless...
I have a 2wire router from AT&T, all lights are green, except the "wireless" light. It's not on, how do I become wireless?????
Hi dilex
The 2wire router wireless light comes only when a system is connected to it wireless.
Please post the system that you are using and also what exactly when you try to connect via wireless.
Thank you
Rakesh
Dell Laptop Expert
Jan 06, 2009 | 2wire 2700HG-B Router (2700HGB)
Belkin (F5D8231-4) Wireless Router (F5D82314) Logo
404 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
