I have a comtrent 5361t router/modem i cannot get
I have a comtrend 5361t router/modem i cannot get my pc to communicate with the router through the web browser.
  • 3 Answers
Try manually assigning your computer to an IP address in the same subnet as the Comtrend.
For Example: Set the computers IP to 192.168.1.5 with a Subnet Mask of 255.255.255.0 and default Gateway of 192.168.1.1.
If that does not allow you to access the admin page at 192.168.1.1 then try resetting the router.
Good Luck!
Posted on Jan 13, 2010
No ip on comtrend ar-5381u, will not connect to internet
DO NOT INSERT A PAPER CLIP TO RESET THE MODEM! unless you know how to reprogram the router, this includes having complete knowledge of ALL the settings required by the ISP AND having your username and modem password (modem authentication passwords are not usually provided to the customer) Doing a "hard boot" will only return your modem to factory settings
Dec 21, 2012 | Comtrend CT-507 Router
How to open nat for ps3 modern warfare3
Hey alldayrobbie,
Check out this forum post that gives step directions and has video details on how to open a locked NAT for PS3.
Good Luck
Jul 29, 2012 | Comtrend 12 Used 5361t Modems
Every time my power goes out I have to completely re-setup my whole network. The comtrend ct-5072t modem does not seem to want to communicate with my linksys wrt54gl router. changed the ip on the router...
With changing the IP and all that business it may have messed it up a little bit.
This may not be the most sophisticated way of fixing it, but this is what I personally would recommend. THIS WILL ERASE YOUR ROUTER CONFIGURATION, but at this point that should be a good thing.
On both the Comtrend modem and the Linksys router, there should be a "reset" button. Grab a pencil or something long and skinny to press the reset button. Press on the reset button for 5 seconds on both the Modem and the Router.
Then make sure all of your wires are plugged in correctly. Go into your Router's web configuration by opening up Internet Explorer, Firefox, Chrome, etc. and typing "192.168.1.1". The username should be "Admin" and the password should be "password".
After you log in, change the Wireless settings and setup a password for your network and a name for your network.
Unless your Router is truly is faulty, then it may still reset on a power outage, but it should retain all of these settings.
Hope this helps.
Thanks for using FixYa.
Aug 07, 2011 | Comtrend CT-507 Router
I have a comtrend ADSL2+Ethernet Router hooked to my desktop Pc and a G-Wireless Router made by Belkin.According to the tech I should be able to connect these two to use my Laptops, but any way I've tried...
You dont need a Belkin Disk to set up - this can be done manually you can get a manual from this site http://en-us-support.belkin.com/app/product/list/q/routers/ select G in the first dropdown and then your model - theres two to choose from and then then the version
you have a choice - you could change the comtrend router to just use the modem - bridged mode - they have a few different routers see here http://www.comtrend.com/links/i$residential-adsl2-modem-router$product.htm so not sure which one you have if you can bridge to just use the modem then connect tothe Belkin and all PCs should connect to the Belkin
OR you can connect two routers together Leave the comtrend router set as it is -
Set the IP address of belkin router to same subnet as the comtrend. Depending on the DHCP range of the comtrend router - set the IP outside this range - so if comtrend is set to give an ip of 192.168.0.2 to 192.168.0.100 - set the belkin to 192.168.0.254 Disable the DHCP in the belkin.
Connect the comtrend LAN to one of the Belkin LAN ports - you may need to use a crossover cable. On the belkin the WAN port will be left unconnected
Mar 20, 2010 | Belkin (F5D7231-4) Wireless Router
How do you locate wep key for comtrend ct-5361t router
To find out the WEP key, you will need to access the routerset up. Do you have any computer connected to the router Or any computer online using the same router ? If you do not have any computer online through the router then you will need to connect the computer to the router and access the routerset up. Once you access the router set up then you will be able to locate the WEP key. Click Here for step by step solutions
Nov 17, 2009 | Computers & Internet
I have a comtrend ct-5361T wireless router can not access internet
  • set the wireless settings first to no password first for this is a password issue most of the times
  • and change the SSID name and channel not auto, set to 6 or 11
Jul 31, 2009 | Computers & Internet
Driver for comtrent ADSL Router
Drivers first link & manual at second... http://www.dlink.com.au/tech/drivers/files/routers/dslg604t.htm www.comtrend.co.uk/Datasheets/DS_CT-507_CT-507E_%20C5%20R1.1.pdf
Sep 01, 2007 | Comtrend CT-507 Router
Computers & Internet Logo
515 people viewed this question
David Payne
David Payne
